06-28-2009, 05:33 PM
#11 (permalink)
is TLess
Originally Posted by bentlr666
The charging mod yeah??
Thats good, cos they are soldered on so they aint coming off
No, not the charging mod. It's the new bypass the 30amp fuse in the starter solenoid mod. (I can't remember what thread he posted it up in or I'd grab it).
(I'd make one little change to it. Instead of running the new fuse tail to the battery post, I'd put it under the main supply post on the solenoid, so it's more compact and less wiring to run.)
06-28-2009, 05:49 PM
#12 (permalink)
Sold, to the man in the slippers
Member #6383
Sportsbike: TLR 1000 (of course).
Pictures: 20
Life Wasted on TLZone: 3 Weeks, 4 Days and 8:18:58 Hours
bentlr666
This one yes??
Originally Posted by TLDV8
I never had any electrical problems on either TLS,no water could get to it n that bike as it is tucked up under the seat and undertray.
Maybe excessive use of the starter overheats the plug.
What motor vehicle runs the main power off solenoid.
Easily fixed if it does go west.
The solenoid/relay then becomes a sole unit not a mickey mouse power take off. ?
I don't know about all bikes but some were said to !@#$ the R/R if the battery was disconnected while the engine was running,idling speed who knows.
TLoM here i come.... ok it may take me a while but i'm working on it
Work in Progress.....
Vandriver's Clear Clutch Cover, Pressure Plate, Sprocket cover, Billet Rear Brake Reservoir and Brake Return Spring, Yoshi RS3 SS Bolt on's, +2 Driven Rear Sprocket, Eaglescreens Blue Windlip Screen, Revolution Rotors, Axle Flip Mod, MattTheHat TRE, Bitubo Rear Shock, Rifleman's 1/5th Insert, FP Racing Lever's, Charge Mod, Carrozeria V-Track Wheels, Tribo Seat Cover
Waiting to be installed...
Gap Mod Tray, TopGun Undertail
06-28-2009, 06:00 PM
#13 (permalink)
is TLess
That's the one.
06-28-2009, 06:09 PM
#14 (permalink)
Member #6383
Pictures: 20
bentlr666
Ok, so should i cut the red and red/white wires off the relay to join together going to the fuse...
Then the red wire going fromt the battery to the relay, where about on the relay does that connect??
Sorry, electrics aren't my thing.. I can do it when i understand it, but i need to understand it first
06-28-2009, 06:42 PM
#15 (permalink)
Member #6383
Pictures: 20
bentlr666
Just had the bike hooked up to my car and she's fires up no problems... But as soon as i take the jumper leads off, it dies... So i think it's fair to say that the battery is fucked..  not happy, it's only a couple months old.. Now i need to find out whats destroying my batteries
06-28-2009, 09:14 PM
#16 (permalink)
Member #6594
Life Wasted on TLZone: 4 Weeks, 1 Day and 3:02:25 Hours
TomM
Was it a made in china battery? they seem to be failing for no reason. grab a jap one
06-28-2009, 09:30 PM
#17 (permalink)
Member #6383
Pictures: 20
bentlr666
It's a dynomaster battery.. I think i might just bite the bullet and go for a Yuasa 14V battery.. I just don't wanna fork out $270 for it to die 3 months down the track if something else is the problem..
06-28-2009, 10:00 PM
#18 (permalink)
Member #6594
TomM
i just remember seeing a post here about a bigish name battery failing and when they took it back to the shop they found that the manufacturer had started to subb the manufacturing out to a chinese firm. they were failing right left and centre. but thats from memory and i havent got the best of memorys. but worth checking where your battery was manufactured. + if it has failed after 3 months then shouldnt the shop refund?... just a thought.
06-28-2009, 10:07 PM
#19 (permalink)
Member #6383
Pictures: 20
bentlr666
06-28-2009, 10:12 PM
#20 (permalink)
Member #6594
TomM
take it back
just googled dynomaster. havent found their batteries but have found shocks and forks and they are all made in china.
