09-13-2008, 07:40 PM
Member #9502
Sportsbike: 02 TL1000R, 00 TL1000R, 97 TL1000S
Riding Experience: 14
Life Wasted on TLZone: 4 Weeks, 1 Day and 21:22:32 Hours
TLR-Brendan
97 TLS rebuild....
I just picked up a 1997 forest green TLS for $400.00, the only down side is that a fair amount of the engine came out with the oil...
So I am already planning on doing a complete engine rebuild to get her back on the road as my daily driver.
I already have a good set of cylinders and low milage TLR pistons. I also have a spare set of TLR heads and cams incase the TLS parts are damaged.
I know I will need at the very least a new oil pump, relief valve and most likely a crankshaft and maybe rods. I am already planning on using a vented rear valve cover and creating a breather system on this bike. I also remember reading there was an oiling difference between the older and newer engines. I will be doing a lot of reading over the next few weeks to gather as much information on rebuilding my 97 TLS engine as possible. Any helpfull tips or suggestions would be appreciated.
Thank you...
2002 TL1000R, Air box mod, Pipercross air filter, Full yoshimura RS-3 stainless, Yoshimura box remap. R-1 throttle tube, Bitubo rear shock, Vandriver billet rear resovoir, tail risers, +1mm swingarm eccentrics, sprocket cover.
Future plans. 12.6:1 pistons, Web cams and gears, PCIII, Matchported and cleaned up heads, Vandriver triple clamps and clutch cover...
SOLD2004 GSX-R 1000, K&N air filter, Full yoshimura carbon TRS exhaust, -1 front sprocket. 148.3 horsepower and 73.14 ft-lbs torque.
2000 TL1000R track bike. K&N air cleaner, yoshimura RS-3 carbon full system with dual oxygen sensor bungs. Stock engine for now......
1997 TL1000S, soon to be TLR powered....
09-14-2008, 02:42 AM
Member #1612
Sportsbike: Suzuki TL1000R & TL1000S
Riding Experience: 21yr
Life Wasted on TLZone: 1 Week, 1 Day and 7:56:52 Hours
bdejong
TLR or '98- casings, they're stronger/stiffer, but then you also need anoter secondary shaft, sprocket bearing, seal and spacer.
Next to that the TLR/'98-TLS uses solid shift fork guides, larger oil jets and different crank bearing clearances.
There's also a steel plate in the bottom of the sump of the later models.
That's what I changed throwing '97 internals in '98- casings.
The bike has ran 35000km since. No probs.
Wooden shoes, Wooden head and wouldn't listen.
Oh yeah, and also a wooden bridge now. http://www.a7sneek.nl
09-14-2008, 08:18 AM
Member #9502
TLR-Brendan
Trying to keep the rebuild costs down..... So will the later style windage tray fit into the 97 cases...
09-14-2008, 10:34 AM
Member #5251
Sportsbike: tl1000sv,cb1100r
Riding Experience: definately
Life Wasted on TLZone: 3 Weeks, 1 Day and 21:41:09 Hours
jagboy1
i'd put a later motor in.....
09-14-2008, 11:13 AM
Member #9502
TLR-Brendan
Way too much money without the knowedge that I know everything is in good working order inside the engine.
09-15-2008, 08:32 PM
Member #9604
Sportsbike: 02 r1, 00 TL1000R
Riding Experience: 5 years
Life Wasted on TLZone: 11:16:35 Hours
gixxerfrank
brendan...finish the track bike first!!
09-15-2008, 10:17 PM
Member #1612
bdejong
No guarantees, but I think the windage tray will fit the '97 model. It's held in place by the oil canal and the back side of the engine as far as I recal, and the casings shouldn't be that different in that area.
For probably a few bucks you can have a try. Don't blame me if it doesn't fit.
01-06-2009, 04:29 PM
Member #14076
Sportsbike: 01' TL1000S 95' CBR F3
Riding Experience: 10 years on and off road
Life Wasted on TLZone: 5 Days and 21:16:02 Hours
Gibby936
Dude if I would of known you were going to sell that thing as cheap as it is listed I would of bought it in a heartbeat! Unfortunatly i alrealy bought one.
 Full M4 exhaust, pc3, speedo healer, 17/41, gold x-ring chain, solo cowl, corbin seat, gpr, flapper unhooked, TRE, db speed screen, launch strap, integrated signals, clear clutch cover, billet pressure plate, barnett springs, braided lines, under tail, tank bra, k & n, crash bars, grab bar
01-06-2009, 06:23 PM
Member #11400
Sportsbike: 98 TLR, 97TLS/R, 06SV1000S
Riding Experience: 4 years
Life Wasted on TLZone: 1 Week, 3 Days and 8:12:23 Hours
vtwinjunkie
why not just buy a running motor and throw it in?
