| Performance Enhancement Things that make you go VRRROOOOM! |
05-20-2009, 03:06 PM
#11 (permalink)
Member #69
Sportsbike: tiller
Riding Experience: some
Life Wasted on TLZone: 4 Weeks, 1 Day and 9:34:01 Hours
J-Bone
Originally Posted by tzr_andy
My PC2 has gone tits up today which has a custom map for the mods
would you be willing to share that PCII map? I have the same mods except I have a full Akra system instead, I would like to try your map if you dont mind.
Thanks
Done:
-==- Full Akra Evo Ti w/ custom hangers -==- CZ Stage2 wheels -==- Semi-floating rotors by Speedking -==- Brembo 19x18 m/c -==- Galfer HH's -==- Galfer wavy rear -==- Bitubo shock -==- Rosmoto adj. rearsets -==- ExtremeTech damper -==- PCIII USB -==- Van's rear brake res. -==- Van's sprocket cover -==- Joe V mod -==- K&N filter -==- Galfer lines -==- 520 conv. @ 16/40 -==- Speedohealer -==- No-cut sliders -==- GSXR K2 rear caliper -==- Pairvalve mod -==- GiPro w/ ATRE -==- BRG 1/5 throttle -==- Avia Comp. C/F mirrors -==- C/F fender -==- Pyramid C/F hugger -==- GCC C/F tankprotector -==- FSMD undertail -==- LP speedscreen -==- Flush signals -==- Subframe mod. -==- GAP mod. -==- Quick release tank & seat -==- Preload adjusters -==-
To come:
-==- GSXR750K4 forks -==- R1 radial calipers -==- Woodcraft Clip-on's -==- Pro-Grips -==- Van's CCC -==- Van's PP -==- Van's +1mm eccentrics -==- Barnett clutch springs -==- TWM gas cap -==-
05-20-2009, 03:29 PM
#12 (permalink)
Member #69
Sportsbike: tiller
J-Bone
Done:
To come:
05-21-2009, 02:47 PM
#13 (permalink)
Member #5251
Sportsbike: tl1000sv,cb1100r
Riding Experience: definately
Life Wasted on TLZone: 3 Weeks, 2 Days and 4:42:56 Hours
jagboy1
somewher there's some results from testing the pressure in air boxs.......i think the tlr gained 12mb.....no much......but better than nothing.....also means the nice fresh cool air from the front of the bike was being pushed in,rather than sucked in....
another thing to think about is....as the bike moves through the air.....it creates low pressure down the sides.....effectively drawing air from the middle of the bike......this cant be a good thing with the lid of....
on a dyno this wouldn'y be a factor......as there's usuall just a cooling fan....  ideally bikes should be set up in a wind tunnel.....with the fan directly linked to wheel speed.......
05-21-2009, 03:33 PM
#14 (permalink)
Member #13045
Sportsbike: 1999 TLR
Riding Experience: Fall down & get back up
Life Wasted on TLZone: 1 Week, 4 Days and 15:15:02 Hours
officer140
Sooo, u gonna share those PC II maps?
05-25-2009, 01:56 AM
#15 (permalink)
Member #9887
Sportsbike: 2002 TLR YELLOW
Riding Experience: After I started walking
Pictures: 7
Life Wasted on TLZone: 3 Days and 21:17:35 Hours
N2DEEP
I ran no cover for a bit. Didn't notice anything but a big airbox decibel level increase. So all I got was a headache after an hour of riding.
Originally Posted by Kamikuza
Now all you need is a full fairing, a second set of injectors, better cams, 6 spring clutch, full fairing and a beam frame and you might have a decent bike
Bike Gallery
http://www.tlzone.net/forums/vbgarag...o=view&id=9887
07-05-2009, 01:36 PM
#16 (permalink)
Member #3874
Sportsbike: TL1000R, TZR 250 race bike
Riding Experience: 20 yrs
Life Wasted on TLZone: 1 Day and 9:24:27 Hours
tzr_andy
Been having website problems, but once sorted, I'll be putting up all the maps I've either used or have downloaded.
Have also read the Sportrider Magazine articles on ram air, and seen the pressure increases within the airbox so will be trying the bike with the lid on. Only issue for the time being is that I'm looking to get a cheap(ish) Wideband Commander to ensure that the bike doesn't run lean at high rpm / throttle openings and to give me something to work from when adjusting the map(s).
Latest purchase is a PK Quickshifter which integrates perfectly with the PC3...just need some testing time to sort out the shift times required.
Andy
http://www.andy.t.wheeler.btinternet.co.uk
PC3 USB, Quickshifter, Airbox Mod & K&N, Full M4, Harris Rearsets, GSX-R M/C.
"You can have the best parts in the world, but if you're hamfisted with brakes, steering and throttle, you'll always be shit!"
07-12-2009, 12:24 PM
#17 (permalink)
Member #3874
tzr_andy
Quickshifter works a treat - set to 75ms and not to operate before 6000 rpm, so enabling normal road use up to about 100mph for day to day tootling around. If I need/want to get a shift on and turn the noise tap on, wazzing through 6k then shifting is just an absolute pleasure of seamless acceleration. Not tried it cranked over yet, but I've had issues shifting mid corner before, so will see what this does to alleviate any bucking bronco impressions!
Sounds fucking awesome too!
Andy
