Crank Timing - Page 2 - TLZone Forums
Old 02-07-2010, 11:05 AM   #11 (permalink)
tillerdog's Avatar
Member #10327
Sportsbike: tlr
Riding Experience: EXPERT DIRT/OFF ROAD
Life Wasted on TLZone: 3 Months, 3 Weeks, 5 Days and 20:03:29 Hours
tillerdog tillertard
Send a private message to <!-- google_ad_section_start(weight=ignore) -->tillerdog<!-- google_ad_section_end --> Steve is the prettiest admin
Originally Posted by zippytlsr View Post
Ok serious guess is that the Con rods were install facing apart and not facing together... according to the manual. There by allowing the crank to rotate the extra 3 degrees prior to the piston stopping at TDC. Yes?
hmmm, guess that's what doug said..
you cant change the length of the rod by flipping it around
once i thought i was wrong but i was just mistaken!!
Old 02-07-2010, 01:17 PM   #12 (permalink)
Patch11's Avatar
Member #6676
Sportsbike: '98 TLR
Riding Experience: twice a year
Trader Rating: (8)
Life Wasted on TLZone: 2 Weeks, 6 Days and 6:43:52 Hours
Patch11 Patch
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Patch11<!-- google_ad_section_end --> Steve is the prettiest admin
that would only mean the oil gallery is facing the wrong way unless you are using sv rods
The idea is not to buy cheap but to buy right!
Old 02-07-2010, 01:19 PM   #13 (permalink)
Life Wasted on TLZone: 3 Months, 2 Weeks, 1 Day and 21:55:59 Hours
On a car piston with offset wrist pin holes it is possible to change the motion of the piston travel. by rotating the piston but not the actual position of TDC
Old 02-07-2010, 08:48 PM   #14 (permalink)
doug's Avatar
Member #221
Life Wasted on TLZone: 3 Days and 20:34:08 Hours
doug
Send a private message to <!-- google_ad_section_start(weight=ignore) -->doug<!-- google_ad_section_end --> Steve is the prettiest admin
Well I just measured a set of R cases and they are at 90 degrees and the crank center line is within 1 thou of the distance to the barrel matting surface. The flywheel ignition triggers are 90 degrees apart, I will go back to sleep now.
Old 02-07-2010, 09:09 PM   #15 (permalink)
zippytlsr's Avatar
Trader Rating: (21)
I was guessing that MAYBE the con rod big ends had been wallowed out and thus allowing the play to allow for "87" degrees. Just a guess.. now that DOUG has posted up his findings... my mind is smoking..
I know by turning the conrods around it SHOULDNT make a diff, just thinkin maybe the con rods were worn--badly. Like i say.. just a guess.
Carry on gentlemen....
crank, timing
