stripped oil plug - TLZone Forums
Old 01-08-2008, 08:47 PM   #1 (permalink)
supertwintlr's Avatar
Member #12279
Sportsbike: 2001 TLR
Riding Experience: 4 years
Life Wasted on TLZone: 1 Week, 1 Day and 16:12:49 Hours
supertwintlr
Send a private message to <!-- google_ad_section_start(weight=ignore) -->supertwintlr<!-- google_ad_section_end --> Steve is the prettiest admin
stripped oil plug
when i bought my tlr 2 years ago i did the oil change and found that the plug had a heil a coil and the plug did not fit on after that. pissed me the fuck off. so i had to retap the plug with a bigger size bolt. it took care of the problem. so far.when this happened i found out that the tlr does not have an oil pan? is this true? any information would be appreciated. did anyone ever had this problem?
Old 01-08-2008, 10:26 PM   #2 (permalink)
Sam Sam is online now
Trader Rating: (104)
Life Wasted on TLZone: 2 Months, 4 Weeks, 1 Day and 9:35:40 Hours
When you say oil pan do you mean sump
The TLS and TLR both have one and hold about 3.5L
Old 01-09-2008, 12:19 AM   #3 (permalink)
richara3's Avatar
Member #6346
Sportsbike: 2000 tlr
Riding Experience: not enough
Life Wasted on TLZone: 1 Week, 0 Days and 19:06:32 Hours
richara3
Send a private message to <!-- google_ad_section_start(weight=ignore) -->richara3<!-- google_ad_section_end --> Steve is the prettiest admin
I think he is hoping that the drain plug is on a 'pan' that can be removed from the bike rather than just deing tapped in to one of the crankcase halves.
My name is Andy Piper cross filter, airbox mod,Blue Flame Titanium cans,PCII,TRE,Barnett clutch springs,Ohlins rear shock,revalved forks
Old 01-09-2008, 12:25 AM   #4 (permalink)
I see, no it doesn't have an oil pan then.
There are a few threads on here, here's one I posted pics of the helicoil kit on
clicky
Old 01-09-2008, 08:59 AM   #5 (permalink)
Member #12279
supertwintlr
exactly. like most inline fours you can remove the pan and replace it. but on here its engine casing halves. i got a price for it at a local dealer and the priced $1600.00 fuck that. and i didnt want to heil coil it because i some how dont trust them. thanks guys for the information.
Old 01-09-2008, 09:13 AM   #6 (permalink)
Helicoils are better than sound alloy threads if done right.
For example Marchesini fit helicoils as standard to their magnesium wheels for the disc bolt threads.
Old 01-09-2008, 09:37 AM   #7 (permalink)
i8marcus's Avatar
Member #9967
Sportsbike: 98 TLR & 02 YZ250
Riding Experience: 12+ Years
Life Wasted on TLZone: 2 Weeks, 3 Days and 11:42:23 Hours
i8marcus
Send a private message to <!-- google_ad_section_start(weight=ignore) -->i8marcus<!-- google_ad_section_end --> Steve is the prettiest admin
The reason most sumps end up stripped is it's made of aluminum and is much softer than steel drain plug plug.. A Heli-coil is steel and is a much better match to the drain plug if installed properly.
1998 TL1000R
Yoshimura RS-3 Exhaust, Forks reworked by Racetech, RaceTech valved Showa Shock/Eibach Superbike Spring, Ivan's TRE, Brembo HP Rotors, Brembo 19x18 Clutch M/C, Brembo 19x18 Brake M/C, EBC HH Pads, Galfer SS Brake & Clutch Lines, Hyperpro RSC Damper, CFM/Woodcraft Rearsets, CFM/Woodcraft Clip-on's, Stealth Tri Metal Sprocket 17/42, DID Chain, Michelin Pilot Powers, BMC Air Filter, Zero Gravity Windscreen, GSXR Race Tail.
"Brake later and open the throttle before normal" -Valentino Rossi
Old 01-18-2008, 03:18 PM   #8 (permalink)
Zefflyn's Avatar
Member #1286
Life Wasted on TLZone: 0:05:16 Hours
Zefflyn
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Zefflyn<!-- google_ad_section_end --> Steve is the prettiest admin
Yep, I stripped mine pretty quickly after I got my TL in '98 (got confused and kept pushing the wrench the wrong way). I put in a Helicoil, and its lasted nearly 10 years.
Old 01-18-2008, 05:50 PM   #9 (permalink)
Member #12279
supertwintlr
when i took the plug out the last time i changed the oil. the plug came out along with the coil. the coil looked like a spring when it came out. all stretched out. so like i sad in the beginning of this thread i retapped the threads with the next size up bolt and used a rubber washer. so far no problems. but now when i do my oil changes i cant use the crush washer. (too small now). so now i kinda wish i used a heli-coil....... oh well.......shit happens........ fuck it.
i still ride the shit outta my bike. draggin knees.
Old 01-18-2008, 07:27 PM   #10 (permalink)
Zefflyn's Avatar
Member #1286
Zefflyn
I bet the wrong size Helicoil was used. That sucks dude.
