Runs for 2 seconds then nothing. - TLZone Forums
Old 01-05-2009, 01:32 PM   #1 (permalink)
NineDV's Avatar
Member #4329
Location: The Amish Flat Lands; (Outside of Lancaster), Pa
Sportsbike: 99 TLR
Riding Experience: Mostly Steph and Nikki...
Pictures: 7
Life Wasted on TLZone: 3 Weeks, 1 Day and 3:01:59 Hours
NineDV
Send a private message to <!-- google_ad_section_start(weight=ignore) -->NineDV<!-- google_ad_section_end --> Steve is the prettiest admin
http://www.youtube.com/watch?v=eOm7azf65yc
Im thinking it might be something in the vacum lines but i havent had a chance to look and see if i assembled them correctly. Needless to say i left the shop rather frustrated last night thinking "damn so close to being back together." Would something crossed or missing in the line setup cause this?
Thanks
Jesse
Have Real Estate Questions?Ask Me.
Specializing in First Time Buyers.
Already Done: Devil cans w/ baffels remved, PCII, fan switch,PAR removed, hacked airbox, ZG drk smk DB, short stalks all around, custom rear signal brackets, TRE, air box mod, +mod, home made clear clutch cover, Bitubo, Custom Gap Tray, Traxxion reworked forks and custom pavement paintjob
Old 01-05-2009, 01:50 PM   #2 (permalink)
Life Wasted on TLZone: 3 Months, 2 Weeks, 0 Days and 9:19:24 Hours
if it runs for 2 sec I would say that the fuel pump is not receiving the signal to run.
when you turn on the ignition the fuel pump primes and this stored fuel will run the bike for a coulpe of seconds
the computer then gets a signal from the motor to tell it the bike is running and starts the fuel pump.
this is so the pump doesn't spray fuel if the bike crashes and stops running etc.
Old 01-05-2009, 01:54 PM   #3 (permalink)
NineDV's Avatar
Member #4329
Sportsbike: 99 TLR
Pictures: 7
NineDV
would this be every time you thumb the start button? This happens without turning on/off the ignition.
Old 01-05-2009, 02:31 PM   #4 (permalink)
Its possible.
if you can jumper some power to the fuel pump so it runs continually you could prove it and then find the source . probably a loose plug.
I had a similar prob on a car recently. jumpered the pump , ran fine, turned out the pump relay had dirty connections
Old 01-05-2009, 02:40 PM   #5 (permalink)
pad pad is offline
pad's Avatar
Member #3439
Sportsbike: TL1000R
Riding Experience: Since 10
Life Wasted on TLZone: 3 Weeks, 5 Days and 0:37:15 Hours
pad
Send a private message to <!-- google_ad_section_start(weight=ignore) -->pad<!-- google_ad_section_end --> Steve is the prettiest admin
Give the tipover sensor a shake and make shore it is facing the right way
Are you using an OEM ignition switch .?
Old 01-05-2009, 02:55 PM   #6 (permalink)
WSB Pit boss
Gigas's Avatar
Member #2708
Sportsbike: TLS 1000, Husqy 610 SM, Enfield Bullet 500
Riding Experience: Always learning...
Life Wasted on TLZone: 1 Year, 5 Months, 1 Week, 4 Days and 19:44:37 Hours
Gigas misses his lost innocence...
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Gigas<!-- google_ad_section_end --> Steve is the prettiest admin
Any error codes? This would be helpful
Old 01-05-2009, 03:18 PM   #7 (permalink)
NineDV's Avatar
Member #4329
Sportsbike: 99 TLR
Pictures: 7
NineDV
No FI light that i recall. Two hrs left of work then i can get back at it. Kinda excited to get the thing back together. I am a good bit useless at work today.
Old 01-05-2009, 03:29 PM   #8 (permalink)
WSB Pit boss
Gigas's Avatar
Member #2708
An error code won't necessarily give you FI light.
Bridge the plug in the tail and run the bike a few seconds and see what's coming up on the display....
Old 01-05-2009, 08:31 PM   #9 (permalink)
NineDV's Avatar
Member #4329
Sportsbike: 99 TLR
Pictures: 7
NineDV
up date
So far here is what i have done:
TOS is filled so that is very unlikely the problem.
Fuel pump relay was bridged so the pump continuously ran (i also threw the c41 when rigged) but that did not solve the problem.
I double checked my vacuum lines and they are all good.
No codes in dealer mode when cranked.
So i am thinking in another direction; could i have messed up the timing so bad that it wouldnt stay running? This will probably be my next investigation.
Here is what happens when i turn the bike over.. it will fire up and runs with an odd tone when it starts to die like it did in the previous clip i touch the starter button and it keeps on running. It would run indefinitely with the starter button always running. Its back firing mucho amounts and the exhaust is grayish in color. While fun to watch the huge flames popping out the pipes its not so good on the hearing.
Before i tear off valve covers again, does that sound like the way i should go? I have a video clip on my camera phone but will have to wait till i get to work to upload it.
I just want to ride some wheelies! (and yes it is cold as crap here now)
Old 01-05-2009, 08:39 PM   #10 (permalink)
if it continues to run with the starter button puched then there is a power delivery problem . there is only power with the starter running. check the wiring around the starter relay. make sure the power feed to the harness is connected on the battery side and not on the starter side.
nothing., runs, seconds
