Big end Rod Bearings - TLZone Forums
Old 12-06-2008, 12:43 PM   #1 (permalink)
Gibby936's Avatar
Member #14076
Sportsbike: 01' TL1000S 95' CBR F3
Riding Experience: 10 years on and off road
Life Wasted on TLZone: 5 Days and 21:16:02 Hours
Gibby936
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Gibby936<!-- google_ad_section_end --> Steve is the prettiest admin
What is the difference between the F00 and the F11?
Full M4 exhaust, pc3, speedo healer, 17/41, gold x-ring chain, solo cowl, corbin seat, gpr, flapper unhooked, TRE, db speed screen, launch strap, integrated signals, clear clutch cover, billet pressure plate, barnett springs, braided lines, under tail, tank bra, k & n, crash bars, grab bar
Old 12-06-2008, 01:14 PM   #2 (permalink)
Sam Sam is online now
Trader Rating: (103)
Life Wasted on TLZone: 2 Months, 4 Weeks, 0 Days and 17:29:46 Hours
F11 have probably superceded the F00
F11's are the ones you want.
Out of interest try and choose the F00's and see if it comes up with a superceded part number, ie F11
Old 12-06-2008, 01:43 PM   #3 (permalink)
Gibby936's Avatar
Member #14076
Gibby936
Doesn't say anthing about be replaced by or anything. I was actually hoping that they were oversized but after a search that isn't possible. I now have 2 junk cranks after buying a "guaranteed to be tight and good bottom end" off of ebay. Maybe he will take it back but I doubt it. I need a crank if any1 has one pm me with price.
Old 12-06-2008, 02:37 PM   #4 (permalink)
Life Wasted on TLZone: 3 Months, 2 Weeks, 0 Days and 22:25:02 Hours
bearings from a honda car b1800 motor can be used to reclaim the cranks. buy them from an auto supply store not honda to get the best range of sizes. an auto crank grinder will understand what you are wanting .
Old 12-06-2008, 03:53 PM   #5 (permalink)
Life Wasted on TLZone: 5 Months, 1 Week, 1 Day and 2:50:41 Hours
Originally Posted by Gibby936 View Post
I was actually hoping that they were oversized.
Undersized. When you have your crank ground you use undersized bearings. The crank pin is smaller than stock.
Old 12-06-2008, 07:07 PM   #6 (permalink)
Gibby936's Avatar
Member #14076
Gibby936
Yea that too, you know what I ment...
Old 12-06-2008, 07:13 PM   #7 (permalink)
Gibby936's Avatar
Member #14076
Gibby936
Can you give me more info? I did a search and found nothing?
Old 12-06-2008, 07:17 PM   #8 (permalink)
do as I suggested. take your crank and rods to an auto crank grinder. he will have listings of the bearings. he will grind your crank to the next suitable size. and probably supply the bearings.
bearing shells require a small touch with a file but he will know what to do.
Old 12-07-2008, 10:40 AM   #9 (permalink)
cyclecamper's Avatar
Member #4340
Riding Experience: 40 years
Trader Rating: (27)
Life Wasted on TLZone: 2 Weeks, 0 Days and 1:53:24 Hours
cyclecamper
Send a private message to <!-- google_ad_section_start(weight=ignore) -->cyclecamper<!-- google_ad_section_end --> Steve is the prettiest admin
I have two extra cranks that aren't in engines. One is nearly perfect, and stamped to indicate all journals are the larger size; it can still be micro-polished to any of the 3 stock Suzuki sizes of shells. The other has one bad half-journal from a typical front-cylinder big-end failure (Chuck's bike). I was asking Kendall $270 plus shipping for both, with almost all the value going to the good one. The "bad" cranks have demand and value for Kendall Berg's strokers or other stroker applications (Falicon will stroke it for you), Falicon (or other shop) stock-stroke grind/weld-up/regrind procedure, or like Stu said regrind smaller journal for customized thicker-size smaller-ID bearing shells originally meant for Honda or BMW engines (search).
Old 12-07-2008, 12:04 PM   #10 (permalink)
Gibby936's Avatar
Member #14076
Gibby936
I found honda bearings that I can get in .25, .5, and .75 undersizes. So I will prolly go that route. I just may fix both motors and keep or sell the xtra.
bearings
