re-build help - TLZone Forums
Old 04-21-2009, 11:48 AM   #1 (permalink)
Member #16992
Sportsbike: 2 GSXR750's, 1 street and 1 track, TLR1000, 6 or 7 dirt bikes
Riding Experience: 35 yrs.
Life Wasted on TLZone: 4:55:24 Hours
ezzywave
Send a private message to <!-- google_ad_section_start(weight=ignore) -->ezzywave<!-- google_ad_section_end --> Steve is the prettiest admin
re-build help
I'm in the process of rebuilding a '99 TLR. It was given to me as a basket case.
I'm ready to assemble the starter clutch and related components. However I seem to be missing a bushing. According to the manual there is one bushing on each end of the "Starter Limiting Assembly" (the assembly with 4 thin gears on it). I only have one. I would just buy a new one but the parts diagrams (online) don't show it. They only show 1 bushing, on the outside, that goes into the case cover.
Does anyone know if the inner and outer bushings are identical?
Old 04-21-2009, 12:50 PM   #2 (permalink)
TLR-Billbo's Avatar
Member #1415
Trader Rating: (48)
TLR-Billbo is dreading winter coming
according to the schematic they're the same bushing
*2005 SXR 800*Skat 9/17 140-75 SS Impeller*Blowsion mat kit*Blowsion billet bilge switch*Rule 500GPH bilge*R&D bilge bracket*R&D billet angled reed spacers*V-Force Delta 2 Carbon reeds*R&D exhaust sleeve*Wamiltons scupper*Wamiltons stubby pump cone*fuel fill and pickup mod*-4" hull*-1.5" pole*R&D stealth intake grate*-4" ride plate*ODI grips*R&D Pro-lock filters*Jetworks mixture screws*Blowsion billet engine mount keepers*R&D 6º ignition adv kit*Billet driveshaft coupler*dual-cooling*Wiseco 80.96mm factory Kawi race pistons (true 800cc)*UMI Billet throttle lever*
MySpace and Facebook
Old 04-21-2009, 01:24 PM   #3 (permalink)
Sam Sam is online now
Trader Rating: (103)
Life Wasted on TLZone: 2 Months, 4 Weeks, 0 Days and 19:24:04 Hours
One normally gets left in the cover, check it's not there or in the bottom of one of the box's
But yes they are the same
Old 04-22-2009, 09:13 AM   #4 (permalink)
Member #16992
ezzywave
OK, I figured it out. The schematic I was looking at only showed 1 bushing, but paging down to the parts list tells you that 2 are required. Hey, I never claimed to be a rocket scientist.
Note to self- Righty tighty, Lefty loosey.
While were at it, does anyone have the recipe for toast?
Old 04-22-2009, 10:07 AM   #5 (permalink)
It's on the same page as Milk
Old 04-22-2009, 12:53 PM   #6 (permalink)
Life Wasted on TLZone: 3 Months, 2 Weeks, 0 Days and 22:25:02 Hours
Toast :
take 2 slices of bread from packet.
rummage thru workshop and locate heat gun last used to strip paint off handrailings.
suspend bread from vice using welding wire.
direct heat gun at bread till desired colour is achieved.
experiment with heat settings and distance from bread.
remember that due to the bread drying thru the reverse side of the bread will toast much faster.
Milk:
find field full of cows.
take appropriate bucket.
remember to warm hands first!!!
don't try to milk the bull!!
Old 04-22-2009, 01:03 PM   #7 (permalink)
TLR-Billbo's Avatar
Member #1415
Trader Rating: (48)
Old 04-22-2009, 01:10 PM   #8 (permalink)
_FLY_'s Avatar
Member #4625
Sportsbike: Bumble Bee tl1000r
Riding Experience: 32 years and counting
Life Wasted on TLZone: 1 Week, 1 Day and 7:14:02 Hours
_FLY_ Viagra--not yet!!!
Send a private message to <!-- google_ad_section_start(weight=ignore) -->_FLY_<!-- google_ad_section_end --> Steve is the prettiest admin
if you cant find a cow then a goat will do n if ya use cold hands it will
on ya
Old 04-22-2009, 01:12 PM   #9 (permalink)
TLR-Billbo's Avatar
Member #1415
Trader Rating: (48)
and you know this how?
re-build
