Swapping TLS Swingarm for TLR - TLZone Forums
Old 02-20-2008, 10:15 AM   #1 (permalink)
Member #12644
Life Wasted on TLZone: -
Bar.R
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Bar.R<!-- google_ad_section_end --> Steve is the prettiest admin
Cool Swapping TLS Swingarm for TLR
Trying to fit a TLR Swingarm to a TLS. Can you give me some information on how to go about it. I've got the TLR Swingarm and brackets for the conversion. Just need some more information on it and some pictures or diagrams.
Old 02-20-2008, 10:22 AM   #2 (permalink)
wsmc831's Avatar
Member #368
Sportsbike: 1997 TLS 2002 KTM 300MXC
Riding Experience: First bike, 1983
Life Wasted on TLZone: 1 Week, 0 Days and 1:34:03 Hours
wsmc831
Send a private message to <!-- google_ad_section_start(weight=ignore) -->wsmc831<!-- google_ad_section_end --> Steve is the prettiest admin
no sweat.
upper right on the bar there is a button called 'search'.
you should find all of the information you require in many previous threads.
1997 TLS - the subtle green one. Yosh full system, custom high mount. PcII, Sharkskinz TLR one piece race tail with anti draft undertail, Zero gravity double, Pro-tek rearsets, Hyperpro 916 style damper, corbin seat, Vortex triple clamp, airtech hugger, Penske/Lindeman rear shock and linkage, Lindeman superbike fork valve job, Marchesini 10 spoke Black, Gsxr 750 6 piston calipers and larger m/c, SS brake lines front and rear, Braking Wave Rotors front, milled gsxr rotor rear, billet preload adjusters, airbox reworked, Graves clutch cover, gsxr 1000 rear caliper, Stealth tri metal rear sprocket, Rk 520 chain, sprocket specialists front, KN air filter, Black/gold Pazzo levers, Vortex black gas cap, Ti bolts, ceramic coated headers, 05 1k clip ons, 4 lb battery.
January 2009, the end of an error.
Old 02-20-2008, 11:19 AM   #3 (permalink)
targetvs's Avatar
Member #10782
Pictures: 4
Life Wasted on TLZone: 12:35:05 Hours
targetvs
Send a private message to <!-- google_ad_section_start(weight=ignore) -->targetvs<!-- google_ad_section_end --> Steve is the prettiest admin
Depends on how you want to do it ! you can leave the shock mounts where they are and fit new shock to the middle (lot of work) or remove shock mounts from the s and fit them on the r.You will also need to grind a bit of the chassis off because it gets in the way.
Cooler than penguin pissQuicker than a greasy weasel
TLR swing arm,TLR exhaust,Yoshi stubby cans,GLPRO/ATRE,pazzo levers,gsxr faring,gsxr clocks,SH,999 headlamps,1/5 throttle,k&n,PCII with custom map(121bhp)ICS damper,5/8 mc,6 pot calipers,gillies rearsets,
http://i254.photobucket.com/albums/h...1062008083.jpg
http://i254.photobucket.com/albums/h...1062008084.jpg
http://www.2-d-xtreme.co.uk/
Old 02-20-2008, 01:59 PM   #4 (permalink)
Nothing to see here...move along
actls's Avatar
Member #968
Sportsbike: 01 TLS, 03 ZX9R
Riding Experience: more daily
Trader Rating: (31)
Life Wasted on TLZone: 1 Month, 0 Weeks, 2 Days and 3:42:36 Hours
actls
Send a private message to <!-- google_ad_section_start(weight=ignore) -->actls<!-- google_ad_section_end --> Steve is the prettiest admin
Use search...
This should help too.
http://home.comcast.net/~herzingkplus4/swing_swap.htm
People not to buy from
...ckfrdrice...TeamDutch (Dutch stole over $500 after selling me a damaged TLR engine. I returned the engine, he kept the money=thief)
People that I have purchased things from that were great to deal with
...Vandriver, Sam, Ziggy999, TLMike, djkoenig, N2Wheelies, Todd at CalSportbike, ET79, S Winglet, Rifleman...I know there's more...just can't remember everyone I've bought stuff from
Old 02-20-2008, 02:43 PM   #5 (permalink)
TLexup's Avatar
Member #1518
Sportsbike: TL1000S '98 - Yamaha XT660X'04
Riding Experience: 16 years riding
Trader Rating: (23)
Life Wasted on TLZone: 1 Week, 5 Days and 3:48:32 Hours
TLexup
Send a private message to <!-- google_ad_section_start(weight=ignore) -->TLexup<!-- google_ad_section_end --> Steve is the prettiest admin
I did this mod last winter.... You have to consider few things...
The mounting tabs for the rotary and SOAS are not on the same position. So you'll have to cut away the tabs and weld again on the proper place. I bought a swingarm wich has already mod for the TLS so in my case it was a straight forward conversion.
The TLS headers won't fit...so you have two posibilities.... Mod the TLS headers, make it longer on the rear header or fit a TLR headers (what I did)
If you fit a TLR headers two more problems appeart . The oil cooler doesn't fit cos the TLR fornt headpipe run the smae way as oil radiator. So you'll have to built a custom bracket and fit longer oil pipes.....Also the passenger pegs won't fit so you'll have to figure out some way to built pegs and cans brackets....
The rest is just a straight forward change..... Hera are some pics of my baby...
TLS from the other side of the Ocean
http://i29.photobucket.com/albums/c2...p/2f782806.jpg
Old 05-25-2008, 02:53 PM   #6 (permalink)
silson's Avatar
Member #12270
Sportsbike: nitrous tls
Riding Experience: 33 years
Life Wasted on TLZone: 14:51:46 Hours
silson
Send a private message to <!-- google_ad_section_start(weight=ignore) -->silson<!-- google_ad_section_end --> Steve is the prettiest admin
why dont you just have an engineering place brace your s swinger problem solved
Old 06-02-2008, 07:25 PM   #7 (permalink)
Troy's Avatar
Member #12174
Sportsbike: TLS/R 98,TOPSECRET track hack
Riding Experience: 25 years and counting...
Trader Rating: (10)
Life Wasted on TLZone: 1 Month, 2 Weeks, 0 Days and 7:59:50 Hours
Troy
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Troy<!-- google_ad_section_end --> Steve is the prettiest admin
nice mods you have...i did the swing mod too!
