TRE Mod - TLZone Forums
Old 06-24-2009, 01:07 AM   #1 (permalink)
grenelson's Avatar
Member #17110
Sportsbike: 97 TL1000s
Riding Experience: 20+
Life Wasted on TLZone: 4 Days and 12:33:57 Hours
grenelson
Send a private message to <!-- google_ad_section_start(weight=ignore) -->grenelson<!-- google_ad_section_end --> Steve is the prettiest admin
TRE Mod
I'm looking to do this mod, but not sure where to find the correct wires,
my TLS is a '97 but has the recall euc so am I looking for a two or three wire plug? where are they situated?
ECU is a 32920-02F41
would like to try making my own Smart TRE.
cheers
97 TL1000S (Rego 98) Dark Green, Two Brothers, Stock Steering damper 2.5wt Oil, Smart TRE, Led Indicators, Thermo Mod, Undertail.
Old 06-24-2009, 01:13 AM   #2 (permalink)
ITSMESTEVE's Avatar
Member #11561
Sportsbike: 98 TLR just looks like an '02
Riding Experience: 26 Yrs
Life Wasted on TLZone: 5 Months, 2 Weeks, 3 Days and 19:32:28 Hours
ITSMESTEVE 's family coat of arms ties in the back
Send a private message to <!-- google_ad_section_start(weight=ignore) -->ITSMESTEVE<!-- google_ad_section_end --> Steve is the prettiest admin
You need to visit Stevetls's home page TRE
Red 98 TLR but looks like a yellow 02.Full Yoshi system ,airbox mod,Bitubo rear,SS brake lines,SteveTLS TRE,TLRstacker Sliders,Rifleman 1/5 throttle,Vandriver swingarm pivots ,Pazzo levers,Vandriver tailrisers,PowerCommander lll,Projector headlights,GSXR forks and Radial Calipers & M/C,Ring-In 30mm offset triples,Duc radial clutch master,Ohlins steering damper...and counting. ........ PICK THE POINT IN THE SIG WHERE I JOINED TLZ
Old 06-24-2009, 01:41 AM   #3 (permalink)
Octofinger's Avatar
Member #4643
Sportsbike: TL1000S -97
Riding Experience: 8 years
Life Wasted on TLZone: 1 Month, 2 Weeks, 2 Days and 6:40:32 Hours
Octofinger Should be scared of the Admins
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Octofinger<!-- google_ad_section_end --> Steve is the prettiest admin
cheers
It's a two wire plug and it's located behind the rear end of the right hand side fairing.
A white plug with one blue and one pink wire (at least from one of the directions).
Done: -98 thermostat housing + bypass mod, Rifleman's 1/5'th, black screen, 17/40 sprockets, home made ATRE, Bitubo rear shock, Barnett clutch springs, split steering damper bracket, iridium plugs, D&D CF full system, +/- mod, Van fork sliders, Ziggy999 frame sliders, Pazzo shorty levers, US headlight, Busa front MC, Galfer SS lines, TLR 6-potters, airbox mod, PCII, Van sprocket cover, EBC front brake discs, TI rotor bolts, Van clear clutch cover, 6-spring clutch, Van clutch plate, Scotts oil filter, K&N.
Todo:CF undertail/gap mod, Discacciati discs, fork revalving, Stealth sprocket, full TLR M4 system, improve crank case breather, fix the broken faring and scratches ...
