08-21-2008, 05:21 AM
Member #3439
Sportsbike: TL1000R
Riding Experience: Since 10
Life Wasted on TLZone: 3 Weeks, 5 Days and 1:48:28 Hours
pad
Big end bearings lucky to catch this one
http://members.optusnet.com.au/p-d/PICT0004.JPG
This is out of a motor with 35000 kilometres on it
18000 of witch are from the previous owner over a period of five years.
On my last ride I noticed an increase in vibration from the engine.
I ended up removing the side cover and having a look at the oil Filter mesh, there I found a couple of small flakes of white metal.
The crank looks fine , ill measure up the crank and rod end to see What sort of clearances are there.
The bearing looks like it is suffering from metal fatigue, with the white metal Starting to flake off the back shell
08-21-2008, 05:47 AM
Life Wasted on TLZone: 5 Months, 1 Week, 1 Day and 4:57:00 Hours
is TLess
Lucky catch.
I wonder if that's the cause of the vibes though
08-21-2008, 06:01 AM
Life Wasted on TLZone: 1 Week, 5 Days and 3:48:31 Hours
I'm with Steve there.. wow... really nice catch. any pictures of the crank?
Scorpio SE-i500 system,TLR MOTOR, pc2,yosh full system w/titanium cans ,(thanks 00tiller) k+N filter, UFO tail light kit-sweet! Corbin seat,Heli Bars, Throttle miester, six pot tlr caliper system, dble bubble screen,Galfer ss brake lines front&rear,tl tank protector,Bitubo rear shock-thanks Origin8tor!,clear clutch cover, CRG Levers,clear tailight lens-new paint, front end reworked by Aftershocks, fresh Powdercoated rims and front Wave rotors via TODD at Cal sportbike,as well as a SPEEDO HEALER from him,  ,fan mod-thanks et79,gpi gear indicator w/ATRE-thanks again cal sportbike. MY CUSTOM R/R WIRING HARNESS TO GET CHARGING SYSTEM UP TO PAR! check frequent mod section out!!
08-21-2008, 07:37 AM
Life Wasted on TLZone: 2 Months, 4 Weeks, 0 Days and 20:09:56 Hours
Very Lucky Catch
The pitting is from the excess clearance of the shell. The rod will have started to hammer causing the vibration and failure of the bearing material.
08-22-2008, 12:38 AM
Member #112
Sportsbike: speed triple 1050,T-ace trackhack, used to have 97 TLS
Riding Experience: over 10 years on the road
Life Wasted on TLZone: 4 Days and 22:08:57 Hours
JarkkoT
Nice catch, that really shows how the damage starts, so it's a rare picture. usually pics are taken after the damage is total.
is the damage only to lower shell? It's amazing that many times the damage actuall is to the lower shell and not the upper, even thou upper should get more damage, because piston forces are against it.
I've seen some explanation, that engines with big pistons are generating so much G forces to the piston that rod gets pulled at higher force when throttle is suddenly closed or engine hits limiter, because there is no air cushion anymore and no explosition to turn the piston to go down. This can cause lower bearing damage, as the pull to get the piston down is so great at 10k.
so actually driving at good throttle at 10k does less damage to the engine, compared to situation where the limiter is hit and throttle closed suddenly. many drag racers are saying the same thing, that throttle should not be closed totally at the end. it destroys engines.
I take no liability if someone burns up his/her TL with Jarkko/Sparkko/plus mod  It's safe if it's done right....
quote:
Originally posted by tv1000s
"If i had a garage half the size of the smallest garage you guys had i would build a tl powered airplane with lazers"
08-22-2008, 01:58 AM
Member #6819
Sportsbike: tls/r hybrid
Riding Experience: Since 2001
Life Wasted on TLZone: 3 Weeks, 0 Days and 5:18:24 Hours
brent_b
I know mine failed in the TLS upon hitting the rev limiter
08-22-2008, 02:30 AM
Que?
Member #4632
Life Wasted on TLZone: 2 Months, 0 Weeks, 3 Days and 1:10:06 Hours
Kamikuza
's real name is Kevin
Ah, that might explain why when my local shop does a 'dyno' run, they keep revving the engine with the clutch in while the rear wheel spins down ... then again, it may just be a whacky jappo thing
08-23-2008, 05:36 AM
Member #112
JarkkoT
+1
it's more dramatic to hit rev limiter with twin, because the piston +rod weights alot. four cylinder has much lighter pistons and rods. 10k for 1000cc twin is more dramatic than 20k for 1000cc four? as far as pistons go.
that oil hole area has some damage too. not sure what is the cause, is that some fatique or cavitation damage. There was one good page in the internet that showed all the damage types, but I couldn't find it now.
08-23-2008, 02:17 PM
Member #6819
brent_b
+1
it's more dramatic to hit rev limiter with twin, because the piston +rod weights alot. four cylinder has much lighter pistons and rods. 10k for 1000cc twin is more dramatic than 20k for 1000cc four? as far as pistons go...
I have seen mention of soft and hard rev limiters, do we have a hard type? I thought the whole reason for the rev limiter is to stop damage to the engine, not create it
