03-02-2008, 09:18 AM
Member #7709
Sportsbike: 2002 RC51 SP2 + 1998 TL1000R
Riding Experience: 34 years & counting
Life Wasted on TLZone: 1 Week, 3 Days and 7:57:26 Hours
GlennCauley
Exhaust bolts -- replace with studs/nuts?
Well, at some point in the near future I will be removing my TLR exhaust system to put on a new one. Having read all of the threads about snapping the header bolts, needless to say I'm a bit nervous. I am considering not even bothering to try loosening them, but rather just grinding the heads off, removing the remaining studs, and then doing the trick with the nut MIG welded onto the stud.
Here's my question...
Has anyone bothered to swap the stock M8 bolts with some studs and use flange nuts? If yes, what size/grade studs would you recommend? M8x40?
GDRacing Canada Motosports Team
www.gdracing-canada.com
TLotM July 2009
Yoshimura Open SuperSport engine | WitchHunter-tuned fuel injectors | TiForce full exhaust | Pipercross airfilter | NGK race plugs | Braunberger Autosports ECU | 1/5 throttle insert | Machined alu sprocket cover | Accelerated Technologies suspension | Hyperpro RSC steering damper | Renthal grips | TLS cable clutch w/ Pazzo lever | Brembo 19RCS radial brake MC w/ remote reservoir | HEL SS brake lines | BrakeTech AXIS ductile iron rotors | Pro-Bolt Ti disc bolts | Brembo/Ducati 4-pad calipers | Ferodo CP2.11 ceramic pads | Sharkskinz race bodywork + fender | Chelapa ram airtubes | Graves fairing stay | ETI Fuel Cel (Kevlar) | Stomp Grip tank traction pad | QB Carbon self-supporting tail section | RK 520GXW chain | TechG adj. rearsets | +1mm swingarm eccentrics | Penske/LE rear shock + linkage | Yoshimura/Marchesini cast magnesium 16.5" sprint wheels
03-02-2008, 10:23 AM
Member #4643
Sportsbike: TL1000S -97
Riding Experience: 8 years
Life Wasted on TLZone: 1 Month, 2 Weeks, 2 Days and 9:25:05 Hours
Octofinger
Should be scared of the Admins
I changed to stainless steel bolts which I lube with aluminium paste before mounting. No problems what so ever.
Done: -98 thermostat housing + bypass mod, Rifleman's 1/5'th, black screen, 17/40 sprockets, home made ATRE, Bitubo rear shock, Barnett clutch springs, split steering damper bracket, iridium plugs, D&D CF full system, +/- mod, Van fork sliders, Ziggy999 frame sliders, Pazzo shorty levers, US headlight, Busa front MC, Galfer SS lines, TLR 6-potters, airbox mod, PCII, Van sprocket cover, EBC front brake discs, TI rotor bolts, Van clear clutch cover, 6-spring clutch, Van clutch plate, Scotts oil filter, K&N.
Todo:CF undertail/gap mod, Discacciati discs, fork revalving, Stealth sprocket, full TLR M4 system, improve crank case breather, fix the broken faring and scratches ...
03-02-2008, 10:33 AM
Member #9366
Sportsbike: 02 TL1000R
Riding Experience: 3 years
Life Wasted on TLZone: 2 Weeks, 1 Day and 7:49:03 Hours
98ss
When I replaced a couple gears in the trans, one of the front bolts broke. I went up to the local carquest and got two studs, a couple stainless nuts and lockwashers, no problems yet. Although. when i drilled out the broken one I didn't quite get it as straight as i would like it. Thats because I also broke two easy outs, and had a lot of dremmel time, which reminds me I still have to dremmel and tap the rest of the way the rest of the third and final headache out. I broke the drillbit, spiraled up the flutes. It still works  I ended up putting some of the red lock tight on the threads which sort of work more like a lube than a locker. The studs are just like the studs you would find on your exhaust on your car. They are about 3/4 in to the non threaded part, and have about 1/4 inch of threads on the otherside. I really need to purchase a digital camera. If I had to take the bolts off again, I would have borrowed my buddies 1/4 in impact. That should be enough to pull them out with out breaking the heads off.
03-02-2008, 02:31 PM
Life Wasted on TLZone: 3 Months, 2 Weeks, 1 Day and 7:50:54 Hours
buy some stainless rod and cut to length and get some nuts made from brass hex bar. If you can get some bar then a machine shop can run a hole in it and you can tap it and cut it to length. It WILL NOT freeze onto stainless.
If there is interest in this as a mod I may be able to make it up as a kit.
03-02-2008, 05:39 PM
Life Wasted on TLZone: 3 Months, 1 Week, 6 Days and 6:50:38 Hours
1crock
has no witty saying for
The hot set up is a stainless stud with a brass nut. Worst case then is the brass threads strip when you try to remove them. and yes, they will torque up enough to seal the exhaust properly.
03-07-2008, 05:36 PM
Member #4340
Riding Experience: 40 years
Life Wasted on TLZone: 2 Weeks, 0 Days and 3:22:37 Hours
cyclecamper
Working on cars with studs on the exhaust manifold, I use a Snap-On nut splitter...never even try to unscrew one, I just split the nut in two.
Are stainless study easy to locate/buy? Are they in the McMaster-Carr catalog?
04-17-2008, 08:47 PM
Member #4340
cyclecamper
So, would this stud from McMater-Carr be the ones to get?
M8 X 1.25mm thread pitch
20mm long?
US $0.89 each
http://www.mcmaster.com/
93805A353
04-17-2008, 09:07 PM
if it is a stud ie just a length of thread it would need to be around 40mm long
I have made up a kit of stainless studs washers and brass nuts which are soon to be tested
I'll keep u innformed
04-17-2008, 09:38 PM
Que?
Member #4632
Life Wasted on TLZone: 2 Months, 0 Weeks, 3 Days and 1:39:10 Hours
Kamikuza
's real name is Kevin
I got my stud'n'brass nut kit
04-17-2008, 11:36 PM
Member #4340
cyclecamper
Good! That's what we all need!!!
