No Fuel spitting from injectors - TLZone Forums
Old 05-20-2009, 10:21 PM   #1 (permalink)
redhottl's Avatar
Member #5692
Sportsbike: You wouldnt understand...
Riding Experience: 8
Life Wasted on TLZone: 3 Days and 8:14:13 Hours
redhottl
Send a private message to <!-- google_ad_section_start(weight=ignore) -->redhottl<!-- google_ad_section_end --> Steve is the prettiest admin
Has anyone ever had a problem with this? The fuel pump is primed and you can hear the buzz sound but bike wont start. I twist the throttle and check out the throttle boddies and no fuel is spitting out the injectors...
RIP to the hottest TLR
scorpioncustomsusa.com
ride4haiti.com
vipalliance.me
djgqla.com
burnfilms.com
Old 05-21-2009, 02:24 AM   #2 (permalink)
TLDV8's Avatar
Member #1349
Sportsbike: DR650 ADV/SM
Trader Rating: (38)
Pictures: 220
Life Wasted on TLZone: 3 Weeks, 4 Days and 18:57:48 Hours
TLDV8
Send a private message to <!-- google_ad_section_start(weight=ignore) -->TLDV8<!-- google_ad_section_end --> Steve is the prettiest admin
To see fuel you would have to be thumbing the starter button.
The ECU will not do anything unless the engine is rotating to get sensor activation.
2008 DR650 Ohlins Shock - Race Tech .46 Springs/Emulators/20W oil - GSXR Muffler & FMF PowerBomb header - Mikuni TM 40 Pumper - Twin Air Airfilter - Pro taper Contour Bars - Acerbis Handguards - Volar Foot pegs - Zumo 550 - Moto-Sport Racks - Andy Strapz Panniers - Wolfman Expedition Rear Bag - Utah Sport Bash Plate - Screens for Bikes Screen - Corbin Seat - Safari 32 litre Fuel Tank - AMP Case Savers - Dunlop D606's.
Road trim.. Procycle SM wheels - Michelin Pilot Road 2's - EBC Rotors - Braided Brake Lines
http://i30.photobucket.com/albums/c345/manurewa/YL8Small-2.jpg
Old 05-21-2009, 02:32 AM   #3 (permalink)
TLDV8's Avatar
Member #1349
Trader Rating: (38)
Pictures: 220
TLDV8
If you are cranking the engine,you could check the fuel rail pressure via the fitting in the hose end with a gauge (L/H side on the TLR i think)
If everything was ok before it might not be mechanical but a sensor overide or wire off somewhere.
Old 05-21-2009, 02:50 AM   #4 (permalink)
Super Motarderator ........ Mad Modder .......
OldTLSDoug's Avatar
Member #1458
Sportsbike: 2008 Husqvarna SM610 2008 DR-Z70 2004 SV650S
Riding Experience: Since 1971
Trader Rating: (80)
Life Wasted on TLZone: 1 Month, 0 Weeks, 6 Days and 10:37:41 Hours
OldTLSDoug '08
Send a private message to <!-- google_ad_section_start(weight=ignore) --><b>OldTLSDoug</b><!-- google_ad_section_end --> Steve is the prettiest admin
The TOS affects fuel delivery and the pump can still run.
Be Good, Wear Gear, Do Wheelies,
Doug "OldTLSDoug" Basinger
2008 DR-Z70
2008 SM 610
2004 SV650S
G-Town Squid Squad
Feb. 04 TLOTM
http://www.tlzone.net/forums/image.php?type=sigpic&userid=1458&dateline=1210726963
Old 05-21-2009, 05:25 AM   #5 (permalink)
Or crank it for a good 6 seconds or more and check for an error code.
If the crank or cam sensors are playing up, the fault isn't registered until the ECU gets the start signal and realieses they're missing. It takes a bit for those faults to register.
Also the if the ECU isn't getting the start signal when you press the button it wont be expecting to need the fuel pump again and wont turn it on, but if you push start it, the engine will turn over fast enough for the ECU to realise it's running and needs the fuel pump. A simple check for that is to listen for the pump coming back on when you hit the button.
Also like Doug said, the tip over sensor will allow the pump to prime, but wont allow the engine to run. It takes several seconds for the TOS to register as a fault.
Do you have any error codes coming up?
Old 05-22-2009, 01:47 AM   #6 (permalink)
Sold, to the man in the slippers
bentlr666's Avatar
Member #6383
Sportsbike: TLR 1000 (of course).
Pictures: 20
Life Wasted on TLZone: 3 Weeks, 4 Days and 9:08:20 Hours
bentlr666
Send a private message to <!-- google_ad_section_start(weight=ignore) -->bentlr666<!-- google_ad_section_end --> Steve is the prettiest admin
Is there fuel in the tank??
TLoM here i come.... ok it may take me a while but i'm working on it
Work in Progress.....
Vandriver's Clear Clutch Cover, Pressure Plate, Sprocket cover, Billet Rear Brake Reservoir and Brake Return Spring, Yoshi RS3 SS Bolt on's, +2 Driven Rear Sprocket, Eaglescreens Blue Windlip Screen, Revolution Rotors, Axle Flip Mod, MattTheHat TRE, Bitubo Rear Shock, Rifleman's 1/5th Insert, FP Racing Lever's, Charge Mod, Carrozeria V-Track Wheels, Tribo Seat Cover
Waiting to be installed...
Gap Mod Tray, TopGun Undertail
Old 05-23-2009, 05:31 PM   #7 (permalink)
redhottl's Avatar
Member #5692
redhottl
Fuel in the tank. Error codes are C41 and C 42. I took out the ignition and out a push button in its replacement. That might have something to do with it. Does anyone know will the TLR run on a toggle on off switch insted of a key ignition?
ride4haiti.com
vipalliance.me
djgqla.com
burnfilms.com
Old 05-23-2009, 05:45 PM   #8 (permalink)
Life Wasted on TLZone: 3 Months, 2 Weeks, 1 Day and 18:33:22 Hours
you can't just remove the ignition switch there is a resistor in it that the ecu uses. you have to fudge the replacement to think its still there.
Old 05-23-2009, 05:56 PM   #9 (permalink)
It wont start with a C42 error, and that's because it's missing the correct signal from the ignition switch.
fuel, injectors, spitting
