possible mains - TLZone Forums
Old 05-26-2008, 08:38 AM   #1 (permalink)
jagboy1's Avatar
Member #5251
Sportsbike: tl1000sv,cb1100r
Riding Experience: definately
Trader Rating: (13)
Life Wasted on TLZone: 3 Weeks, 1 Day and 8:18:57 Hours
jagboy1
Send a private message to <!-- google_ad_section_start(weight=ignore) -->jagboy1<!-- google_ad_section_end --> Steve is the prettiest admin
possible mains
i've got a noise on my tl....when it's warmed up...and sat in neutral...there's a sort of metallic knocking noise....it sounds end float ...used to get similar sound on my ols gs 425...that was cam end float...i know it's not end float on crank....but when i take hold of fly wheel...i can feel movement when i try to lift it up and down....i'm guessing there should be a tiny amount...but not sure how much is too much
the motor had a complete rebuild last spring...all bearings replaced.
Old 07-07-2008, 01:39 PM   #2 (permalink)
jagboy1's Avatar
Member #5251
Trader Rating: (13)
jagboy1
it was the mains that had gone in my motor....one of the shells had started to work it's way into the side of the crank......something that ususlly happens to sv650'ss....several weeks and a few hundred £££££s later ....i now have a fully rebuilt tlr motor sat in my s.....done a few miles....all sounds nice and as it should.....just need to set th tbs and tps....
Old 07-07-2008, 01:45 PM   #3 (permalink)
Posh Johnny's Avatar
Member #5574
Sportsbike: Boo hoo don't rub it in!!!
Riding Experience: 6 points in Bala
Trader Rating: (13)
Life Wasted on TLZone: 2 Weeks, 2 Days and 18:04:55 Hours
Posh Johnny
Send a private message to <!-- google_ad_section_start(weight=ignore) --><b>Posh Johnny</b><!-- google_ad_section_end --> Steve is the prettiest admin
I have seen you ride mate, wonder if it is a 650 engine you have in there
Old 07-07-2008, 02:20 PM   #4 (permalink)
Micky's Avatar
Member #5090
Sportsbike: 97 / TLs
Riding Experience: France Belguim Germany
Trader Rating: (10)
Life Wasted on TLZone: 2 Weeks, 0 Days and 19:16:31 Hours
Micky I Love Scotland............
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Micky<!-- google_ad_section_end --> Steve is the prettiest admin
Carl on our last ride out when you were pottering about at the back I thought it was down on preformance or running on 1 cylinder
is it really a 650 engine
The folk I've met from this TL Zone are the best
Old 07-07-2008, 02:53 PM   #5 (permalink)
richara3's Avatar
Member #6346
Sportsbike: 2000 tlr
Riding Experience: not enough
Life Wasted on TLZone: 1 Week, 0 Days and 19:06:32 Hours
richara3
Send a private message to <!-- google_ad_section_start(weight=ignore) -->richara3<!-- google_ad_section_end --> Steve is the prettiest admin
Good work carl... But why was there lateral movement in the shell.? Hasnt it got a notch that matches an indent in the cases?
And 650cc ... more like 50cc poofter!
My name is Andy Piper cross filter, airbox mod,Blue Flame Titanium cans,PCII,TRE,Barnett clutch springs,Ohlins rear shock,revalved forks
Old 07-07-2008, 05:43 PM   #6 (permalink)
jagboy1's Avatar
Member #5251
Trader Rating: (13)
jagboy1
your a cheeky pair.....
Old 07-07-2008, 05:47 PM   #7 (permalink)
jagboy1's Avatar
Member #5251
Trader Rating: (13)
jagboy1
no notches to hold em in place...they have to be pressed in as a pair because the cases split vertically....my gues is that perhaps latteral play on crank became a bit to much....there were a few marks on the cases....the later one have a plate to stop the bearing coming out...and a different thrust washer....
Old 07-07-2008, 05:50 PM   #8 (permalink)
richara3's Avatar
Member #6346
richara3
Originally Posted by jagboy1 View Post
no notches to hold em in place...they have to be pressed in as a pair because the cases split vertically........
Doh!.. so they do.. Super glue/ loctite
Old 07-07-2008, 06:03 PM   #9 (permalink)
jagboy1's Avatar
Member #5251
Trader Rating: (13)
jagboy1
i think they're held in with suzuki magic paste no.4
no locktite...just pressed in....they have to be lined up...but that's it.
