Brakes (I suck a search) - TLZone Forums
Old 02-13-2008, 04:53 AM   #1 (permalink)
sector5's Avatar
Member #11012
Sportsbike: late 97TLS
Trader Rating: (12)
Life Wasted on TLZone: 2 Weeks, 2 Days and 1:46:58 Hours
sector5
Send a private message to <!-- google_ad_section_start(weight=ignore) -->sector5<!-- google_ad_section_end --> Steve is the prettiest admin
Question Brakes (I suck a search)
Have a set of 07 Busa callipers; 5/8 M/C braided lines with dot 4 fluid. When I installed them they where like a rock. The problem is when I leave the bike out in the sun or do not use it for along time the brakes become spongy. Will using a higher dot fluid help (what is the highest I can use for 07 Busa brakes) or is there any other was I can stop this form happening.
Old 02-13-2008, 05:39 AM   #2 (permalink)
TwinLoveRace's Avatar
Member #9992
Sportsbike: yellow and fast
Riding Experience: 12 years on and off
Life Wasted on TLZone: 1 Month, 1 Week, 6 Days and 5:16:30 Hours
TwinLoveRace Weigh ancor, hoist the sails. Crusin' for booty on watery trails!
Send a private message to <!-- google_ad_section_start(weight=ignore) -->TwinLoveRace<!-- google_ad_section_end --> Steve is the prettiest admin
Don't mix glycol- and silicone based brake fluids.
The dot4 you're running now is glycol based, 5.1 is too.
Dot5 is silicon based though.
Edit: I strongly doubt the dot4 in itself is causing the sponginess (is there such a word?). Using fresh brake fluid?
Old 02-13-2008, 06:51 AM   #3 (permalink)
Octofinger's Avatar
Member #4643
Sportsbike: TL1000S -97
Riding Experience: 8 years
Life Wasted on TLZone: 1 Month, 2 Weeks, 2 Days and 9:38:17 Hours
Octofinger Should be scared of the Admins
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Octofinger<!-- google_ad_section_end --> Steve is the prettiest admin
My guess is that they're poorly bled. The dot is not to blame.
Done: -98 thermostat housing + bypass mod, Rifleman's 1/5'th, black screen, 17/40 sprockets, home made ATRE, Bitubo rear shock, Barnett clutch springs, split steering damper bracket, iridium plugs, D&D CF full system, +/- mod, Van fork sliders, Ziggy999 frame sliders, Pazzo shorty levers, US headlight, Busa front MC, Galfer SS lines, TLR 6-potters, airbox mod, PCII, Van sprocket cover, EBC front brake discs, TI rotor bolts, Van clear clutch cover, 6-spring clutch, Van clutch plate, Scotts oil filter, K&N.
Todo:CF undertail/gap mod, Discacciati discs, fork revalving, Stealth sprocket, full TLR M4 system, improve crank case breather, fix the broken faring and scratches ...
Old 02-13-2008, 07:05 AM   #4 (permalink)
BikePilot's Avatar
Trader Rating: (18)
Life Wasted on TLZone: 3 Months, 3 Weeks, 4 Days and 8:53:52 Hours
The dot level is irrelevant to your issues, 3 or 4 or 5.1 are fine and all interchangeable. Sounds like its not properly bled, you have a fluid leak or a faulty master cylinder.
Old 12-10-2008, 08:29 PM   #5 (permalink)
TLPedro's Avatar
Member #10359
Riding Experience: kindergarten
Life Wasted on TLZone: 1 Week, 0 Days and 11:57:15 Hours
TLPedro
Send a private message to <!-- google_ad_section_start(weight=ignore) -->TLPedro<!-- google_ad_section_end --> Steve is the prettiest admin
I know this is from a few months ago, but I thought I'd mention that it's not a good idea to mix dot 5 with either 5.1 or 4. Apparently that is what turns the fluid into a jelly-like substance.
Old 12-14-2008, 08:14 PM   #6 (permalink)
Just tiny specs in the mirror
chucks_net's Avatar
Member #4998
Trader Rating: (12)
Life Wasted on TLZone: 2 Months, 1 Week, 4 Days and 17:54:27 Hours
chucks_net
Send a private message to <!-- google_ad_section_start(weight=ignore) -->chucks_net<!-- google_ad_section_end --> Steve is the prettiest admin
ok...
dot 4 absorbs moisture and lasts longer
dot 5 does NOT. dot 5 is race spec and should be bled after every use
mixed should be treated as dot 5 and bled after use
shit I thought I put this in my FAQ.... guess not
moisture/ condensation builds up in the caliper as they heat up from use. If there is an air pocket where condensations builds up or a pocket of water then that pocket will heat and expand locking the caliper. dot 4 absorbs the moisture and prevents this to some degree. dot 5 does not and the system can build water pockets with every use and can become dangerous over a period of time if not maintained
Old 12-15-2008, 02:14 AM   #7 (permalink)
Can you get them back rock solid just by pumping the lever a few times, Simon? If so, sounds like a bleeding issue.
Old 12-15-2008, 04:48 AM   #8 (permalink)
tl1000lasse's Avatar
Member #75
Sportsbike: TLS -00 the faster yellow and a DZR400 -00 motard + a raceproject TLS
Riding Experience: yes pleace
Trader Rating: (34)
Life Wasted on TLZone: 1 Month, 3 Weeks, 3 Days and 8:12:08 Hours
tl1000lasse wants to cuddle with crashtd
Send a private message to <!-- google_ad_section_start(weight=ignore) --><b>tl1000lasse</b><!-- google_ad_section_end --> Steve is the prettiest admin
try to bleed them again
TLZone Forums Staff - Resident Shrimp cheese lover
Hey I´m from SWEDEN so what did U expect
Tick Tack Tick Tack ....................
Old 12-15-2008, 09:42 AM   #9 (permalink)
sector5's Avatar
Member #11012
Trader Rating: (12)
sector5
therer all good now this was in feb
Busa 6 Pots GOLD, Busa GOLD Rear Calliper, Busa M/C 5/8, Braided Goodrich Lines all round, 520 17/42 Chain and Sprocket, Speedo Healer, Power Commander 3USB,Wideband Commander with LCD, Multi Hub, TLR Hydro Clutch with Busa Master, Air Box Mod, K&N High-Flow Filter, Led Turn and Tail Lights, Bitubo Rear Shock, Rifleman 1/5 Throttle Insert, Pazzo Levers, Scott’s Oil Filter, 5bolt VAN Billet Clutch Pressure Plate, VAN Billet Sprocket Cover, VAN Billet Starter Cover, VAN Billet Rear Brake Res and Spring, VAN Billet Clear Clutch Cover, Smart TRE, Blue LED Gauges, Fan Switch Mod, Clutch Switch Mod, Gap Mod. http://www.skinna.net/piss/suzuki.swf
Old 12-16-2008, 02:57 AM   #10 (permalink)
I didn't look at the original date
