need affordable cams - TLZone Forums
Old 08-11-2008, 10:56 PM   #1 (permalink)
Goo Goo is offline
Member #15330
Life Wasted on TLZone: 0:55:33 Hours
Goo
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Goo<!-- google_ad_section_end --> Steve is the prettiest admin
couldn't afford JE Hi-comp pistons, so a Wiseco set is on the way for 350$. Would a set of Webb performance cams be an ideal bang for the buck? My ebay seller stop carrying the Webb cams and I'm having a hard time finding a set. Can some1 post a reply with an opinion & a link to a set of affordable cams please? Thx
Old 08-12-2008, 11:24 AM   #2 (permalink)
jagboy1's Avatar
Member #5251
Sportsbike: tl1000sv,cb1100r
Riding Experience: definately
Trader Rating: (13)
Life Wasted on TLZone: 3 Weeks, 2 Days and 7:43:51 Hours
jagboy1
Send a private message to <!-- google_ad_section_start(weight=ignore) -->jagboy1<!-- google_ad_section_end --> Steve is the prettiest admin
they're not cheap dude...
Old 08-12-2008, 08:56 PM   #3 (permalink)
cyclecamper's Avatar
Member #4340
Riding Experience: 40 years
Trader Rating: (27)
Life Wasted on TLZone: 2 Weeks, 0 Days and 4:29:45 Hours
cyclecamper
Send a private message to <!-- google_ad_section_start(weight=ignore) -->cyclecamper<!-- google_ad_section_end --> Steve is the prettiest admin
I've got veetwo cams I'm going to use, so I have an extra set of lightly used WebCam cams in good condition I'd sell for 1/3 price, but you'd need to buy the adjustable gears, which are expensive http://webcamshafts.com/ . New the set of cams and gears would cost $1054 but this way it would only cost you $668 and you have new gears. These already have the mounts for the adjustable gears welded on, so you can't use stock gears anymore. Is this for a TLS or TLR? Aftermarket cams don't work well unless you raise the compression higher than the stock TLR. The Wiseco pistons are the same compression as the stock TLR regardless of what Wiseco says; you'd have been much better off for less money with just the J&E than Wiseco and cams. So you'd need to shave your heads, and .020 is the max you can take off. That could work OK if you set squish carefully.
The lesson is to use J&E unless you can get Wiseco to raise the dome on their pistons.
Old 08-12-2008, 09:03 PM   #4 (permalink)
Member #4340
Trader Rating: (27)
cyclecamper
You can usually get somebody to discount the Wiseco for around $325. You probably did OK if you didn't pay sales tax.
Old 08-13-2008, 11:45 AM   #5 (permalink)
jagboy1's Avatar
Member #5251
Trader Rating: (13)
jagboy1
wish i had tha xash to take em off your hands.....cams are the next things for my engine......
Old 08-28-2008, 09:46 PM   #6 (permalink)
Member #4340
Trader Rating: (27)
cyclecamper
So why the hell didn't we all get Wiseco to make higher-dome TL pistons with better compression? They're half the price of J&E and decently made, and Wiseco makes all kinds of custom pistons...if we'd done a group buy they'd be half the cost of the J&E even as custom pistons.
Old 08-28-2008, 10:30 PM   #7 (permalink)
Sam Sam is online now
Trader Rating: (104)
Yep, wiseco's are just an alternative replacement to a Genuine Suzuki TLR Stock Piston and Rings
Old 08-28-2008, 10:57 PM   #8 (permalink)
Life Wasted on TLZone: 3 Months, 2 Weeks, 1 Day and 20:28:57 Hours
How do they compare for weight . the wisecos I put in my 900 duke were over the top weight wise.
Old 08-28-2008, 11:36 PM   #9 (permalink)
I'm not sure as I'm at work, but have all the weights at home of stock/JE/Wiseco etc
Old 08-28-2008, 11:56 PM   #10 (permalink)
abn abn is online now
Member #7804
Sportsbike: 1997 TLS, 2000 TLR
Riding Experience: 20 years or so
Trader Rating: (8)
Life Wasted on TLZone: 1 Month, 0 Weeks, 5 Days and 4:06:07 Hours
abn
Send a private message to <!-- google_ad_section_start(weight=ignore) -->abn<!-- google_ad_section_end --> Steve is the prettiest admin
Same here...IIRC they were about the same weight maybe a gram or two lighter. But the genuine made in Taiwan thin wall pin was only about 73 grams, about the same weight as comparable Ti pins I've seen, the relief ground in the pin bore is supposed to allow pins with less hoop strength (more distortion). Sounds funky to me, but I guess Wiseco knows what they're doing Well now that I've done my part to turn Goo's cam thread into a piston thread I'll move along
affordable, cams
