| Open Forum Non-TL related, Current events, protective gear, etc. NO PIRATE TALK |
05-14-2009, 09:43 AM
SQDBIKE Admin
Member #102
Sportsbike: '04 Yamaha R1, '09 Ducati Streetfighter
Riding Experience: 2 weeks
Pictures: 14
Life Wasted on TLZone: 1 Month, 0 Weeks, 5 Days and 18:21:23 Hours
crashtd
need motorcycle bloggers,
inquire within.
Any insight on the firing order?
So...I have these pictures...and to me, it looks like this motor is firing 1/4-2/3
any thoughts? this is outside my sphere of knowledge...so I'll leave the debate open to you much more wiser folk.
click for bigguns
05-14-2009, 11:34 AM
No Likey No Spiders
Member #613
Sportsbike: Virtual NSR500
Riding Experience: Got some
Life Wasted on TLZone: 1 Month, 1 Week, 2 Days and 15:35:16 Hours
MotoTiller
Spiders Love Me
Looks like 1-4-2-3- to me as well.
Is this a pic of a real motor in production today or just a design of something for the future?
Might be easier to google it if its real.
05-14-2009, 11:37 AM
SQDBIKE Admin
Member #102
Pictures: 14
crashtd
inquire within.
it's a soon to be production motor...no info on it yet. I'm trying to figure out if its a big-bang design or not.
05-14-2009, 12:02 PM
Member #7563
Sportsbike: TLRS
Riding Experience: not enough
Life Wasted on TLZone: 2 Weeks, 4 Days and 6:37:24 Hours
Loki-TLR
Loki-TLRS
Exhaust cam lobes seem to be 90 degree apart per cilinder. And the crank is just plain ordinairy.
Arwan:
The coolest car alarm tester by far - TL1000S
05-14-2009, 02:32 PM
Scooter hottie chauffeur
Member #3716
Sportsbike: TL1000R, is there any other?
Riding Experience: 23 years / 121,000 miles
Life Wasted on TLZone: 1 Week, 4 Days and 16:48:01 Hours
Rifleman
says: All that is needed
for evil to prevail, is
for good men to do
nothing.
that's what is was on the Kan-o-tuna. 1 and 4, 2 and 3... both fired at the same time. I guess it doesn't matter if the "other" cylinder gets a spark in the middle of the exhaust cycle...
Need a 1/5th throttle insert, or need to know how to install it click me now. OR click here and get the kewl new installation instructions in downloadable .pdf format.
Silver metalic flake Clear Clutch cover has been sold See what was available. (8/12/09)
05-14-2009, 03:27 PM
Life Wasted on TLZone: 3 Months, 2 Weeks, 1 Day and 19:51:09 Hours
if you look at the exhaust cam on this picture you will see that it is a conventional camshaft.
this picture is of a conventional engine and you can't make any assumptions from it .
to be a big band engienthe lobes on the cam would need to be in the same plane in 1-4 and 2-3 . the firing order would then be determined by the phasing of the lobes. if the 1-4 pair were 90degrees before the 2-3 they would fire first. if phased after then fire after.
remember here that the cam turns at half the crank speed. so 180degrees of cam is one revolution of crank.
but the answer to the question first asked is this is not a big bang engine.
05-14-2009, 03:29 PM
Loki your crank requires a different cam altogether.
05-14-2009, 03:46 PM
Member #371
Sportsbike: 10 speed racer
Riding Experience: 3 crashes
Life Wasted on TLZone: 3 Weeks, 6 Days and 13:59:30 Hours
Miles B
sucks!
Yup, lobes show non-banger.
Used to ride a '01 TLR
He wrapped himself in quotations- as a beggar would enfold himself in the purple of Emperors.
-- Rudyard Kipling
05-14-2009, 03:52 PM
Life Wasted on TLZone: 3 Months, 3 Weeks, 4 Days and 18:59:38 Hours
The basic method of decoding the pics for me is to look at the pointy bits of the cam. If the pointy bit of the intake cam is facing the valve or close to it then that cylinder is sucking in air/fuel, if the pointy bit on the exhaust side is facing the valve, then that cylinder is squirting exhaust out and if both pointy bits are pointing away from the valve fuel/air is getting compressed
05-14-2009, 04:32 PM
Member #5845
Sportsbike: '97 TLS
Riding Experience: 7 years, 8 bikes, 1 wreck
Life Wasted on TLZone: 2 Days and 22:53:42 Hours
Eldon
That theyar is a BEEMA! Pretty sure thats the new s1000RR engine. Apparently they continue to use those silly hemishperical shims...I was wondering.
Remember: That which doesn't kill you only makes you slower.
