Should I buy a new crankshaft or have it repaired?
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Should I buy a new crankshaft or have it repaired?
    Feb 2011
    Scottsdale, Arizona
    34
    I spun a rod bearing in my tl1000r and am trying to decide if I should have it repaired or to replace it. I have talked to a couple machine shops that say they can repair it, one shop says they will weld and turn it for a resonable price but a long turn around time. The other shop says they will grind it if I can find different bearings. I am wondering what thoughts are on this one? Anyone done either repair? Anyone know where to get the appropriate bearings?
    MotoGP Pit Boss gaztl1000r's Avatar
    Dec 2003
    nottingham UK
    11,031
    have a look at this thread
    it looks like this was milled down with larger bearings installed
    Surprise!
    i'd go for the other option if you can't find a good crank
    Who's fkin happy??.?? not me said snow white.WP rear damper gsxr k4/5 forks with gold calipers ,blackshadow discs,soon to be a hid/projector headlight,Harris adjustable rearsets,,pc2 k&n, zero limits seat hump,folding levers,mattyj clear clutch cover,rifleman 1/5th insert,more to come ..........
    AMA Pit Boss TLR Tim's Avatar
    Oct 2010
    Ten minutes from fatstu half an hour off sam
    4,873
    Ide pm Sam and buy a 1080 bigbore kit
    1999 TL1000R , Full Yoshimura RS3 Stainless , yoshi paddock stand bobbins , yoshi oil filler cap , gsxr k5 forks , gsxr k7 front fender ,black tokico calipers , pazzo copy levers ,K&N , Goodridge braided hoses , ebc discs ebc HH sintered pads , Renthal R4 SRS chain & sprocket , fan switch mod , gp mod, tre , tinted screen , Barnett clutch springs.
    pm me for TLZone stickers and beanie hats
    TLotM April 2012
    Dec 2003
    nottingham UK
    11,031
    nogood puttin a 1080 on a fekked crank though
    so send the 1080 to me and i'll fek my own crank
    lol
    12,690
    This was on the zone before the crash.
    its still on the planet here
    http://www.tlplanet.com/forums/showt...ghlight=cranks
    this motor is still running strong and has done track days too.
    Dec 2003
    nottingham UK
    11,031
    sounds like some top qc in the suzuki supply chain somewhere
    is it specific to any particular model year? or accross the production run?
    AMA Pit Boss doug's Avatar
    Mar 2003
    Vancouver Canada
    2,009
    would depend on how far undersized the crank has to go to clean it up if its more than a few thou its weld time or get a different crank. There is another thread with the cracked crank but it looks like it was ground way undersize and past the case hardening so it broke.
    12,690
    common mis-interpretation of function.
    if the crank loses hardness it will wear and appear to have "spun a bearing"
    broken cranks are most commonly caused by cracks.
    cracks are most commonly caused by the pounding of the loose rod and bearing assembly.
    really all reground cranks should be crack tested before re-use.
    equally they should be hardness tested and where the hard area has been removed they should be re-hardened.
    AMA Pit Boss Loki-TLR's Avatar
    May 2006
    Netherlands
    2,611
    I believe there where three things that led to the breaking of the crank on my S, not only the downsizing..
    JMCA 00139160
    Mar 2012
    Richards Bay South Africa
    19
    I recently had to fix the big ends. There was nothing left of the caps and the crank pin started to make grooves.
    I had the crankpin ground down less than 2 th, and they fitted BMW car bearings in the conrods after slightly taking away the inside of the conrods to fit the new bearings. The closest Suzuki bearing is 44.976 and the BMW bearing starts at 44.975.
    Its broken in and still rides smoothly
buy new crankshaft
can a broken car crank shaft be fix at engineering
can a broken crankshaft be repaired
can a crankshaft be fixed
can a crankshaft be repaired
can crankshaft be repaired
can crankshafts be repaired
cost of new crankshaft
cracked crankshaft
how many times can a crankshaft be repaired
new crankshaft cost
wer can i buy crank shaft around rustenburg
