Originally Posted by tillerdog
thats the shite !! sam,have you ever tried it ? i think i know the answer "i dont need too" but i ask just the same
I've never tried loctite for gasket sealers other than the blue silicone I used to use. Just use loctite for threadlock and bearing fit etc
asuke07, no need to use gasket sealer on new gaskets except a little on the centre of the base gasket over the crankcase join line and on the generator & clutch covers where the rubber wiring block exits the cases.
Obviously the main use is the crankcase halves
I use a little on the waterpump mechanical seal before pressing into the cover and also under the M6 waterpump bolt washer.
