| Looking to Sell Have Motorcycle or Motorcycle related parts and accessories to sell? Post it here. You have to be a subscriber to start threads in the Market place. Note: Inactive threads will be deleted after 30 days. |
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. If you are already a member, but have forgotten your password, you can have it sent to your email address by using this form. |
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
![]() Member #2079
Life Wasted on TLZone: 1 Month, 0 Weeks, 4 Days and 7:29:31 Hours
SOLD WER Steering Damper, fully adjustable
These are a rotory design much like a Scotts/Ohlins or GPR. They have adjustable damping. It is more simple than the Ohlins, but also fully user serviceable. If you find you want more adjustment range you can put in thicker or thinner oil, although the thumbwheel adjuster works very well.
The reason I went with this model was because it mounts to the lower triple clamp and leaves the upper triple uncluttered for a clean look. This also means it will work just fine with an MX bar conversion. The damper body is universal then mounting kits are used to fit it to various bikes. This one has the kit to mount to a TLR. The mounting is pretty simple and I'm pretty sure it would fit a TLS without much hassle, but haven't tried it yet myself. I bought this with the intention of putting it on my TLS and never got around to it and now could use the $$. These retail for $399 and most discount shops sell them for $360ish. I'd like $260 shipped in CONUS, I'll happily ship to anywhere in the world but outside CONUS I may need a few more $$ to cover the extra shipping expense. Its brand new, the box has only been opened so I could take pics of everything. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
For Sale: EVS Web Knee Braces. Josh ![]() TL Zone Forum Staff - Resident RAIN RIDER Questions about The Forums? Click Here 1997 TL1000S/V - TLR Akro Evo Ti Exhaust - PCII - 5.5" rear rim & 180/55 - Avon AV45/46ST tires - No Steering damper- Uni Filter -Relocated Temp sensor & 98+ t-stat housing/wp cover - TLRCrazy1 Fan Switch Mod - Dual Star heated Grips - HeliBars - 60k miles. 9k mile summer ride report |
#2 (permalink) |
![]() Member #2079
Just FYI that's 167 Euro or 132 GBP (according to xe.com)
For Sale: EVS Web Knee Braces. Josh ![]() TL Zone Forum Staff - Resident RAIN RIDER Questions about The Forums? Click Here 1997 TL1000S/V - TLR Akro Evo Ti Exhaust - PCII - 5.5" rear rim & 180/55 - Avon AV45/46ST tires - No Steering damper- Uni Filter -Relocated Temp sensor & 98+ t-stat housing/wp cover - TLRCrazy1 Fan Switch Mod - Dual Star heated Grips - HeliBars - 60k miles. 9k mile summer ride report Last edited by BikePilot; 05-12-2008 at 08:27 AM. |
#3 (permalink) |
WSB Pit boss
Member #74
Sportsbike: 2002 TL1000R b/w
Riding Experience: been there, done that!
Life Wasted on TLZone: 1 Day and 17:20:18 Hours
dragonbro
what kind of modification is needed to mount to TLR. Instructions say something about drilling
2002 TLR B/W fan switch. HyperPro steering damper. Extreme Graphic Top Gun undertail. Ohlins rear shock.Gear: Arai Quantum f. Joe Rocket GPX 1pc suit. Alpinestars Super Tech boots. Alpinestars GP-1 gloves----always wear it all |
#4 (permalink) |
Member #368
Sportsbike: 1997 TLS 2002 KTM 300MXC
Riding Experience: First bike, 1983
Life Wasted on TLZone: 4 Days and 17:34:05 Hours
wsmc831
good dampers. I've used one on my ktm for 6 years. Wer has good service and rebuilds are definately on the inexpensive end for that sort of thing.
1997 TLS - the classy green one. Yosh full system, custom high mount. PcII, Sharkskinz TLR one piece race tail with anti draft undertail, Zero gravity double, Pro-tek rearsets, Hyperpro 916 style damper, corbin seat, Vortex triple clamp, airtech hugger, Penske/Lindeman rear shock and linkage, Lindeman superbike fork valve job, Marchesini 10 spoke Black, Gsxr 750 6 piston calipers and larger m/c, SS brake lines front and rear, Braking Wave Rotors front, milled gsxr rotor rear, billet preload adjusters, airbox reworked, Graves clutch cover, gsxr 1000 rear caliper, Stealth tri metal rear sprocket, Rk 520 chain, sprocket specialists front, KN air filter, Black/gold Pazzo levers, Vortex black gas cap, Ti bolts, ceramic coated headers, 05 1k clip ons, 4 lb battery. |
#5 (permalink) |
![]() Member #2079
Best I can tell you have to drill one 3/16ths hole in the underside of the frame spar for mounting the frame bracket (its where the damper attaches to the frame). A drill bit is included. The is also a tap and screws included as well as pop rivets so I guess you can pick which ever you like best. I'll make a better scan of the instructions and post them in a sec
#6 (permalink) |
![]() Member #2079
#7 (permalink) |
![]() Member #2079
Also, if you wanted you could buy a mounting plate for your second bike (if you have one etc) and swap the damper between bikes. Once the plates/brackets are installed it is pretty simple to remove the damper body itself. IIRC mounting kits are about $65.
#8 (permalink) |
![]() Member #2079
Bump
#9 (permalink) |
![]() Member #2079
Just FYI I'm in FL and won't be able to ship it out untill the 1st of june or thereabouts
#10 (permalink) |
Member #9443
Sportsbike: 00 SV650, 01 SV650S, 02 SV650S, 01 TLR fighter, 05 BMW R1100S, 87 BMW K75C, 69 BMW R60
Riding Experience: since 5yrs old
Life Wasted on TLZone: 1 Day and 19:28:10 Hours
mullerjd
I had one I was going to use on mine but the headlight was in the way
I only got about $100 on Ebay though
01 TLR Fighter, 00 SV, 01 SVS, 02 SVS, 05 BMW R1100S, 87 BMW K75, 69 BMW R60US |
#11 (permalink) |
Super Motarderator ........ Mad Modder .......
![]() Member #1458
Sportsbike: 2003 Aprilia RSV Tuono, 2008 DR-Z70
Riding Experience: Since 1971
Trader Rating: (79)
Life Wasted on TLZone: 1 Week, 1 Day and 9:59:11 Hours
OldTLSDoug
'08
WER Dampers are nice, I had one on my first TLS. Nice product. Need to drill a couple of holes in the frame to mount on a TLS
Be Good, Wear Gear, Do Wheelies, Doug "OldTLSDoug" Basinger 2008 DR-Z70 2003 Tuono G-Town Squid Squad |
#12 (permalink) |
![]() Member #2079
Bump, I'm back in MA and would like to get this out of my apartment
Open to offers![]()
#14 (permalink) |
![]() Member #2079
PM replied
