TLR clutch on TLS - TLZone Forums
Old 11-23-2007, 01:20 PM   #1 (permalink)
sector5's Avatar
Member #11012
Sportsbike: late 97TLS
Trader Rating: (12)
Life Wasted on TLZone: 2 Weeks, 2 Days and 1:46:58 Hours
sector5
Send a private message to <!-- google_ad_section_start(weight=ignore) -->sector5<!-- google_ad_section_end --> Steve is the prettiest admin
Question TLR clutch on TLS
Hi all,
As my clutch leaver is flapping in the wind from all the wear and tear I got to thinking about if it would be worth putting a TLR system on my TLS. Would this be possible (would it be a big job) and would I get any gains form doing this(is it worth my time and cash)? As I read in a tread “I modded my TLR to cable clutch. It's piece of piss to do, better than hyd anyway!”
Old 11-23-2007, 03:30 PM   #2 (permalink)
Life Wasted on TLZone: 3 Months, 1 Week, 6 Days and 13:33:42 Hours
It's an easy conversion and much lower maintenance than the cable system. As to whether it's worth it, that all depends on what you like. I have no problem with the hydraulic clutch acuation. There are several here who have converted an S to hydraulic and others who have converted an R to cable. Personal preference.
Old 11-23-2007, 03:53 PM   #3 (permalink)
spoonmectr's Avatar
Member #9388
Sportsbike: 2003 TLR (Parting Out), 1998 TLS
Trader Rating: (26)
Life Wasted on TLZone: 1 Day and 21:58:44 Hours
spoonmectr
Send a private message to <!-- google_ad_section_start(weight=ignore) -->spoonmectr<!-- google_ad_section_end --> Steve is the prettiest admin
I love the feel of the cable vs the hydro.
Old 11-23-2007, 04:25 PM   #4 (permalink)
wsmc831's Avatar
Member #368
Sportsbike: 1997 TLS 2002 KTM 300MXC
Riding Experience: First bike, 1983
Life Wasted on TLZone: 1 Week, 0 Days and 1:34:03 Hours
wsmc831
Send a private message to <!-- google_ad_section_start(weight=ignore) -->wsmc831<!-- google_ad_section_end --> Steve is the prettiest admin
unless your clutch has over 50k miles on it, there's no reason the entire thing should be replaced.b
1997 TLS - the subtle green one. Yosh full system, custom high mount. PcII, Sharkskinz TLR one piece race tail with anti draft undertail, Zero gravity double, Pro-tek rearsets, Hyperpro 916 style damper, corbin seat, Vortex triple clamp, airtech hugger, Penske/Lindeman rear shock and linkage, Lindeman superbike fork valve job, Marchesini 10 spoke Black, Gsxr 750 6 piston calipers and larger m/c, SS brake lines front and rear, Braking Wave Rotors front, milled gsxr rotor rear, billet preload adjusters, airbox reworked, Graves clutch cover, gsxr 1000 rear caliper, Stealth tri metal rear sprocket, Rk 520 chain, sprocket specialists front, KN air filter, Black/gold Pazzo levers, Vortex black gas cap, Ti bolts, ceramic coated headers, 05 1k clip ons, 4 lb battery.
January 2009, the end of an error.
Old 11-23-2007, 04:44 PM   #5 (permalink)
BikePilot's Avatar
Trader Rating: (18)
Life Wasted on TLZone: 3 Months, 3 Weeks, 4 Days and 11:09:09 Hours
I think he's replacing the actuator mechanism not the actual clutch.
I swapped mine over for a TLR hydro setup and like it a lot, smoother, lighter feel and I don't have to replace cables and worm drives constantly. The cable setup might work ok on bikes that only see good weather, but they went to crap after a month or two for me.
Old 11-23-2007, 11:41 PM   #6 (permalink)
wreckah's Avatar
Member #144
Sportsbike: '09 KTM 990 SM-T
Riding Experience: 10 years
Trader Rating: (40)
Life Wasted on TLZone: 2 Weeks, 0 Days and 3:47:50 Hours
wreckah is quite fit, but he'll die
Send a private message to <!-- google_ad_section_start(weight=ignore) -->wreckah<!-- google_ad_section_end --> Steve is the prettiest admin
i did the same thing, went to TLR hydra clutch. I did however put a brembo radial master clutch cylinder on, and the feeling is just the best i've ever had on any bike. No more cable for me!
<a href=http://www.mojomoto.be/logo.gif target=_blank>http://www.mojomoto.be/logo.gif</a>
Old 11-24-2007, 01:31 AM   #7 (permalink)
Member #9920
Sportsbike: Yellow '00 Aprilia RSV Mille
Riding Experience: 10 years on and off
Trader Rating: (9)
Life Wasted on TLZone: -
Tantrum
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Tantrum<!-- google_ad_section_end --> Steve is the prettiest admin
Me Too!
Was pretty easy with a bit of dremmeling - just make sure you get the right parts
It's probably not much better than a perfectly set up cable clutch but it's much more consistent and low maintenance and for me I prefer the feel
Old 11-24-2007, 08:10 AM   #8 (permalink)
sector5's Avatar
Member #11012
Trader Rating: (12)
sector5
just make sure you get the right parts \\
So what will I need to get the complete system ? any extras
Old 11-24-2007, 10:10 AM   #9 (permalink)
Member #9920
Trader Rating: (9)
Tantrum
Well basically a TLR clutch master cylinder and hose, TLR clutch lever, TLR slave cylinder and TLR clutch pushrod. The TLR pushrod is longer than a TLS so if you have a '97 TLS with the five spring clutch get the TLR one. Also try and get the two bolts that hold the slave cylinder on as they are longer than the TLS ones.
Some people I believe used a TLR sprocket cover to save cutting the TLS one but I think you'll have problems with the holes lining up. I used a Dremel to cut mine down and I think it looks OK.
If you need any help just PM me and I'll send some pics of how I did mine and hopefully answer any questions you may have
Old 11-25-2007, 07:25 AM   #10 (permalink)
beurling's Avatar
Member #9961
Sportsbike: 1997/99 Hybrid TL 1000 SV Matthewman Special
Riding Experience: Learning the hard way
Life Wasted on TLZone: 1 Week, 0 Days and 2:18:45 Hours
beurling is desperate for spring to let out the beast!
Send a private message to <!-- google_ad_section_start(weight=ignore) -->beurling<!-- google_ad_section_end --> Steve is the prettiest admin
+1
i've seen his handywork and it aint half bad for doddering bloke in a cardi
oh and from what i can tell it does make a difference....i am thinking of going down that route later on if my op isnt a great success
by the way gray....i tried steve c's clutch which is the standard cable with the barnett springs...BUGGER ME it's heavy....standard springs all the way for me
Colonel Si
1997/99 TL 1000 SV Matthewman Special
off road awaiting strip and refurb
RIP John.. I ride for you mate
