| Performance Enhancement Things that make you go VRRROOOOM! |
06-16-2009, 04:43 PM
#31 (permalink)
Member #12174
Sportsbike: TLS/R 98,TOPSECRET track hack
Riding Experience: 25 years and counting...
Life Wasted on TLZone: 1 Month, 2 Weeks, 0 Days and 7:40:08 Hours
Troy
hi Koko!
im sorry if i upset you,but i think you didnt read this properly!
Originally Posted by Troy
well,those forks may have ohlins internals,but they are NOT ohlins forks!those are TLR? with painted forkbottoms!
anyway you have a nice bike with nice mods!keep modding!
heres OHLINS:
anyways,nice work!like your bike!
TLOTM Aug 08 TLOTY 2009 TLOTM Aug 09
TLR engine(SAM),OHLINS:FG339/SBK kit forks,rear shock(TLR),steering damper,ISR-BRAKES:6pot billet radials,rear billet caliper,3xdiscs,front master,clutch assy,TRANSLOGIC MICRODASH 2,CARROZZERIAs,PC 3,RIFLEMANS 1/5,airbox mod,HRC rear reservoir,YOSHIMURA:R-77 full himount sys,clutch cover,MRA db,CARBON:mirrors,K6 front fender,GILLES: rearsets,chain adjusters,TITANIUM rear axle nut,VELHILL lines,HARRIS screen brace,MICHELIN PP 2CTs,SKIDMARX bellypan,SAMCO hoses,GEELONG tank protector(carbon)SUPERSPROX 42,VORTEX 17,EK goldchain,VANZUKI sprocket cover,braced swingarm and....
06-16-2009, 11:38 PM
#32 (permalink)
Member #4643
Sportsbike: TL1000S -97
Riding Experience: 8 years
Life Wasted on TLZone: 1 Month, 2 Weeks, 2 Days and 9:38:17 Hours
Octofinger
Should be scared of the Admins
Originally Posted by koko_TL1000R
Yes I am thinking a lot about Re-Map to the ECU on my bike but the best option for this case is to buy Yoshi Box .............. you now sell such a "box"
I am ready to pay her a reasonable amount and I'm sure that Chuck will guide me and give advice how to configure the original ECU reprogramming!
I only have a Yosh replica, i.e a home built mak box...
It does have the same functions, but I cannot really guarantee the functionality of it as I built it myself.
If you're a subscriber, you might put up a thread in the "want to buy" forum.
Done: -98 thermostat housing + bypass mod, Rifleman's 1/5'th, black screen, 17/40 sprockets, home made ATRE, Bitubo rear shock, Barnett clutch springs, split steering damper bracket, iridium plugs, D&D CF full system, +/- mod, Van fork sliders, Ziggy999 frame sliders, Pazzo shorty levers, US headlight, Busa front MC, Galfer SS lines, TLR 6-potters, airbox mod, PCII, Van sprocket cover, EBC front brake discs, TI rotor bolts, Van clear clutch cover, 6-spring clutch, Van clutch plate, Scotts oil filter, K&N.
Todo:CF undertail/gap mod, Discacciati discs, fork revalving, Stealth sprocket, full TLR M4 system, improve crank case breather, fix the broken faring and scratches ...
06-17-2009, 04:51 AM
#33 (permalink)
Member #12687
Sportsbike: TL1000R '99/CBR600Evo-I
Riding Experience: since - 1991
Life Wasted on TLZone: 2 Days and 17:29:24 Hours
koko_TL1000R
hi Koko!
.............yep I not read this Internals Sorry and excuse me!
However - for Me problem is this PC-II and I hate him BUT I Must Make with this "Old man" I buy this PC-II exactly for my TL '99.......... if I buy PC-III USB I must make too mutch mod's for wires,without connectors ............ my Injectors is diferent and not have space and bla bla bla  ..........
Diferent connector,Not place for nothing............. - PC-II is decision in My case and should make it to work properly and accurately, Friday will be the day of a terrible truth - if I achieve development and progress!
This Dayton Dyno not have air blowers
for Bike Air Intake(SRAD), there is no system for removal of exhaust gases of the Bike,after every run - the power of the motorcycle fell to 1-2ps. Due to lack of oxygen in the room!
After a every 2-3 run need 1-2 hours time to be ventilated the room, and again and again and.......... - everything is pretty nerve - racking as a whole, but I am determined to set his bike in the final end of this week - whatever it cost me!
TL1000R - Race exhaust system YOSHIMURA+thermo wrap,RS3Carbon,280cc Fuel Injectors,Custom Cam timing,PC-II,Nikko EMCU,WISECO Pistons+squish 0.7mm12.8:1,Oil Catch tank,Ported Cylinder Heads fromTL'97 ,Barnett Cevlar Clutch,Race Airbox Nikko MOD,Custom Race Airintake,DENSO Iridium+Platinum,CBR600RR Ignition Coils,PIERBURG 6.bar fuel pump,Custom Adjustable Fuel Pressure regulator,Polyurethane fuel line,J&R Race air filter custom made,Throtle Insert 1/5 MOD,Charging MOD,EGR&PAIR removed,Brembo Radial Brake pump,Wave rear brake rotor,RK Gold chain,Chiarravali -1F+1R,,UP-rev limiter +500rpm............ 129.9whp&114.94N/m
06-17-2009, 05:04 AM
#34 (permalink)
Member #4643
Octofinger
But... You're not connecting your PCII to the injectors?
06-17-2009, 02:23 PM
#35 (permalink)
Member #12687
koko_TL1000R
PC-II is connected to the receptacle of the ECU which is the main reason to choose it not just PC-III,...............and PC-II has a built-in ignition module
06-25-2009, 04:30 AM
#36 (permalink)
Member #12687
koko_TL1000R
SUZUKI TL1000R to this moment wat I make with my Bike..................
1.Full Race exhaust YOSHIMURA
2.Yshimura RS-3 Carbon slip-on end cans
3.Ceramic wrap for exhaust system
4.WISECO High compresion Pistons
5.Squish - 0.7mm
6.Compresion ratio - 12.8:1
7.Yoshimura Superstock Cam's stage 1
8.Custom cam timing - Nikko
9.280cc fuel injectors
10.Cylinder Heads TL-S '97
11.Power Comander - 2
12.Oil catch tank - "PIM"
13.OHLINS Forks
14.AP-Racing Wave front brake rotors
15.Hayabusa-Golden Brake Calipers
16.Nikko Air Box MOD
17.Nikko Airintake MOD
18.Nikko Switch TRE
19.Nikko - EMCU
20.Nikko Shift light
21.Custom Ignition angle modify unit - Nikko's hand&home made
22.Goodridge-Race Steel Brakeline
23.Steel Clutch line - gloga
24.BREMBO Radial Brake Pump
25.BITUBO steering damper
26.SBS - Front Sintered Race brake pads
27.Chiarravali & VORTEX - Racing Sprocket Black Anodized:
front - 15,16,17: rear - 38,39,40,41( Full set - SBK Race)
28.RK-Racing GOLD Chain - RK520XWZ-Ring
29.Spark plugs DENSO - Iridium+Platinum
30.Adjustabe Fuel Pressure regulator Nikko
31.Polyurethane fuel line
32.J&R Race air filter - custom made Nikko
33.Throttle Insert 1/5 MOD Nikko
34.Charging MOD
35.Pair valve removed
36.UP-rev limiter +500rpm
37.Carbon Front fender - Coerce Race - JAPAN
38.Bi-Xenon 4300+6000
39.GSX-R750K2 - REAR Set + Undertail
40.DB windscreen Zero Gravity
41.Frame Sliders
42.Forks Sliders
43.Rear Swingarm sliders
44.EBC Sintered rear brake pads
Project for next one or two months ...........
BARNET Kevlar - Race Clutch Kit (payed and now waiting)
Fuel pump 6-bar with big range (payed and come after 10 work days)
Rear Wave brake rotor - from HONG KONG
Fully Adjustable Race Rearsets - TechG (payed and now waiting)
Ignition coil from GSX-R1000 K5+
BITUBO Rear shock
Quick shifter
FORKS Adjusters
Race fuel cap
07-06-2009, 12:49 PM
#37 (permalink)
Member #12687
koko_TL1000R
BARNET Kevlar - Race Clutch Kit,Fuel pump 6-bar with big range,Rear Wave brake rotor,Ignition coil from GSX-R1000,Fully Adjustable Race Rearsets All of this is on the Bike now.
........ But my little "project" never not have the END!
And Now in my head have other idea - light wheels...............
GSX-R wheels is cheap from other solutions(Marchezini & .............) I am looking for set GSX-R wheels from 600 K3 ..................... Which would be better than 1000 K2 or 600 K2-K3, the difference is in the rear wheels 5.5" at 600 versus 6" of 1000
What would you recommend me a 5.5" or 6" and what generation K2 K3 K4 K5 ....... rear wheels because the indicators - for open and pinion drives, etc. are the same
Which weigh how much - I need advice and count on you!
07-07-2009, 10:18 AM
#38 (permalink)
Member #9304
Sportsbike: 1998 TL1000R
Riding Experience: 11 years
Pictures: 33
Life Wasted on TLZone: 4 Weeks, 0 Days and 11:15:40 Hours
thumpthump
5.Squish - 0.7mm
13.OHLINS Forks
18.Nikko Switch TRE
19.Nikko - EMCU
34.Charging MOD
41.Frame Sliders
42.Forks Sliders
You should update your front brake rotors, item #14. As already mentioned, they are not AP Racing "wave" rotors. There is no such thing.
07-10-2009, 06:05 AM
#39 (permalink)
Member #12687
koko_TL1000R
Ignition Coils from GSX-R 1000 ........... is too big   but have new solution - Coils from CBR600RR
07-10-2009, 06:15 AM
#40 (permalink)
Member #12687
koko_TL1000R
5.Squish - 0.7mm
9.280cc fuel injectors - GSX-R 1000 K8
13.OHLINS Forks
14.Racing Wave front brake rotors
18.Nikko Switch TRE
19.Nikko - EMCU
31.Polyurethane fuel lines
34.Charging MOD
38.Bi-Xenon 4300K-Lo+6000K-Hi
39.GSX-R750K2 - Tail + Undertail
40.DB windscreen
41.Frame Sliders
42.Forks Sliders
43.Swingarm sliders
45.BARNET Kevlar - Race Clutch Kit
46.PIERBURG Fuel pump 6-bar
47.Fully Adjustable Race Rearsets - TechG
48.Ignition coil from CBR600RR
49.Rear Wave brake rotor
BITUBO Rear shock
Quick shifter
FORKS Adjusters
Race fuel cap
SV K4 Gauges
GSX-R600/750 K3 wheels
This is Up-date fo this moment - now is OK?!?
But I not understand who rear wheels is better 5,5" or 6"
