What are the differences between the TLS and TLR engines? - TLZone Forums
Old 01-02-2009, 10:28 PM   #1 (permalink)
inderocker's Avatar
Member #16497
Sportsbike: 2005 Honda VTR1000F
Riding Experience: 16 years
Life Wasted on TLZone: 1:12:08 Hours
inderocker
Send a private message to <!-- google_ad_section_start(weight=ignore) -->inderocker<!-- google_ad_section_end --> Steve is the prettiest admin
I just bought a 2001 TL1000R with a blown engine for $1600. I've seen a few TLR engines on eBay, but there is a TLS motor on there for a much better price. What would I have to carry over from the blown TLR engine to turn TLS engine into a TLR engine? Is it even possible?
Old 01-02-2009, 11:39 PM   #2 (permalink)
Life Wasted on TLZone: 3 Months, 2 Weeks, 0 Days and 10:58:38 Hours
before 10.97 the S differs from the later S
Some 98 S clutches were still 5 spring
The R has 6 spring clutch
the tranny and clutch is basically the same from 1998 on.
the crank rods and pistons and cams are different from s to r
the oil cooler arrangement is different on the R , It has a heat exchanger.
The power output is similar on both but has different delivery characteristics. the R is a bit more aggressive.
Old 01-02-2009, 11:40 PM   #3 (permalink)
cyclecamper has an R motor for sale
about $500 will pry it loose!
Old 01-03-2009, 03:57 AM   #4 (permalink)
rufer's Avatar
Member #1366
Riding Experience: Since 1999
Trader Rating: (33)
Life Wasted on TLZone: 3 Weeks, 5 Days and 23:12:33 Hours
rufer
Send a private message to <!-- google_ad_section_start(weight=ignore) -->rufer<!-- google_ad_section_end --> Steve is the prettiest admin
There are a lot of threads about this, use search and have a look in the frequent mods forum.
@Stu: The gearbox and clutch were only upgraded for the 1999 TLS models. I have two 1998 TLS and they both have the old clutch and gearbox (with the exception of the big output shaft bearing).
differences, engines?
