Failed valve bucket tappets? - Page 5 - TLZone Forums
Old 07-17-2008, 01:54 AM   #41 (permalink)
I've got time to visit those forums now, so I'll have a read. But I'm sure Europe is well infront of API standards.
I don't think you're talking shit All oils do contain some but it's dropping. Now bikes have catalytic converters in them, they'll (manufacturers) be specifying the low ZDDP oils to be used in them. Not really applicable to the TL's, but when someone goes and buys the latest and greatest oil for their bike, they're probably better off sticking with the old tech stuff that was originally specified until it all disappears and the levels have to come down to the modern lower limits.
i.e Is Mobil going to keep marketing it's Mobil 1 4T racing that is to an old spec that can't be used in modern vehicles, or are they going to reblend it, get it approved and still sell it as Mobil 1 4T racing but drop the SH & SG and rate it as SL. So if you ever see Mobil 1 4T Racing meeting the SL / ILSAC GF-4 or whatever rating, you know it's under the 800ppm.
Old 07-18-2008, 05:55 PM   #42 (permalink)
Member #14979
Life Wasted on TLZone: 2:43:03 Hours
Nev1
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Nev1<!-- google_ad_section_end --> Steve is the prettiest admin
Whilst definately not a TL expert how does this scenario sound. The front cylinder runs a little leaner than the rear on TL. Your German guy goes fast for a long time with no speed limit,the front exh valves get hot and expand causing them to be slow returning up the guides.This starts a small amount of shim bucket float(for want of a better term) which causes the marking on shim buckets.Eventually the valve gets slow enough returning that the piston catches it with resulting explosion. I have seen this sort of marking/blow ups in engines I have built for speedway,they run low on methanol causing the same sort of failure,markings on the buckets even look the same.
Old 07-18-2008, 10:32 PM   #43 (permalink)
Life Wasted on TLZone: 3 Months, 2 Weeks, 1 Day and 19:54:09 Hours
not in a million years. ( IMHO ) :-)))
Old 07-19-2008, 12:45 AM   #44 (permalink)
rufer's Avatar
Member #1366
Riding Experience: Since 1999
Trader Rating: (33)
Life Wasted on TLZone: 3 Weeks, 6 Days and 5:39:35 Hours
rufer
Send a private message to <!-- google_ad_section_start(weight=ignore) -->rufer<!-- google_ad_section_end --> Steve is the prettiest admin
Possibly the little scrapes / markings on the right exhaust bucket are from the auto decomp??
But it is not always the right bucket that fails, so it can't be a problem of the auto decomp.
Old 07-19-2008, 03:11 AM   #45 (permalink)
Member #9953
Trader Rating: (4)
Life Wasted on TLZone: 2 Days and 21:27:54 Hours
benben
Send a private message to <!-- google_ad_section_start(weight=ignore) -->benben<!-- google_ad_section_end --> Steve is the prettiest admin
i have bought two tls (one bike complete and one motor) with this...
all was on front on exhaust ...and all was motor 2000...
Old 07-19-2008, 04:34 PM   #46 (permalink)
Member #14979
Nev1
buckets
When the exh valve gets hot from lean mix,it expands and tends to stick in the guide."not in a million years" may be a bit strong,quite a few engine failures in long high rpm situations are caused by this. I have tuned a fair few TL's that have been leaner on the front. Just putting forward a theory. I have seen RMZ250,R6,YFZ450 engines all with very similar wear patterns as in the pic fail for that reason. Have a nice day.
Old 07-19-2008, 05:56 PM   #47 (permalink)
you make a good point nev
but a tl front exhaust valve is submerged in oil
Old 07-20-2008, 11:30 AM   #48 (permalink)
cyclecamper's Avatar
Member #4340
Riding Experience: 40 years
Trader Rating: (27)
Life Wasted on TLZone: 2 Weeks, 0 Days and 4:26:06 Hours
cyclecamper
Send a private message to <!-- google_ad_section_start(weight=ignore) -->cyclecamper<!-- google_ad_section_end --> Steve is the prettiest admin
Sticky valves or spring float cause similar marks initially. Sticky valves sometimes initially give a very metallic noise, as they release as soon as the piston touches them, so at first there's no catastrophic failure, but ti doesn't sound like normal valvetrain noise. "Floating" valves from fatigued weak springs also can make a different noise initially, not as prominent a metallic knock. But a lot of people run more radical cams with stock springs without problems.
The fact only one guy is having such a rare failure recurrent in the same part in his engine indicates the real cause has probably not been addressed.
Old 07-20-2008, 12:21 PM   #49 (permalink)
rufer's Avatar
Member #1366
Trader Rating: (33)
rufer
I repeat, it's not just one isolated failure. More than 5 cases are known in Germany. Add the two from Benben.
Old 07-20-2008, 05:31 PM   #50 (permalink)
Member #4340
Trader Rating: (27)
cyclecamper
But fwer than that in the entire rest of the world? Perhaps it is related to the long-running on the autobahn, practically an endurance race?
