01-26-2008, 02:33 PM
Member #1794
Riding Experience: 16 years
Life Wasted on TLZone: 0:02:12 Hours
Astroman
Camshaft problem...
am working on my 1998 tlr1000 and i had the cylinders off of it and am now putting it back together now i am stuck on cam timing the manual says to time it with marks parallel to the surface where the valve cover and cylinder head meet i took off the front valve cover and the timing is not even close to what the manual says is there anybody that can help me maybe if i sent pictures u could tell me if these cams are stock or not.
01-26-2008, 03:15 PM
Life Wasted on TLZone: 3 Months, 3 Weeks, 2 Days and 22:19:43 Hours
Just post a pic up here and someone will know for sure
Remember that cams spin at half the speed of the crank, so if things are all wonky you may just need to spin it around again.
01-26-2008, 03:21 PM
WSB Pit boss
Member #3905
Sportsbike: 97 tls trackbike
Riding Experience: years
Life Wasted on TLZone: 1 Week, 2 Days and 5:00:25 Hours
tornado
have you got the crank in the right position?
01-26-2008, 05:44 PM
Life Wasted on TLZone: 5 Months, 1 Week, 0 Days and 15:35:00 Hours
is TLess
How did you time it when you put the cams back in when you put the cylinders back on?  Did you just slap them in?
Front exhaust timed correctly.
The idler should be timed when fitting the chains too, using the mark on the head. (This picture is of the mark, not the teeth that should line up with it)
01-31-2008, 03:15 PM
Member #9326
Sportsbike: tl1000r
Riding Experience: 20yrs
Life Wasted on TLZone: 18:21:43 Hours
paddy
when i rebuild mine it never lined up and read a few treads its a common
fault but after getting it dame close then turning motor over seemed to
get better...
03-01-2008, 10:31 AM
Member #221
Life Wasted on TLZone: 3 Days and 19:22:39 Hours
doug
there is a specific procedure spelled out in the manual that you must follow to get the cams installed correctly. Use it.
03-02-2008, 05:38 AM
Member #1612
Sportsbike: Suzuki TL1000R & TL1000S
Riding Experience: 21yr
Life Wasted on TLZone: 1 Week, 1 Day and 7:13:08 Hours
bdejong
OOps...
Check the bearing/play on the gear beneath the camshafts withouth the camchain tensioned.
Wearing out these bearings for whatever reason causes the timing to be way off (and poor teeth contact).
Wooden shoes, Wooden head and wouldn't listen.
Oh yeah, and also a wooden bridge now. http://www.a7sneek.nl
03-07-2008, 06:31 PM
Member #4340
Riding Experience: 40 years
Life Wasted on TLZone: 1 Week, 6 Days and 21:46:32 Hours
cyclecamper
If it comes up a half-tooth off the crank is 360 degrees off (cam turns 1/2 speed). There's a lot of TLs driving around with cams improperly installed by incompetents 1/2 tooth off, and they still run just not as well.
03-08-2008, 01:27 AM
Member #1612
bdejong
03-08-2008, 01:19 PM
Member #4340
cyclecamper
The cams spin at half-crank speed. The cams have an odd number of teeth. So on exactly one rotation of the crank, the cam will turn half-way...where the cam had a tooth line up now the exact opposite side of the cam gear now lines up, and since there's an odd number of teeth that means the space between teeth lines up, so it's off a half-tooth.
One rotation a tooth will line up with an arbitrary point...next rotation of the crank to the exact same crank position the cam will be a half-tooth off...next rotation lines up...next rotation half-tooth off etc. etc.
Actually, you might be able to alter the timing on purpose via this method to get close then using offset keys to fine-tune it. A lot easier than re-pressing on cam gears or re-pressing the gear onto the sprocket shaft of the idler, and a lot cheaper than adjustable gears.
