01-23-2010, 07:29 AM
Member #18862
Sportsbike: TL1000S '97
Riding Experience: 2 Years
Life Wasted on TLZone: 4 Days and 4:35:03 Hours
wattawog
Front & Rear Disc Diameter
Dimensions at hand for front & rear rotors anyone?
Rotor Thickness: ? mm
Bolt Center: ? mm
Bolt Diameter: ? mm
Thanks in advance
01-23-2010, 07:37 AM
Never ride faster than your angel can fly.
Member #17601
Sportsbike: 97' TL1000s (v)
Riding Experience: Getting better every day.
Pictures: 6
Life Wasted on TLZone: 2 Months, 3 Weeks, 2 Days and 0:22:56 Hours
Chris
Do it, do it, do it, do
it, do it, DO IT...!!!!
Fronts
I think the Diameter is 320mm
the service limit on thickness is 4.5mm
Not sure about the bolt holes but the bolts are 30mm from under the head 10mm of shoulder 20mm thread.
Bolts are 8x33
97 TLS - Rizla Colours - Blue wheels, - Reflective yellow rim tape - Lowers fitted - LSL top yoke and risers - Renthal bars - Braided lines twin front and single rear - Vans gold reservoirs front and rear - Sprint steering damper - Screen cut down - mirrors removed - 6 pot Gold calipers - Blackshadow UK 'Blade' front Rotors - Blade reverse rear rotor - EBC HH pads - Blue LED Dash Lights - LED number plate light and indicators - flasher relay changed - K&N Air filter - K&N Oil Filter - Scorpion Race Cans Cut to 10 inch - +Mod - OEM Thermostat Mod - Riflemans 1/5th - Ohlins rear damper - Samco blue hoses - FP Gold levers w/blue adjusters - D3 gold/black grips - 6 Bolt clutch conversion - OEM plates & Barnett springs - Vans gold pressure plate w/gold retainers - Original clear clutch cover - Vans gold rear brake return w/blue spring
TLS WHITE DIALS GROUP BUY
01-23-2010, 07:42 AM
Member #17601
Pictures: 6
Chris
Rear is 220mm diameter
Service limit is 4.5mm thick
How do you want the holes on the rear measured, one to the next or diagonally?
Bolts are the same
01-23-2010, 07:43 AM
Pictures: 161
Life Wasted on TLZone: 6 Months, 1 Week, 1 Day and 5:16:13 Hours
is TLess
I think the PCD is in Sam's fork chart.
(Edit, it is. 91mm)
01-23-2010, 07:45 AM
Member #18862
wattawog
Great, thank you...
Now finding the right ones,
01-23-2010, 07:46 AM
Member #17601
Pictures: 6
Chris
Whats a PCD
01-23-2010, 11:31 PM
Pictures: 161
is TLess
PCD = Pitch Circle Diameter
01-24-2010, 05:42 AM
Member #17601
Pictures: 6
Chris
Clever B*sT*rd
