How do i remove this bearing? - TLZone Forums
Old 11-14-2007, 09:33 PM   #1 (permalink)
zippytlsr's Avatar
Trader Rating: (21)
Liike the title says... how do i get it out. it's the bearing on the oil pump side of the crank case. It does not appear you can get behind the bugger to drive it out... getting it in would be easy enough. Do i need some special tool to pull it? Thanks for your help in advance.
Oh, an another thing... why is this gear BLACK? Does it mean it's been cryogenically treated for strength or something?
Oh and another question.. The grove in the Crank bearings.. in the TLS.. they appear to only go half way around the crank. In my TLR motor.. the grove goes ALL the way around the bearing surface. IS this Normall?
Old 11-15-2007, 03:31 AM   #2 (permalink)
pad pad is offline
pad's Avatar
Member #3439
Sportsbike: TL1000R
Riding Experience: Since 10
Life Wasted on TLZone: 3 Weeks, 5 Days and 2:36:17 Hours
pad
Send a private message to <!-- google_ad_section_start(weight=ignore) -->pad<!-- google_ad_section_end --> Steve is the prettiest admin
A slide hammer style bearing puller is the gadget you need
There are also many bush mechanics ways f getting the suckers out
Old 11-15-2007, 07:15 AM   #3 (permalink)
zippytlsr's Avatar
Trader Rating: (21)
I want to get the right tool for the job.. also gives me a reason to buy tools.
Old 11-15-2007, 08:05 AM   #4 (permalink)
Sam Sam is offline
Trader Rating: (104)
Life Wasted on TLZone: 2 Months, 4 Weeks, 1 Day and 14:54:18 Hours
Wash the crankcase in petrol or soapy water and dry thoroughly. Remove all the rubber seals etc
Stick in the oven at gas mark 8 for 15 mins
Remove from the oven and place on the kitchen floor with the bearing facing down (on a cloth so you don't burn the floor) the bearing will drop out, if not lightly tap the back of the case behind it with a wooden mallet.
You will find the bearing next to it will also fall out.
Same procedure for fitting new bearings except you put the bearings in the freezer for 10 mins and the case in the oven.
You can get blind bearing pullers but they are expensive and not really required on a TL motor if your oven works.
The shell groove is normal, the TLR and later TLS had a different oil configuration with the left side of the crank having an extra gallery to the big end from that shell and hence had a groove all the way around inside the shell.
Not sure why the gear is black, maybe a protest from some african imigrant worker in Japan (More likely a different hardening process)
God I sound sad, I'm not really a TL geek !
Old 11-15-2007, 09:09 AM   #5 (permalink)
Life Wasted on TLZone: 3 Months, 1 Week, 6 Days and 14:20:28 Hours
Yep a bit of heat and the aluminum case expands much faster than the steel bearing out they come. Going in it's not always even necessary to heat the case if the bearing is good and cold, but it never hurts either.
Old 11-15-2007, 05:09 PM   #6 (permalink)
Super Motarderator ........ Mad Modder .......
OldTLSDoug's Avatar
Member #1458
Sportsbike: 2008 Husqvarna SM610 2008 DR-Z70 2004 SV650S
Riding Experience: Since 1971
Trader Rating: (80)
Life Wasted on TLZone: 1 Month, 0 Weeks, 6 Days and 10:36:47 Hours
OldTLSDoug '08
Send a private message to <!-- google_ad_section_start(weight=ignore) --><b>OldTLSDoug</b><!-- google_ad_section_end --> Steve is the prettiest admin
Sam=Geek
Be Good, Wear Gear, Do Wheelies,
Doug "OldTLSDoug" Basinger
2008 DR-Z70
2008 SM 610
2004 SV650S
G-Town Squid Squad
Feb. 04 TLOTM
http://www.tlzone.net/forums/image.php?type=sigpic&userid=1458&dateline=1210726963
Old 11-15-2007, 08:32 PM   #7 (permalink)
zippytlsr's Avatar
Trader Rating: (21)
YOU ROCK SAM, ANd oldtlsdoug.. your both GEEKS when it comes to tl knowledge.. and right now... I am ever so thankfull. Next time i see you gents... the round is on ME! Thanks again for your help. I will be washing with soapy water and giving it a go.
By the way... how do i convert the Gas Mark 8, to say Degrees.. my wifes gas range only has a digital temp read out. Thanks again fellas.
Old 11-15-2007, 10:12 PM   #8 (permalink)
Sam Sam is offline
Gas Mark 8 just meant pretty hot
Make sure you wash all the oil out cos the wife will never forgive you when you stink the house out, and if washing in petrol certainly make sure it DRY aswell or she will divorce you after emerging from within the rubble
As for Doug, there was no need to agree
Old 11-16-2007, 03:53 AM   #9 (permalink)
pad pad is offline
pad's Avatar
Member #3439
Sportsbike: TL1000R
pad
I dident wont to mention the oven trick.
Last time I did it the mises freaked The house stunk
And next Sundays roast lunch tasted like shit
Old 11-16-2007, 04:19 AM   #10 (permalink)
Sam Sam is offline
LOL, like I say, the cleaner you can get the cases the better the food tastes later
Did I mention dishwashers are good for cleaning parts in......but thats another story
