01-31-2010, 03:40 PM
Member #6676
Sportsbike: '98 TLR
Riding Experience: twice a year
Life Wasted on TLZone: 2 Weeks, 6 Days and 6:43:52 Hours
Patch11
Patch
Crank Timing
Right, now that I am a master engine builder  (due to Sam's great instruction  ) and much hair pulling, knashing of teeth on my part
Anyone else notice/find that the No.2 cylinder is not actually 90* to the No.1 cylinder - mine is 87*
I assume that's why we can buy an ignition module to correct stuff like this  this is assuming I'm absolutely spot-on with my measuring
Just a thought on what the actual Master Engine Builders have found
The idea is not to buy cheap but to buy right!
01-31-2010, 05:52 PM
Never ride faster than your angel can fly.
Member #17601
Sportsbike: 97' TL1000s (v)
Riding Experience: Getting better every day.
Pictures: 6
Life Wasted on TLZone: 1 Month, 3 Weeks, 5 Days and 23:56:41 Hours
Chris
If it ain't broken don't
fix it, it cost too much.
Dude, if Sam says its good its good
I have no idea how you know its only 87deg, I'll find out some day I have no doubt. So until I join the league of Master Engine Builders like yourself  and  Sam obviously, I'll just say, well found out
How far have you got with the shelf anyway? I like how clean your engine is now  mine will never be that clean until it comes out  (hope that it never HAS to come out)
Bigrigdriver - got a new name
97 TLS - Rizla Colours - Blue powder coated wheels, - Reflective yellow rim tape - Lowers fitted - LSL top yoke and risers - Renthal bars - Braided lines twin front and single rear - Sprint steering damper - Screen cut down - mirrors removed - 6 pot Gold calipers - Blackshadow UK 'Blade' front Rotors - Blade reverse rear rotor - EBC HH pads - 200 rear tyre - Dunlop Qually II front and rear - red undertail - Blue LED Dash Lights - LED number plate light and indicators - flasher relay changed - K&N Air filter - K&N Chrome Oil Filter - Scorpion Race Cans Cut to 10 inch - +Mod - OEM Thermostat Mod - Riflemans 1/5th
Still to come
FP Racing Levers Gold with Blue adjusters - 6 Bolt clutch conversion - Barnett springs- Clear Clutch Cover - Gold Retainers - D&D Headers Ceramic coated - Headlight Loom Mod - Remote/Keyless Start - Vans Gold front and rear Reservoirs - D3 grips - Rear Brake return spring blue or gold ?? -
01-31-2010, 09:45 PM
Member #6676
Sportsbike: '98 TLR
Patch11
Patch
Sam was just schooling me on the timing etc - I haven't/didn't mention what I found.  Thought I'd make a thread instead, that everyone else can input and we can all learn.
It's not that hard to measure. Its a 90* V-Twin, which is as it says/means the cylinders move 90* to each other.
A pic would have been easier  but since I didn't
Easiest way is to give each cylinder their own pointer at true tdc, place no.1 cylinder at 0* and observe what number the no.2 cylinder is pointing at. Mine was at 87*.
Given it would be slightly out due to casting, machine tolerances etc but 3*  that's abit.
A good mate of mine has been schooled by the V8 lads (old skool  ) and they take that pretty seriously even going as far as re-machining cranks, cylinders etc to make it near perfect.
Will be interesting to see what the others more knowledgeable will have to say about it
An engine should always 'come out'  just ask Del
The shelf you ask? you will have to check the other thread ya cheeky monkey
01-31-2010, 10:48 PM
Life Wasted on TLZone: 3 Months, 2 Weeks, 2 Days and 0:51:32 Hours
its why you need to use a positive stop to judge TDC.
no way is the angle out.
02-01-2010, 01:26 AM
Member #10327
Sportsbike: tlr
Riding Experience: EXPERT DIRT/OFF ROAD
Life Wasted on TLZone: 3 Months, 3 Weeks, 5 Days and 20:36:22 Hours
tillerdog
tillertard
the rods are on the same jounal,it would be only off 90 if the cases were not machined 90 ,the v8 guys have many crank throes and are refering to cylinders being out of fase,this could be related to un-accurate crank build,basically it is impossible for our engines,unless suzuki feked up..machining a crankcase,not likely
once i thought i was wrong but i was just mistaken!!
02-01-2010, 07:11 PM
Member #221
Life Wasted on TLZone: 3 Days and 20:34:08 Hours
doug
Need to think about this a bit. Very curious thinking out loud here if the length of the rods, cylinder height would enter into this a bit, easy to be out 3 degrees though if you are not using a positive stop to determine tdc, ie using a dial indicator instead. I guess the other way to check it would be next time I have a pair of case just bolt them together and use a couple of striaght edges and a machinists angle finder to look at the included angle.
02-01-2010, 07:29 PM
so I just measured the cases and they are 90degrees.( the big 4 are not likely to stuff this up)
such misinformation can become problematic if not checked.
if you haven't experience in locating TDC then its very easy to get wrong.
02-07-2010, 09:48 AM
Member #221
doug
If you measured the cases and they are 90 degrees there is one more place to look at which is probably more important and that is the crank triggers on the flywheel for ignition timing. If you have a flywheel can you check the pickups to see if they are really at 90 degrees. If they are not it may explain why changing ignition timing doesnt seem to have as much effect as you think it would.
02-07-2010, 10:51 AM
You did not have your chain tensioner released.
Scorpio SE-i500 system,TLR MOTOR, pc2,yosh full system w/titanium cans ,(thanks 00tiller) k+N filter, UFO tail light kit-sweet! Corbin seat,Heli Bars, Throttle miester, six pot tlr caliper system, dble bubble screen,Galfer ss brake lines front&rear,tl tank protector,Bitubo rear shock-thanks Origin8tor!,clear clutch cover, CRG Levers,clear tailight lens-new paint, front end reworked by Aftershocks, fresh Powdercoated rims and front Wave rotors via TODD at Cal sportbike,as well as a SPEEDO HEALER from him,  ,fan mod-thanks et79,gpi gear indicator w/ATRE-thanks again cal sportbike. MY CUSTOM R/R WIRING HARNESS TO GET CHARGING SYSTEM UP TO PAR! check frequent mod section out!!
02-07-2010, 10:59 AM
Ok serious guess is that the Con rods were install facing apart and not facing together... according to the manual. There by allowing the crank to rotate the extra 3 degrees prior to the piston stopping at TDC. Yes?
hmmm, guess that's what doug said..
Reason: found the error of my ways..insert foot here.
