Aarrgghh!! not again.. - TLZone Forums
Old 06-28-2009, 02:55 AM   #1 (permalink)
Sold, to the man in the slippers
bentlr666's Avatar
Member #6383
Sportsbike: TLR 1000 (of course).
Pictures: 20
Life Wasted on TLZone: 3 Weeks, 4 Days and 7:34:09 Hours
bentlr666
Send a private message to <!-- google_ad_section_start(weight=ignore) -->bentlr666<!-- google_ad_section_end --> Steve is the prettiest admin
Well the weather gods blessed us with some nice riding weather today, had a nice blast through the twisties and was quite enjoying myself... Until half way home
Riding along i noticed the FI warning light had come on, and after the problems i had earlier on in the year i decided to pull over and put it into dealer mode to see what code was being thrown up.. Get back on and kick her over, no warning light came up again so i carry on.. Not long after i see c35 on the display and still no warning light.. about 10min down the road, i'm slowing down for a set of lights and i noticed the needle drop a couple of times then the bike cuts out.. Hit the starter and she fires up straight away.. Get around the corner, bike seems to be running fine, no warning lights, c00 code showing, so i carry on carefully and keep an eye on it.. Another 5 or so minutes down the road she just dies, try hitting the starter.. nothing.. try clutching it.. nothing.. Manage to get off the main road and i have no power what so ever
$200 later and the bike is now home and i am not very impressed..
Last time this happened, i soldered the wires to the starter relay on top of the battery, i removed the white connector under the left front indicator and soldered the wires together. Still didn't fix the problem.. Turns out the battery was rooted (mind you it was only 3 months old) so i replaced that and she was running beautifully.. Will check on the battery status tomorrow to see if that is dead again because at the moment that is all i could think that it may be..
TLoM here i come.... ok it may take me a while but i'm working on it
Work in Progress.....
Vandriver's Clear Clutch Cover, Pressure Plate, Sprocket cover, Billet Rear Brake Reservoir and Brake Return Spring, Yoshi RS3 SS Bolt on's, +2 Driven Rear Sprocket, Eaglescreens Blue Windlip Screen, Revolution Rotors, Axle Flip Mod, MattTheHat TRE, Bitubo Rear Shock, Rifleman's 1/5th Insert, FP Racing Lever's, Charge Mod, Carrozeria V-Track Wheels, Tribo Seat Cover
Waiting to be installed...
Gap Mod Tray, TopGun Undertail
Old 06-28-2009, 03:12 AM   #2 (permalink)
ITSMESTEVE's Avatar
Member #11561
Sportsbike: 98 TLR just looks like an '02
Riding Experience: 26 Yrs
Life Wasted on TLZone: 5 Months, 2 Weeks, 4 Days and 21:53:46 Hours
ITSMESTEVE 's family coat of arms ties in the back
Send a private message to <!-- google_ad_section_start(weight=ignore) -->ITSMESTEVE<!-- google_ad_section_end --> Steve is the prettiest admin
Signal to the rear injector?
Have you had a look at ther loom and connections?
Getting power to the rear injector/injectors?
Red 98 TLR but looks like a yellow 02.Full Yoshi system ,airbox mod,Bitubo rear,SS brake lines,SteveTLS TRE,TLRstacker Sliders,Rifleman 1/5 throttle,Vandriver swingarm pivots ,Pazzo levers,Vandriver tailrisers,PowerCommander lll,Projector headlights,GSXR forks and Radial Calipers & M/C,Ring-In 30mm offset triples,Duc radial clutch master,Ohlins steering damper...and counting. ........ PICK THE POINT IN THE SIG WHERE I JOINED TLZ
Old 06-28-2009, 03:19 AM   #3 (permalink)
bentlr666's Avatar
Member #6383
Pictures: 20
bentlr666
Yeah, it's a strange code.. The bike seemed to be running fine when it happened..
Haven't had a chance to have a look yet, i've got tomorrow off as an RDO cos i had a zone ride planned so now i can't go to that
Guess tomorrow is gonna be a busy day, might need to buy a case of beer
Old 06-28-2009, 03:23 AM   #4 (permalink)
ITSMESTEVE's Avatar
Member #11561
I was thinking you might have a faulty connection at the ecu (or anywhere for that matter) and the rear injector connection was the first to be compromised.Could be as simple as a lose connector somewhere.
Old 06-28-2009, 03:33 AM   #5 (permalink)
bentlr666's Avatar
Member #6383
Pictures: 20
bentlr666
and if that is the case, would it completely shut down the bike? As in no power to the dash with the ignition turned on..
Old 06-28-2009, 03:37 AM   #6 (permalink)
ITSMESTEVE's Avatar
Member #11561
If it is the cnnector to the fuse box or ignition switch
Old 06-28-2009, 03:41 AM   #7 (permalink)
bentlr666's Avatar
Member #6383
Pictures: 20
bentlr666
Hmm... I hate electrical shit
Old 06-28-2009, 03:43 AM   #8 (permalink)
ITSMESTEVE's Avatar
Member #11561
Electrickery
Old 06-28-2009, 06:09 AM   #9 (permalink)
Life Wasted on TLZone: 5 Months, 1 Week, 1 Day and 4:08:51 Hours
TLDV8 posted a picture of a mod the other day. It bypasses the main electrics running through the starter solenoid completely. A much simpler and more effective mod than soldering the wires to the solenoid.
(You still need the solenoid coil wires connected, but they don't carry much current and aren't the cause of the problem with it).
Old 06-28-2009, 05:20 PM   #10 (permalink)
bentlr666's Avatar
Member #6383
Pictures: 20
bentlr666
The charging mod yeah??
Thats good, cos they are soldered on so they aint coming off
aarrgghh!!, again..
