01-08-2009, 11:54 AM
Member #5251
Sportsbike: tl1000sv,cb1100r
Riding Experience: definately
Life Wasted on TLZone: 3 Weeks, 2 Days and 4:42:56 Hours
jagboy1
shot/bead blast or sonic
hey peeps......what would you say is the best way to get a set of carbs clean.....not just the insides...as that's fairly easy.....i want he outsides to look like new....or very nearly....
01-08-2009, 12:06 PM
Life Wasted on TLZone: 2 Months, 4 Weeks, 1 Day and 14:41:58 Hours
water/vapour blasting or what ever they call it
I'm sure they do one with just water and not with the glass beads used in vapour blasting, I've seen the stall at our local auto jumble but can't remember the name
I have an 1 gallon ultrasonic cleaner and it's not that good unless you have access to a proper commercial one.
01-08-2009, 12:26 PM
Member #5251
jagboy1
i've heard the vapour blast thing is good...will see if i can find one local....
01-08-2009, 12:46 PM
Life Wasted on TLZone: 3 Months, 2 Weeks, 1 Day and 13:34:50 Hours
soda blasting is supposed to be the best of all. if ur blasting.
I used to bead blast but you have to be so careful to clean them out
Engine reconditioners have a product called carbosol which I believe has been superceded by a better safer product and will bring them out like new just from dipping, not good if there is a high maggy content inthe aluminium tho, and you have to remove all the plastic bits first.
interesting thing about the ultrasonic sam I would have thought that the ultimate.
I really want to get a wet bead blaster one day.
01-08-2009, 01:32 PM
Member #5251
jagboy1
done c little digging on the net . . it looks like the ultrasonic could be the way if it's industrial . as sam said . . :-)
01-08-2009, 01:45 PM
01-08-2009, 02:20 PM
Life Wasted on TLZone: 3 Months, 1 Week, 6 Days and 13:33:42 Hours
1crock
has no witty saying for
You've got to remember, all that makes an old carb look bad is not dirt. There's corrosion involved and aluminum oxide is pretty tough stuff to remove. Blasting or some chemical process is the way to go.
01-08-2009, 03:12 PM
you're not going to believe this but I have cleaned some small carbi bits in the microwave.................
I put them in a micro dish and covered them with soapy water (totally covered) and ran it for 10 min intervals. the water protects the micro from the effects of the metal supposedly, it sort of worked, good but not brilliant.
I've also dried timber for turning in there too but that was another story and almost involved the fire brigade,
Is it any wonder I'm still single
01-08-2009, 05:09 PM
Member #2388
Sportsbike: Green '97 TL1000S; '73 Goose; 1999 TTR250 (street legal)
Riding Experience: 21 years - street
Life Wasted on TLZone: 2 Weeks, 6 Days and 6:59:01 Hours
pmmonster
Originally Posted by The Ring-In
...Is it any wonder I'm still single
Now go try to boil an egg in your microwave. And when you're done with that try a bar of soap (you'll need to do something to clean the microwave after the egg experiment  )
Pete - Ann Arbor
Penske, 6 piston brakes, fighter, airbox, breather mod...
01-09-2009, 10:29 AM
Member #9870
Sportsbike: 2001 TL1000R
Pictures: 15
Life Wasted on TLZone: 1 Week, 4 Days and 12:29:04 Hours
keeena
Ultrasonic cleaning. TLR-Billbo had his done this way & had some pix before/after...looked brand new after it was done. He could probably give you more specifics.
