Whats the trick? - TLZone Forums
Old 02-07-2009, 11:11 AM   #1 (permalink)
NineDV's Avatar
Member #4329
Location: The Amish Flat Lands; (Outside of Lancaster), Pa
Sportsbike: 99 TLR
Riding Experience: Mostly Steph and Nikki...
Pictures: 7
Life Wasted on TLZone: 3 Weeks, 1 Day and 13:42:58 Hours
NineDV
Send a private message to <!-- google_ad_section_start(weight=ignore) -->NineDV<!-- google_ad_section_end --> Steve is the prettiest admin
Whats the trick?
I still have oil spewing out of the water pump weep hole. I ordered up the new seal and installed it when it arrived. I made sure to tape over the sharp edges of the water pump shaft and greased everything up. Is there some trick to this that i am missing? Could something else me amiss?
This isnt a slow leak more like a drip under throttle....
Jesse
Have Real Estate Questions?Ask Me.
Specializing in First Time Buyers.
Already Done: Devil cans w/ baffels remved, PCII, fan switch,PAR removed, hacked airbox, ZG drk smk DB, short stalks all around, custom rear signal brackets, TRE, air box mod, +mod, home made clear clutch cover, Bitubo, Custom Gap Tray, Traxxion reworked forks and custom pavement paintjob
Old 02-07-2009, 11:39 AM   #2 (permalink)
BikePilot's Avatar
Trader Rating: (18)
Life Wasted on TLZone: 3 Months, 3 Weeks, 4 Days and 13:03:46 Hours
No trick that I know of. I've replaced it twice when replacing the mechanical seal and haven't head a leak Be careful with the grease, the mechanical seal does not like grease (though the wp seal shouldn't mind a dab of grease).
Old 02-07-2009, 02:49 PM   #3 (permalink)
N2wheelies's Avatar
Member #301
Sportsbike: 97 tls, 05 sv650, 97wr250
Riding Experience: 24 yrs
Trader Rating: (105)
Life Wasted on TLZone: 3 Weeks, 0 Days and 7:13:03 Hours
N2wheelies
Send a private message to <!-- google_ad_section_start(weight=ignore) --><b>N2wheelies</b><!-- google_ad_section_end --> Steve is the prettiest admin
polish that shaft ive had to replace mine
twice in 65K miles. second time i had to leave the
oil seal about 2 mm from fully seated to miss
the groove worn in the impeller shaft.
new motor got a brand new shaft from the
get go since i was already in there. manual
describes everything pretty well including
keeping the water seal clean and free of oil
TLZone Forums Staff - Resident Doctor of Drag
Old 02-07-2009, 02:51 PM   #4 (permalink)
BikePilot's Avatar
Trader Rating: (18)
Come to think of it I polished up my shaft as well. 60k and still going though it is a little pitted.
Old 02-07-2009, 02:52 PM   #5 (permalink)
133bhp's Avatar
Member #4408
133bhp
Send a private message to <!-- google_ad_section_start(weight=ignore) -->133bhp<!-- google_ad_section_end --> Steve is the prettiest admin
when you pressed the mech seal, you have to be careful not to damage face behind it?
seem to remeber you have to use abit of sealant on the oil seal?
Has the tiny spring in the seal been disloged?
Main sponsor.-
ebaY
Old 02-07-2009, 03:36 PM   #6 (permalink)
NineDV's Avatar
Member #4329
Sportsbike: 99 TLR
Pictures: 7
NineDV
The spring that wraps around the seal is still intact. i dont recall sealant when installing the gasket (pulling out the ol shop manual now).
I did ding the thin metal that is sandwiched between the two seals on the case (on the flat non-sealing-or so i think surface) would that be causing the seal not to sit perfectly flat? The seal seated just fine.
Edit: Guess this will give me something to do tonight. Back in i go i guess.
Old 02-07-2009, 06:14 PM   #7 (permalink)
NineDV's Avatar
Member #4329
Sportsbike: 99 TLR
Pictures: 7
NineDV
Turns out that the seal was twisted and not seated when i pulled the thing apart. sorted that then reassembled everything after polishing up the shaft. still leaks but much slower. Guess the next step is to try pulling the seal back as per N2 suggestion.
Old 02-07-2009, 06:22 PM   #8 (permalink)
BikePilot's Avatar
Trader Rating: (18)
And by now the oil seal may be nicked a little. They often don't like being R&R'd more than once I hear (I've not actually tried it as I've always gone in with a new one). good luck
Old 02-07-2009, 06:47 PM   #9 (permalink)
zippytlsr's Avatar
Trader Rating: (21)
YEP... like they said... pollish up your shaft buddy. I had mine all corroded and pitted... got it clean with my dremel and polished it up with my dremel again and used a new seal. Zero problems.
Old 02-08-2009, 02:15 AM   #10 (permalink)
133bhp's Avatar
Member #4408
133bhp
guess I'm lucky, my old 50k 97 has always been pitting and corrosion free. But Although I reused mine 6/7 times before it finally weeped. (Just used platic bag over shaft) it. I'd toss the seal and start again, probabaly nicked/deformed as been said
regards sealant? - beleive the oil seal retainer comes with a band of blue sealer? or was that the mech seal, or both cant remeber now
Main sponsor.-
ebaY
trick?
