coolant in oil - Page 2 - TLZone Forums
Old 06-16-2009, 11:55 AM   #11 (permalink)
sasuke07's Avatar
Member #18028
Sportsbike: 2001 TL1000S
Riding Experience: 10 years
Life Wasted on TLZone: 1 Day and 4:20:43 Hours
sasuke07
Send a private message to <!-- google_ad_section_start(weight=ignore) -->sasuke07<!-- google_ad_section_end --> Steve is the prettiest admin
You are awsome thanks so much
Old 06-16-2009, 12:32 PM   #12 (permalink)
sasuke07's Avatar
Member #18028
sasuke07
I will let you know what i find
Old 06-16-2009, 05:04 PM   #13 (permalink)
Originally Posted by sasuke07 View Post
The bike did sit over the winter however there was coolant in the rad before it was stored It ran fine before I left it I have not taken anything off or opened any part of the engine. If it is the cor plugs what do I need to do
Was that coolant an antifreeze mix? Did it get cold enough over winter to freeze it? If it popped the welsh plugs, be thankkfull if that's the only thing done.
Here's one of TLDV8's pics. You can clearly see the one on the left:
Old 06-17-2009, 08:53 AM   #14 (permalink)
sasuke07's Avatar
Member #18028
sasuke07
I had engine ice mix in the rad before it sat it was stored in a non heated garage in central new jersey so im guessing it got cold enough to freeze what do you mean popped welsh plugs how do i tell if thats it
Old 06-17-2009, 09:09 AM   #15 (permalink)
Should be storing it with antifreeze / antiboil / corrosion inhibitor.
The welch / welsh / freeze / core plugs all the same thing, I put a picture up of them, Sam put a picture up of them and mentioned remove the cam covers and have a look!
Old 06-20-2009, 04:41 PM   #16 (permalink)
sasuke07's Avatar
Member #18028
sasuke07
okay so I pretty much think I figured out the problem the seals and gaskets to the water pump were shot and the oil seal was in pieces now i went onto Ronayers.com for the seals but see some of them have two different kinds for example on the ronayers.com on the 2001 TL1000s crankcase cover gasket (#3) on the price list it has 3-1 and 3-2 two different part numbers for the same part with two different prices which one do i choose whats the difference between the two can someone help me here is the list of seals I need that have two different part numbers for the one I need all of them are on Ronayers.com
Water Pump Fiche
8 (8-1/8-2)
Crankcase cover
8(8-1/8-2)
3(3-1/3-2)
6(6-1/6-2)
all input would be great thanks
Old 06-21-2009, 02:03 AM   #17 (permalink)
Sam Sam is offline
Trader Rating: (104)
Life Wasted on TLZone: 2 Months, 4 Weeks, 1 Day and 14:54:18 Hours
You will probably find whatever you order you will get the latest superceded part Number. All the gaskets are the same layout for all year S and R models.
The water pump and associated oil seal went through a few revisions aswell. The oil seal gained a flange to stop it getting pushed in too far if the retaining collar in the cover accidentally got broke out when removing the mechanical seal.
Be sure to clean the shaft and fit a new sealing washer under the impellor bolt. Don't get oil on the white ceramic seal and wrap a little of tape around the flats on the shaft before pushing the cover/oil seal over it to stop the sharp edges damaging the seal.
Good news overall, could of been much worse
Old 06-21-2009, 07:53 AM   #18 (permalink)
voodootwin's Avatar
Member #7129
Sportsbike: 2000 Suzuki TL1000R
Riding Experience: 30+ years
Life Wasted on TLZone: 1 Month, 0 Weeks, 6 Days and 11:18:27 Hours
voodootwin Sick of taxes
Send a private message to <!-- google_ad_section_start(weight=ignore) -->voodootwin<!-- google_ad_section_end --> Steve is the prettiest admin
Water Pump Fiche
8 (8-1/8-2)
Crankcase cover
8(8-1/8-2)
3(3-1/3-2)
6(6-1/6-2)
When I click on them I only see one part number for each.
Water Pump:http://fiche.ronayers.com/Index.cfm/...oup/WATER_PUMP
8 - http://www.ronayers.com/browseparts....e.ronayers.com
Crank Case:http://fiche.ronayers.com/Index.cfm/...RANKCASE_COVER
3 - http://www.ronayers.com/browseparts....e.ronayers.com
6 - http://www.ronayers.com/browseparts....e.ronayers.com
"Got torque?"
An optimist believes we live in the best of times
-a pessimist fears this is true
John
Poor Al Gore. Global warming completely debunked via the very Internet you invented. OH. OH the irony. The iro---ny. -Jon Stewart
Old 06-22-2009, 06:00 AM   #19 (permalink)
sasuke07's Avatar
Member #18028
sasuke07
No I mean on the list of parts under the fiche
it gives the list of all parts and you click a part number to see the price if you go to the link above you will see for example #8 in the fiche is the water pump bolt and when you go down to the list below it it will have 8-1 and 8-2 to choose from thats where Im getting confused
Old 06-22-2009, 07:16 AM   #20 (permalink)
voodootwin's Avatar
Member #7129
Interesting.....I don't know how you arrived at that link, but if you click on the link for the water pump fiche in my previous post it only shows one part number.
"Got torque?"
John
coolant
