TLS oil leak with pics - TLZone Forums
Old 09-16-2007, 04:04 PM   #1 (permalink)
TLSean's Avatar
Member #445
Sportsbike: 1998 TLS
Riding Experience: 8 years
Life Wasted on TLZone: 0:05:53 Hours
TLSean
Send a private message to <!-- google_ad_section_start(weight=ignore) -->TLSean<!-- google_ad_section_end --> Steve is the prettiest admin
I have had this leak for quite some time now and I would usually just park on some cardboard and call it good. It would only drop about 3-4 drops of oil and then it would be done. This week I decided to try and figure out where it was coming from and see if I could fix it. I have seen some other threads and the pics look similar (for a TLR) so I am hoping this is one of the common leaks people talk about. I cleaned the area completely with engine degreaser and rode around for about 10 mins. There seems to be one of two places it is coming from. I don't know what these areas are called, but either the steel rod that seems to be attached to the shifter (pic 1) or the top area of the cover in pic 2. The oil is all over so I can't find the exact area. Any help would be appreciated.
tls-oil-leak-pics-img_3129.jpg   tls-oil-leak-pics-img_3140.jpg   tls-oil-leak-pics-img_3143.jpg
'98 TLS
SE WI
Old 09-16-2007, 05:06 PM   #2 (permalink)
tlsracer1's Avatar
Member #350
Sportsbike: 97 TL1000S
Riding Experience: 23 years
Trader Rating: (10)
Pictures: 4
Life Wasted on TLZone: 1 Day and 3:53:27 Hours
tlsracer1
Send a private message to <!-- google_ad_section_start(weight=ignore) -->tlsracer1<!-- google_ad_section_end --> Steve is the prettiest admin
TlSean,it appears to be the clutch rod seal,our bikes are known to leak at the seal ,try cleaning the clutch rod and make sure it`s not nicked or has any rust on the rod that can damage the seal.
TLSRACER1 green 1997 TLS,dymag wheels,ohlins rear shock Vee-two ride height adjuster,remapped with a factory pro TEKA,race tech reworked forks,carbon fiber upper fairing ,carbon fiber front fender and rear hugger,brembo radial GP brake master cylinder,brembo billet two piece calipers,galfer brake lines,sharkskinz solo street tail section brake full floating ductile iron rear brake rotor,brake tech AXIS ductile iron front rotors with PFC pads front and ferodo pads in the rear,high speed tech rear tailight,full indigo high mount exhaust,hyperpro steering damper and more that I can`t recall
Old 09-16-2007, 07:04 PM   #3 (permalink)
TLSean's Avatar
Member #445
TLSean
I took the rod out, cleaned, it seemed pretty clean. How do I repair or fix that? I almost took some gasket sealer and coated the one end of it but thought better of that idea.
'98 TLS
SE WI
Old 09-16-2007, 10:06 PM   #4 (permalink)
MIKE FORD's Avatar
Member #6003
Sportsbike: 1998 TL1000S,NSR600 Race bike
Riding Experience: 26 years
Trader Rating: (27)
Life Wasted on TLZone: 1 Month, 3 Weeks, 0 Days and 22:50:50 Hours
MIKE FORD Slapper?
Send a private message to <!-- google_ad_section_start(weight=ignore) -->MIKE FORD<!-- google_ad_section_end --> Steve is the prettiest admin
You need to go but another seal,cheap as chips really,just be abit careful with it when installing..tap it in gently with a socket.
TLOTM March 07, "Say no to garage queens"
Old 09-17-2007, 04:27 AM   #5 (permalink)
TLSean's Avatar
Member #445
TLSean
How do I get the old one out? When I was checking for leaks before, I pulled the push rod out and lost a little bit of oil. Not sure how to grab onto that seal to pull it out?
'98 TLS
SE WI
Old 09-17-2007, 05:54 AM   #6 (permalink)
richara3's Avatar
Member #6346
Sportsbike: 2000 tlr
Riding Experience: not enough
Life Wasted on TLZone: 1 Week, 0 Days and 19:21:02 Hours
richara3
Send a private message to <!-- google_ad_section_start(weight=ignore) -->richara3<!-- google_ad_section_end --> Steve is the prettiest admin
take off the front sprocket... There is a metal plate that holds that seal in place. removing the sprocket allows access to the plate , remove the plate to access the seal. the seal is about twice the diameter of what you can see in those pics so dont try to pull it out just yet.....
good luck mate its an easy fix.
My name is Andy Piper cross filter, airbox mod,Blue Flame Titanium cans,PCII,TRE,Barnett clutch springs,Ohlins rear shock,revalved forks
Old 09-20-2007, 08:05 PM   #7 (permalink)
TLSean's Avatar
Member #445
TLSean
Finally found the diagrams I was looking for. Looks like I just remove two bolts and that plate will come off. Do I need to worry about spilling oil all over or is there nothing there?
'98 TLS
SE WI
Old 09-20-2007, 11:40 PM   #8 (permalink)
Carbon fiber, the chrome of sportbikes
bx-459's Avatar
Member #759
Sportsbike: 1999 TL1000S
Riding Experience: ...could always use more!
Trader Rating: (128)
Life Wasted on TLZone: 4 Days and 9:28:07 Hours
bx-459
Send a private message to <!-- google_ad_section_start(weight=ignore) -->bx-459<!-- google_ad_section_end --> Steve is the prettiest admin
...that side of the bike, I'd drain the oil - if its new oil then use a new/clean pan...if its old oil then its the perfect excuse for a change...
Silver, the fastest color!
On the inside - HID type bulbs, K&N filter, Iridium ix plugs, 16T front sprocket, Coerce billet sprocket cover, +5, +5, +5, Scorpio SE-i500 system from my GB and an ATRE.
On the outside - TLR forks, front carbon fender, 5/8th master brake cylinder, black SS brake lines (frnt & rear), braking waves all around with Ti bolts, Brembo gold front calipers & a busa gold rear caliper, flush mount signals (frnt & rear), ZG DB screen, black mirror stay, Helibars, black '97 top triple clamp, preload adjusters, Scott's magic gold box, Coerce real carbon dash surround, Irvine sliders, TL1000S (cutout) heel guards, carbon case cover - left side, clear billet clutch cover - right side, carbon gas cap, 1/2 tank bra, gel seat, Coerce full real carbon tail section, Coerce real carbon hump, Coerce real carbon tire hugger and undertail eliminator w/ LED's, Ohlins rear damper & LE 800# spring, Yoshimura RS-3 race Ti full system, Stealth 41T rear, and more to come...
Old 09-21-2007, 10:17 AM   #9 (permalink)
bdejong's Avatar
Member #1612
Sportsbike: Suzuki TL1000R & TL1000S
Riding Experience: 21yr
Life Wasted on TLZone: 1 Week, 3 Days and 6:50:54 Hours
bdejong
Send a private message to <!-- google_ad_section_start(weight=ignore) -->bdejong<!-- google_ad_section_end --> Steve is the prettiest admin
Do not tap it in too far. When you think it's about far enough and just one little bit will get it right, it will go too far in. Better use some kind of socket with a neck.
Wooden shoes, Wooden head and wouldn't listen.
Oh yeah, and also a wooden bridge now. http://www.a7sneek.nl
Old 09-24-2007, 08:58 PM   #10 (permalink)
TLSean's Avatar
Member #445
TLSean
Any other places for the leak?
Well, I replaced the seal, went out for a ride, came back and parked it and 10 minutes later had two separate spots of oil drops on the cardboard. Any other ideas for what would leak in that area? Or how to find where the leak is specifically coming from?
'98 TLS
SE WI
