gsxr1000 k7 engine rebuild much harder than TL? - TLZone Forums
Old 10-28-2008, 09:22 AM   #1 (permalink)
ego ego is offline
ego's Avatar
Member #7581
Sportsbike: sv400Naked(sold) TL1000R
Riding Experience: from 1998
Life Wasted on TLZone: 3 Weeks, 1 Day and 20:27:44 Hours
ego
Send a private message to <!-- google_ad_section_start(weight=ignore) -->ego<!-- google_ad_section_end --> Steve is the prettiest admin
i'm thinking about rebuild gsxr engine after oil starvation, i have experince with rebuild of TL engine, and wondering about gsxr one, do i need any special tools except workshop manual?
Russia
Transistor TRE, Airbox Mod, 17/40, 1/5 trottle insert, Ohlins shock and steering damper, gold 07 busa forks with Traxxion dynamics "Street Only" setup, fullfloating rivet mod brake rotors, Carrozzeria black wheels, Brembo brake MC 19x18, Brembo clutch MC 16RCS, black powdercoated frame/subframe/swinger, 03 YB colour scheme, full Yosh SS system, adjustable Yosh billet rearsets, Honda Dio ZX integrated tail light with LEDs, headlight mod with BMW E50 Bi-Xenon 3" lens and integrated turn signals.
Old 10-28-2008, 09:49 AM   #2 (permalink)
BikePilot's Avatar
Trader Rating: (18)
Life Wasted on TLZone: 3 Months, 3 Weeks, 4 Days and 14:25:17 Hours
I've not done one, but overal I-4's tend to be easier to work with in some ways as you've only got one cylinder bank - one set of cams, more simple to get them timed etc. check to be sure it is rebuildable, I think the cams ride directly on the cylinder head journals with no bearings so if they are scored it may not be easy to rebuild. I don't know if the crank bearings still use shells like the TL or if they've done away with them.
best of luck
Old 10-28-2008, 01:53 PM   #3 (permalink)
TLR-Billbo's Avatar
Member #1415
Trader Rating: (48)
TLR-Billbo is dreading winter coming
still use crank bearings, no bearings on cams. you'll need the flywheel puller, etc to replace the crank seals. pretty simple usually though. pull the cams and head, flip the motor upside down, split the case, pull out the trans and crank/pistons. I'm pretty sure the cyls on those are part of the cases, so just grab the cranka nd lift it out, pistons and all. may be a tad easier to unbolt the rods and pull the crank, then pull each piston individually
*2005 SXR 800*Skat 9/17 140-75 SS Impeller*Blowsion mat kit*Blowsion billet bilge switch*Rule 500GPH bilge*R&D bilge bracket*R&D billet angled reed spacers*V-Force Delta 2 Carbon reeds*R&D exhaust sleeve*Wamiltons scupper*Wamiltons stubby pump cone*fuel fill and pickup mod*-4" hull*-1.5" pole*R&D stealth intake grate*-4" ride plate*ODI grips*R&D Pro-lock filters*Jetworks mixture screws*Blowsion billet engine mount keepers*R&D 6º ignition adv kit*Billet driveshaft coupler*dual-cooling*Wiseco 80.96mm factory Kawi race pistons (true 800cc)*UMI Billet throttle lever*
MySpace and Facebook
Old 11-23-2008, 08:26 PM   #4 (permalink)
whitehendrix's Avatar
Member #16295
Sportsbike: not a tl :( .. i have 2-600 ninjas, a ZX7-R and a XR100R so far..
Riding Experience: 8 yearsish
Life Wasted on TLZone: 4:05:38 Hours
whitehendrix
Send a private message to <!-- google_ad_section_start(weight=ignore) -->whitehendrix<!-- google_ad_section_end --> Steve is the prettiest admin
ya. I-4 stuff is cake. i do it all day. Just as TLR-Billbo said.. the cam bearings are cast pieces.. .. plastigauge the bearings and everything to ensure clearances are in spec.
the last motor i did that suffered oil starvation made enough metal flakes and ground up piles or aluminum and steel to probably make another motor. trashed 15 gallons of solvent in my parts washer and spent 2 days cleaning the cases. EVERY SINGLE damn bearing in it EVERY one was hosed. there was metal in places i didn't know existed. there are 3 oil pumps on this particular motor, and all 3 are trashed.
the ONLY salvagable parts are the valves, which i'll lightly lap and reinstall, along with a set of new cams (not oem.. different LSA and all)
if you're gonna go into it hardcore, i'd do all the seals if you're going to split the case halves.. at the very least, do a valve adjustment if need be (you can bench adjust..) look into valve seals and make uber sure theres no more reason for the pump to fail.. if you don't know the root cause as to why it went out, find it!!
honestly, they are easy tho.. very simple and basic layout.
good luck man
Old 11-23-2008, 08:32 PM   #5 (permalink)
Life Wasted on TLZone: 3 Months, 2 Weeks, 1 Day and 18:26:30 Hours
pretty straightforward . fitting the piston and rings to the barrels will probably require 2 people and a steady hand .
Pm me for details to make ring holders for the job
Old 11-29-2008, 06:00 AM   #6 (permalink)
JarkkoT's Avatar
Member #112
Sportsbike: speed triple 1050,T-ace trackhack, used to have 97 TLS
Riding Experience: over 10 years on the road
Life Wasted on TLZone: 4 Days and 22:12:21 Hours
JarkkoT
Send a private message to <!-- google_ad_section_start(weight=ignore) -->JarkkoT<!-- google_ad_section_end --> Steve is the prettiest admin
i doubt it's worth the effort. parts cost alot and there is lot of work and in the end it may still fail.
buy new engine. there is so many crashed k7 out there.
but before doing that, you may open it up for the hell of it, just to estimate the damage. if the head is fine, you can probably sell it. so the new engine doesn't cost that much if you get some money out of the old one.
JT
I take no liability if someone burns up his/her TL with Jarkko/Sparkko/plus mod It's safe if it's done right....
quote:
Originally posted by tv1000s
"If i had a garage half the size of the smallest garage you guys had i would build a tl powered airplane with lazers"
Old 11-29-2008, 06:31 AM   #7 (permalink)
zippytlsr's Avatar
Trader Rating: (21)
I'm with JarrkoT.... just get another motor
Then take the other apart.. and take lots of pictures... i'm itchen to see what the internals of the motor look like.
Old 11-29-2008, 09:38 AM   #8 (permalink)
133bhp's Avatar
Member #4408
133bhp
Send a private message to <!-- google_ad_section_start(weight=ignore) -->133bhp<!-- google_ad_section_end --> Steve is the prettiest admin
Agree If a new engine is V cheap or can ride/hear running if not - why bother?, you could well end up with a bigger pile of junk than you have now, at the very least its a big gamble, Whereas short of cracking the block etc, You can rebiuld safe in the knowledge its been done right.
Main sponsor.-
ebaY
Old 12-05-2008, 07:58 PM   #9 (permalink)
ego ego is offline
ego's Avatar
Member #7581
ego
Thanks for updates guys!
Used engines is not available here, buy it from EU or USA not worth, shipping will kill such deal. Will try to rebuild that, hopefully all other parts except crank and bearings are fine, motor have only 1k ,miles on it.
Russia
engine, gsxr1000, harder, rebuild
