Another Engine Bites the Dust....... - Page 3 - TLZone Forums
Old 03-19-2009, 06:19 PM   #21 (permalink)
jagboy1's Avatar
Member #5251
Sportsbike: tl1000sv,cb1100r
Riding Experience: definately
Trader Rating: (13)
Life Wasted on TLZone: 3 Weeks, 2 Days and 7:43:51 Hours
jagboy1
Send a private message to <!-- google_ad_section_start(weight=ignore) -->jagboy1<!-- google_ad_section_end --> Steve is the prettiest admin
u love it.
Old 03-19-2009, 10:14 PM   #22 (permalink)
TomM's Avatar
Member #6594
Life Wasted on TLZone: 4 Weeks, 1 Day and 3:25:49 Hours
TomM
Send a private message to <!-- google_ad_section_start(weight=ignore) -->TomM<!-- google_ad_section_end --> Steve is the prettiest admin
so is this something we should check for every 10,000 or so km? i know its a pain to split the cases and look inside but it's better than it going mid corner and leaving the little one without a dad...
im seing a lot of it lately on the Zone and its unnerving.
Old 03-19-2009, 11:20 PM   #23 (permalink)
Sam Sam is offline
Trader Rating: (104)
Originally Posted by jagboy1 View Post
u love it.
True, I do, the wifes hates the smell of petrol drifting around the house and me smelling of it though, a bit unerving when the compressor kicks in
The thought does cross my mind occasionally especially at some of the fast tracks on long corners
A major explosion and locking the rear is pretty rare, just watch out for the tell tale signs of jumping out of gear or false neutrals or a regular basis. Nick did complain of the gearbox getting awkward and a slight vibration before it went.
Old 03-20-2009, 12:04 AM   #24 (permalink)
IOWNATL1000S's Avatar
Member #11669
Sportsbike: TL1000s, GSX750W
Riding Experience: Since 1995
Life Wasted on TLZone: 4 Days and 8:02:50 Hours
IOWNATL1000S ROBORE PRUDENTIA PRAESTAT
Send a private message to <!-- google_ad_section_start(weight=ignore) -->IOWNATL1000S<!-- google_ad_section_end --> Steve is the prettiest admin
Originally Posted by Sam View Post
Then I've got another one to do
you havent forgoten about me have you due to my similar problem i still need those bits
Full respray in two pack black gloss, with a holographic rainbow metalflake layed over the top, Stainless heelplates, Stainless Chainguard, Micron Carbon Cans, New sprockets and D.I.D. chain, Carbon effect Air intakes, Carbon Effect Dash surround, Metzeler Racetec Tyres (120 front and 180 rear),Led rear light with built in LED indicators, LED numberplate light, Modified undertray and Numberplate bracket, Iridium front indicators, Iridium Double bubble screen, Seat hump, Goodridge Stainless Brake lines, Sintered Pads front and rear, Manual fan switch mod, Polished Rims (edges only)
Old 03-20-2009, 01:43 AM   #25 (permalink)
Sam Sam is offline
Nope, your gearbox was washed, checked and rebuilt with new circlips last night
Old 03-25-2009, 02:26 AM   #26 (permalink)
Sam Sam is offline
Nick dropped round the replacement gearbox bearings last night, so I got the cases back together
We had a chat and it never started jumping out of gear he said, just started vibrating and what felt like a missfire, so it sounds like it lost a tooth or two first which quickly started knocking off the rest until the gear broke a chunk off which took the selector fork with it.
Also noticed that the two little bearing retaining plates for the selector drum were bent allowing the whole selector drum to move side ways by a few mm which wouldn't have helped it keep the gears off each other when not selected
Old 03-25-2009, 02:59 AM   #27 (permalink)
133bhp's Avatar
Member #4408
Life Wasted on TLZone: 3 Weeks, 2 Days and 12:39:50 Hours
133bhp
Send a private message to <!-- google_ad_section_start(weight=ignore) -->133bhp<!-- google_ad_section_end --> Steve is the prettiest admin
I hear they've started up production of TL engines again, some where in York apparently!
On my 97, I replaced the shift rod with a solid one once I realised they changed them, can only assume they flex slightly?
Also the tubular shift rod tends to cut a groove in the cases. I just caught mine and fitted out with a washer/solid rod to take up slack and prevent binding/wear,
regards checking? For a lot of track use - I've "thought" about having another bottom end all ready to go, swap out once a year is dead easy with just barrles etc, check the other at your lesuire then. .. I bought a giixer instead!
I had no drama on my gearbox issues either. I came into the pits from donnignton and from a high speed road run, down to first gear, both times, simply could not select neutral properly, boith times dogs/forks had gone. Hardly makes sesnse that under no load they go, unless dogs just holding in under load then finally dogs round so bad give up the ghost and then wont re-engage?
Main sponsor.-
ebaY
Old 03-25-2009, 04:33 AM   #28 (permalink)
TLR-Billbo's Avatar
Member #1415
Trader Rating: (48)
TLR-Billbo is dreading winter coming
thats crazy! glad to hear he kept it up
*2005 SXR 800*Skat 9/17 140-75 SS Impeller*Blowsion mat kit*Blowsion billet bilge switch*Rule 500GPH bilge*R&D bilge bracket*R&D billet angled reed spacers*V-Force Delta 2 Carbon reeds*R&D exhaust sleeve*Wamiltons scupper*Wamiltons stubby pump cone*fuel fill and pickup mod*-4" hull*-1.5" pole*R&D stealth intake grate*-4" ride plate*ODI grips*R&D Pro-lock filters*Jetworks mixture screws*Blowsion billet engine mount keepers*R&D 6º ignition adv kit*Billet driveshaft coupler*dual-cooling*Wiseco 80.96mm factory Kawi race pistons (true 800cc)*UMI Billet throttle lever*
MySpace and Facebook
Old 03-25-2009, 05:35 AM   #29 (permalink)
BikePilot's Avatar
Trader Rating: (18)
Life Wasted on TLZone: 3 Months, 3 Weeks, 4 Days and 21:32:46 Hours
That is a mess! Was the gearbox doing anything funny before the failure? Poping out of gear or otherwise acting like it had rounded off dogs?
Old 03-25-2009, 06:37 AM   #30 (permalink)
Sam Sam is offline
3 posts up
bites, dust......., engine
