Weird problem - TLZone Forums
Old 02-26-2009, 08:11 AM   #1 (permalink)
Member #16924
Life Wasted on TLZone: 1:04:59 Hours
sradder
Send a private message to <!-- google_ad_section_start(weight=ignore) -->sradder<!-- google_ad_section_end --> Steve is the prettiest admin
Weird problem
Well, fisrt hi to all people!
My TLS starts cold OK and smoothly idles about 1200 rpm. After a while when engine temperature rises, it dies. Adjusting idle to, say 2200 rpm, it runs but everything under 2000 rpm is imbossible. Makes city cruising imbossible. I have checked (almost) all. Gas pressure is about 3 bar, no leaks or what so ewer. Borrowed ECU, no help.
ARGGHH!!!
Old 02-26-2009, 08:15 AM   #2 (permalink)
BikePilot's Avatar
Trader Rating: (18)
Life Wasted on TLZone: 3 Months, 3 Weeks, 3 Days and 14:04:14 Hours
Sounds like it may be way rich or lean, probably lean. When cold it is on the super-rich warm-up map, then once warm it moves off that map and onto the normal (much leaner map). The TLS, esp the '97 with its huge ports needs quite a bit of fuel to stay running at low rpms.
If its been remapped that could be the source of the problems, if not, start with the usual TPS, TB sync and valve lash check.
Old 02-26-2009, 09:20 AM   #3 (permalink)
rufer's Avatar
Member #1366
Riding Experience: Since 1999
Trader Rating: (33)
Life Wasted on TLZone: 3 Weeks, 6 Days and 0:55:43 Hours
rufer
Send a private message to <!-- google_ad_section_start(weight=ignore) -->rufer<!-- google_ad_section_end --> Steve is the prettiest admin
I'd also check the temp sensor and thermostat. Does it keep temp?
Other thing that come to mind are vacuum leaks that only develop if the engine is up on temp.
Old 03-10-2009, 06:57 AM   #4 (permalink)
Member #16924
sradder
Another day in garage. I have service manual and had checked almost everything again. All vacuum lines are just they should be, sensors work properly and give reasonable reading. TPS is OK, synchorosation (eh?) does not affect much. Lambda shows between 0,9 - 1,1.
Here gomes weirdo: Idles again ~2000rpm and after adjusting idle about 1/8 round, it dies. I took hose off Intake Pressure Sensor, name might be wrong but you clever people know what I mean. Now idles 1200rpm. So I made 4,5 source for current and measured sensor. All reading are like service manual. Voltage output increase and decrease just it should. Hose back and idles again 2000 rpm. Huh?
Old 03-10-2009, 03:52 PM   #5 (permalink)
TomM's Avatar
Member #6594
Life Wasted on TLZone: 4 Weeks, 0 Days and 20:59:37 Hours
TomM
Send a private message to <!-- google_ad_section_start(weight=ignore) -->TomM<!-- google_ad_section_end --> Steve is the prettiest admin
i has something a bit similar not long ago. never really got to the bottom of it but im keeping an eye on your thread
Bike keeps dying?
Old 03-10-2009, 04:30 PM   #6 (permalink)
cowelly's Avatar
Member #16287
Sportsbike: tls, triumph t150, gas gas200,fantic trials
Riding Experience: 30yrs
Pictures: 4
Life Wasted on TLZone: 3 Days and 9:36:27 Hours
cowelly
Send a private message to <!-- google_ad_section_start(weight=ignore) -->cowelly<!-- google_ad_section_end --> Steve is the prettiest admin
might be worth taking the airbox off and checking that all the vacum hoses into the carbs and airbox are in correctly, any one of em out or incorrect will cause rough running
good luck with it
just because youre paranoid doesn't meen they're not after you
Old 03-10-2009, 05:28 PM   #7 (permalink)
Roadrage's Avatar
Member #6671
Sportsbike: 1999 TL1000R and 2003 CBR600RR
Riding Experience: 5 years, 100,000 miles
Life Wasted on TLZone: 0:31:11 Hours
Roadrage
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Roadrage<!-- google_ad_section_end --> Steve is the prettiest admin
off with the air box, get a spray bottle filled with soapy water, start engine, spray around base of throttle bodies and intake manifold. The throttle body boots are probably loosened up. You might want to reset the high and low idle when you do this, blow out your air filter, lube the throttle body slides/butterfly, lube the linkages. NOTE: DO NOT TRY ADJUSTING THE THROTTLE BODY LINKAGES UNLESS YOU KNOW WHAT YOUR DOING!!!
problem, weird
