Engine questions? - TLZone Forums
Old 08-10-2008, 02:29 PM   #1 (permalink)
ICEtlr's Avatar
Member #15088
Sportsbike: Tl1000r
Riding Experience: 2 years
Life Wasted on TLZone: 12:26:04 Hours
ICEtlr riding
Send a private message to <!-- google_ad_section_start(weight=ignore) -->ICEtlr<!-- google_ad_section_end --> Steve is the prettiest admin
Engine questions?
Ok so i recently synced the TB and set the TPS sensor. Also i removed the flapper system in the airbox.
But when im riding im getting sputter and detenation in the exhaust.
I noticed that the cans have tiny litle holes drilled into them near were the pipe and the cans join. This might be it but im not sure.
Also when setting the the TB's i used a tool like this
http://static.summitracing.com/globa...e/edl-4025.jpg
And the ball in the meter was rocking more up and down on the front TB then on the rear TB.
Then when i open the oil cap while the engine is in idle, its like an exhaust through there i mean it pulses air through there.
Ok so im looking for a troubleshoot here.
DO i have a bad piston ring? (But no smoke in exhaust so no burning oil)
Valve trouble?
Or am i just paranoid and nothings wrong hehe
Chip in your ideas guys thx
Old 08-10-2008, 02:31 PM   #2 (permalink)
ICEtlr's Avatar
Member #15088
Sportsbike: Tl1000r
ICEtlr riding
Engine questions?
Valve trouble?
Old 08-11-2008, 02:56 AM   #3 (permalink)
Life Wasted on TLZone: 3 Months, 2 Weeks, 1 Day and 10:51:11 Hours
The gas coming out of the oil filler is normal just forget about it. there is 1litre of air going up and down in there and some of it will want to get out if you let it . thats why theres a filler bung.
was the splutter etc there before you started?
Old 08-11-2008, 03:14 AM   #4 (permalink)
ICEtlr's Avatar
Member #15088
Sportsbike: Tl1000r
ICEtlr riding
well there was a detenation in the exhaust when letting of from hard throttle, but now theres more of a sputter i think.
Old 08-11-2008, 03:22 AM   #5 (permalink)
noise in the exhaust when you close the throttle is cause by air getting into the pipes on deceleration. A bit of high temp silicon on the joints and block any holes will stop this .
What exactly is sputter?
Maybe fix the exhaust leak first and revisit the sputter.
Old 08-11-2008, 06:05 AM   #6 (permalink)
zippytlsr's Avatar
Trader Rating: (21)
Life Wasted on TLZone: 1 Week, 5 Days and 3:48:31 Hours
Sounds like he may have the Pair Valve still on his bike... on decel it trys to burn the extra exhuast by injecting air into the pipes. The lil holes are moisture drain holes.
You can check to see if the exhaust clamps are snug. just thinking out loud.
Old 08-11-2008, 08:11 AM   #7 (permalink)
TLR-Billbo's Avatar
Member #1415
Trader Rating: (48)
TLR-Billbo is dreading winter coming
remove the pair valve and plug the hoses and you'll lose the backfire. those holes in the mufflers are normal, they're for water drainage in the event the bike gets left out in the rain, and to drain moisture from condenstation when running
*2005 SXR 800*Skat 9/17 140-75 SS Impeller*Blowsion mat kit*Blowsion billet bilge switch*Rule 500GPH bilge*R&D bilge bracket*R&D billet angled reed spacers*V-Force Delta 2 Carbon reeds*R&D exhaust sleeve*Wamiltons scupper*Wamiltons stubby pump cone*fuel fill and pickup mod*-4" hull*-1.5" pole*R&D stealth intake grate*-4" ride plate*ODI grips*R&D Pro-lock filters*Jetworks mixture screws*Blowsion billet engine mount keepers*R&D 6º ignition adv kit*Billet driveshaft coupler*dual-cooling*Wiseco 80.96mm factory Kawi race pistons (true 800cc)*UMI Billet throttle lever*
MySpace and Facebook
Old 08-11-2008, 01:27 PM   #8 (permalink)
ICEtlr's Avatar
Member #15088
Sportsbike: Tl1000r
ICEtlr riding
do all TL's have the PAIR valve? i thought this was only california models or sumthing like that.
But anyways if its there its going of 2morrow.
Old 08-11-2008, 11:52 PM   #9 (permalink)
Not all markets have the PAIR system. Some did, some didn't.
The 'CA only' stuff was a sealed tank vented to atmosphere via a charcoal cannister that was purged by the engine running.
Old 08-12-2008, 06:04 AM   #10 (permalink)
zippytlsr's Avatar
Trader Rating: (21)
True about the Cali bikes... but with Ebay and all I thought maybe he had one of those great smog free machines.
oops, never mind me.. steve i thought you were talking to me.. somehow i missed Icetlr's question.
engine, questions, questions?
