05-23-2008, 08:25 PM
Member #11238
Sportsbike: 2000 Tl1000s
Riding Experience: 5 years
Life Wasted on TLZone: 3:14:19 Hours
tlthekid
High Compression pistons......
Does anyone know if wiseco high comp pistons for a tl1000r will fit in a tls1000? If not does anyone know where I can find some High compression pistons saving up for winter project high comp piston and flowed heads.........  Thank you for you help in advance.
05-23-2008, 09:03 PM
Member #7581
Sportsbike: sv400Naked(sold) TL1000R
Riding Experience: from 1998
Life Wasted on TLZone: 3 Weeks, 1 Day and 20:27:44 Hours
ego
wiseco hi-comp have the same compression with tlr stock forged pistons, they will fit in to tls
Russia
Transistor TRE, Airbox Mod, 17/40, 1/5 trottle insert, Ohlins shock and steering damper, gold 07 busa forks with Traxxion dynamics "Street Only" setup, fullfloating rivet mod brake rotors, Carrozzeria black wheels, Brembo brake MC 19x18, Brembo clutch MC 16RCS, black powdercoated frame/subframe/swinger, 03 YB colour scheme, full Yosh SS system, adjustable Yosh billet rearsets, Honda Dio ZX integrated tail light with LEDs, headlight mod with BMW E50 Bi-Xenon 3" lens and integrated turn signals.
05-24-2008, 09:11 AM
Member #221
Life Wasted on TLZone: 3 Days and 20:21:58 Hours
doug
JE do make a higher compression piston than Wiseco for the TL
05-24-2008, 11:31 AM
Member #5251
Sportsbike: tl1000sv,cb1100r
Riding Experience: definately
Life Wasted on TLZone: 3 Weeks, 2 Days and 4:42:56 Hours
jagboy1
i'd not bother with the tlr/wiseco option....it's a very small gain....use the JE pistons....better still...get +2mm oversize high cmp pistons....and set your squish.....
05-24-2008, 12:45 PM
Member #221
doug
JE only make the pistons to order they do not stock them, minimum order is 4 so you will need to find somebody to share the order with.
05-25-2008, 02:42 PM
Member #12270
Sportsbike: nitrous tls
Riding Experience: 33 years
Life Wasted on TLZone: 14:51:46 Hours
silson
go for je they are an higher comp ratio than wiseco
05-25-2008, 07:02 PM
Member #7791
Sportsbike: 2002 TLR
Riding Experience: Street riding
Life Wasted on TLZone: 1 Day and 6:39:56 Hours
TLTiger
I haven't been keeping up with you all, been away from the zone for a while now. Its the season to be riding and lost some of my garage knowledge. Just wondering what the pro and cons are with these JE or Wiseco +2 mm pistons? Will they work with the same rods? If you have to get 4 of them I may take 2 off your hands unless you want them all to yourself.
On a side note anyone know where you can find ceramic bearings at for the TLR? And are they better than the standard? This might be a winter mod. Thanks for the help and I'm not trying to steal the thread.
02' Suzuki TLR, yellow/blk, Yoshi exhaust, K&N air filter, TechG rear sets, gold 6 pot front & rear brake calipers, steel braided brake lines, Pazzo levers, Rifleman's 1/5th throttle insert, PCIII, Zero gravity DB, manual TRE, frame sliders, carbon fibre bar ends, Tri-metal gear sprocket 16/41 gear conversion, Barnett springs, Van's clutch cover, Van's clutch plate in red with chamfered edges, this modding is very addicting!
05-26-2008, 10:35 AM
Member #9502
Sportsbike: 02 TL1000R, 00 TL1000R, 97 TL1000S
Riding Experience: 14
Life Wasted on TLZone: 1 Month, 0 Weeks, 0 Days and 1:25:56 Hours
TLR-Brendan
Spears enterprises has J&E pistons....
http://www.spearsenterprises.com/products.html
Just select SV1000/TL1000 from the drop down box...
2002 TL1000R, Air box mod, Pipercross air filter, Full yoshimura RS-3 stainless, Yoshimura box remap. R-1 throttle tube, Bitubo rear shock, Vandriver billet rear resovoir, tail risers, +1mm swingarm eccentrics, sprocket cover.
Future plans. 12.6:1 pistons, Web cams and gears, PCIII, Matchported and cleaned up heads, Vandriver triple clamps and clutch cover...
SOLD2004 GSX-R 1000, K&N air filter, Full yoshimura carbon TRS exhaust, -1 front sprocket. 148.3 horsepower and 73.14 ft-lbs torque.
2000 TL1000R track bike. K&N air cleaner, yoshimura RS-3 carbon full system with dual oxygen sensor bungs. Stock engine for now......
1997 TL1000S, soon to be TLR powered....
05-26-2008, 11:30 AM
Member #1353
Sportsbike: 1997 tl1000s
Riding Experience: 27 yrs
Life Wasted on TLZone: 5 Days and 8:05:19 Hours
pencon
I wonder if Would the 2mm overbore actually make a lot of difference over the standard bore hi compression pistons? How much is JE charging for the 4 pistons ? Is it twice the amount of the Spears 2 piston deal?
1997 TL1000s Original ECU With full race Carbon Yoshimuras (runs fine with Techlusion TFI) K&N filter , Airbox mod 121.8 rear wheel Hp on an Dynojet Dyno)Also race tech gold valveand springs ,topgun undertail, bitubo
05-26-2008, 12:25 PM
Member #5251
jagboy1
with the oversize pistons you get much better cylinder filling as the valves are ummasked...giving much better torque...it also raises compression just by fitting them..if you set the squish to 1.00mm you'll get very high comp...
the only downside is engine life.....  but that shouldn't really be an issue on 98 S and all tlr motors......
