Why do Suzuki say not to use valve grinding paste - TLZone Forums
Old 02-08-2008, 03:45 AM   #1 (permalink)
pad pad is offline
pad's Avatar
Member #3439
Sportsbike: TL1000R
Riding Experience: Since 10
Life Wasted on TLZone: 3 Weeks, 5 Days and 2:57:49 Hours
pad
Send a private message to <!-- google_ad_section_start(weight=ignore) -->pad<!-- google_ad_section_end --> Steve is the prettiest admin
Why do Suzuki say not to use valve grinding paste in the manual.
Am I old fashioned and missing something
Or is Suzuki just being strange.
Old 02-08-2008, 03:52 AM   #2 (permalink)
Sam Sam is offline
Trader Rating: (104)
I think the stock valves have a hardened surface that the paste will remove.
If the valves leak then chances are the coating is long gone or pitted, so no further harm to be done
Never stopped me doing it and my clearances remain stable for many miles
Old 02-08-2008, 03:58 AM   #3 (permalink)
tl1000lasse's Avatar
Member #75
Sportsbike: TLS -00 the faster yellow and a DZR400 -00 motard + a raceproject TLS
Riding Experience: yes pleace
Trader Rating: (34)
Life Wasted on TLZone: 1 Month, 3 Weeks, 3 Days and 8:12:08 Hours
tl1000lasse wants to cuddle with crashtd
Send a private message to <!-- google_ad_section_start(weight=ignore) --><b>tl1000lasse</b><!-- google_ad_section_end --> Steve is the prettiest admin
depends on what END you measure yours
TLZone Forums Staff - Resident Shrimp cheese lover
Hey I´m from SWEDEN so what did U expect
Tick Tack Tick Tack ....................
Old 02-11-2008, 10:34 AM   #4 (permalink)
6cuda6's Avatar
Member #10353
Sportsbike: 98 TL1000R
Riding Experience: to many
Trader Rating: (7)
Life Wasted on TLZone: 2 Days and 16:09:47 Hours
6cuda6
Send a private message to <!-- google_ad_section_start(weight=ignore) -->6cuda6<!-- google_ad_section_end --> Steve is the prettiest admin
The modern thinking is that you will actually HARM the surface the has just been made....so if you use a cutter [not a grinder] to do the seats the surface is perfect, by using a compound you grind in a rough surface therefore creating the potential for leaking.
I still like to lap the valves in by hand, this way i know they are matched/sealed.....
Old 08-19-2008, 01:24 AM   #5 (permalink)
Life Wasted on TLZone: 3 Months, 2 Weeks, 1 Day and 19:51:09 Hours
Got to throw my 2c in here.
If you cut the seat you create a flat surface at the angle of your cutter (45 or 46 degress) then you grind the valve to suit .
both should be perfectly (?) flat.
If you grind the valve onto the seat sure you ensure they are matched but you actually grind a small groove the size of the seat in the valve face.
When the valve and head are cold these align, when the engine is at running temp the valve grows slightly in size and then they don't.
If you take a worn valve and seat and grind the two together you get a round seat and a round groove in the valve and when that gets hot it will seat worse than when you started.
I have seen people use a dummy valve to "polish" the seats with paste. and then use fresh ground valves to match .
test your valve job three ways.( I use all three every time)
1. with a vacuum tester.
2. push on the stem and lift the valve slightly off its seat, push the valve sideways in each of four directions (front back and sideways) while lowering onto the seat. This is called sliding. the valve should slide equally back onto the seat in all directions. If the seat is not quite concentricc to the guide . it will slide further from one side than another and needs to be recut with a more rigid tool.
3 blue it. put a light coat of blue on the valve and almost wipe it off. drop the valve onto the seat a couple of times and pull the valve out . chech the valve it should be getting clean evenly all round . check the seat it should be blue evenly all round. wipe the valve clean and drop it in again. pull it and see how the blue has transferred back from the seat. same deal. if it is thin one side thick the other . cut the seats again .
Don't rotate the valve when bluing just drop it on the seat.
Old 08-19-2008, 04:01 PM   #6 (permalink)
pad pad is offline
pad's Avatar
Member #3439
Sportsbike: TL1000R
pad
Cool that makes sence
Old 08-20-2008, 01:19 AM   #7 (permalink)
bdejong's Avatar
Member #1612
Sportsbike: Suzuki TL1000R & TL1000S
Riding Experience: 21yr
Life Wasted on TLZone: 1 Week, 1 Day and 9:38:38 Hours
bdejong
Send a private message to <!-- google_ad_section_start(weight=ignore) -->bdejong<!-- google_ad_section_end --> Steve is the prettiest admin
It's also strange there are no replacement valve seats on the microfiche. Just get a new head is the message.
Had my valve seats freshened up (recut) once. There's not much room for that in the valve clearance range, I ended up with the thinnes shimms.
Dunno if there are aftermarket valve seats available.
Wooden shoes, Wooden head and wouldn't listen.
Oh yeah, and also a wooden bridge now. http://www.a7sneek.nl
Old 08-20-2008, 01:35 AM   #8 (permalink)
you need to take it to a specialist (auto engine reconditioner) . seats require specialised equipment to fit and are usually machined from a range of presized inserts which are very close in dimensions.
If a seat is worn out then removing it usually requires fitting a slightly larger item (OD). not something for the home mechanic.
Old 08-20-2008, 01:42 AM   #9 (permalink)
Sam Sam is offline
TL heads are available in abundance, no need to pay for specialist re-seating just yet
Old 08-20-2008, 02:11 AM   #10 (permalink)
brent_b's Avatar
Member #6819
Sportsbike: tls/r hybrid
Riding Experience: Since 2001
Life Wasted on TLZone: 3 Weeks, 0 Days and 5:18:26 Hours
brent_b
Send a private message to <!-- google_ad_section_start(weight=ignore) -->brent_b<!-- google_ad_section_end --> Steve is the prettiest admin
I just thought I would throw my two cents in. When I had a gsx250 (1994 model) I managed to get carbon stuck between the valves and seats after a slide down the road. Though the manual said not to use valve grinding paste I did, just enough to get rid of minor inperfections. These engines rev to about 13.5k and to this date the engine is still going well, with over 60,000km on it. I just did it because I had nothing to loose..
