Cant get her to fire....HELP...!!! - TLZone Forums
Old 06-19-2009, 07:58 AM   #1 (permalink)
drfunk's Avatar
Member #9825
Sportsbike: '99 TL1000R
Riding Experience: don't wanna talk about it
Trader Rating: (9)
Life Wasted on TLZone: 2 Weeks, 3 Days and 22:39:43 Hours
drfunk is waiting for the good weather
Send a private message to <!-- google_ad_section_start(weight=ignore) -->drfunk<!-- google_ad_section_end --> Steve is the prettiest admin
ok this is the story so far....
battery died....got a new deka.
put her in and fired up ok...
removed side fairing to do charging mod.... guess what?
already been done but with no fuse in line...
disconnect plug from Rectifier, cut wire that goes from rectifier plug back to battery and insert 30amp fuse in the power line...
FORGET to reconnect rectifier to battery before i try to start her...
there's a little puff of smoke from somewhere.... i think it was smoke anyways...
i still have full dash lights, fuel pump primes, all systems go, turns over really well but she won't fire...just seems to be no spark...
the following checks have been completed.... 30amp main fuse, 30 amp inline fuse, all fuses in fuse box.
any ideas?
please help......
Experience is the name so many people give to their mistakes. Oscar Wilde
Getting older and stupider by the day.... Just the way I like it
Don't be stupid ...Wear gear
Old 06-19-2009, 09:51 AM   #2 (permalink)
voodootwin's Avatar
Member #7129
Sportsbike: 2000 Suzuki TL1000R
Riding Experience: 30+ years
Life Wasted on TLZone: 1 Month, 0 Weeks, 6 Days and 11:18:27 Hours
voodootwin Sick of taxes
Send a private message to <!-- google_ad_section_start(weight=ignore) -->voodootwin<!-- google_ad_section_end --> Steve is the prettiest admin
Any idea where the puff of smoke came from? Go over the wiring and all the connection points carefully to locate any burn marks or melted plastic.
"Got torque?"
An optimist believes we live in the best of times
-a pessimist fears this is true
John
Poor Al Gore. Global warming completely debunked via the very Internet you invented. OH. OH the irony. The iro---ny. -Jon Stewart
Old 06-19-2009, 02:10 PM   #3 (permalink)
Just tiny specs in the mirror
chucks_net's Avatar
Member #4998
Trader Rating: (12)
Life Wasted on TLZone: 2 Months, 1 Week, 5 Days and 3:18:24 Hours
chucks_net
Send a private message to <!-- google_ad_section_start(weight=ignore) -->chucks_net<!-- google_ad_section_end --> Steve is the prettiest admin
Sounds like you need the electrical fix... then you will probably get spark
Old 06-19-2009, 03:53 PM   #4 (permalink)
drfunk's Avatar
Member #9825
Trader Rating: (9)
had that problem before so the electrical fix was done...sort of...i suck BADLY at soldering so i used spade connectors instead...mind you the plug was pretty buggered as well.
my next port of call is to remove the inline fuse (it all worked ok before that was added) then remove the main 30amp fuse box (solenoid power?) and check all the connections there....
Old 06-19-2009, 04:09 PM   #5 (permalink)
Life Wasted on TLZone: 3 Months, 2 Weeks, 1 Day and 23:31:04 Hours
wrong!
you're next port of call is to pull off a plug lead and use a spare spark plug to check you actually have no spark, rather than assuming it to be so.
Old 06-19-2009, 04:13 PM   #6 (permalink)
drfunk's Avatar
Member #9825
Trader Rating: (9)
Originally Posted by The Ring-In View Post
wrong!
what else would cause it not to fire?
Old 06-19-2009, 04:32 PM   #7 (permalink)
chucks_net's Avatar
Member #4998
Trader Rating: (12)
chucks_net
yeah -check for spark. The plugs foul very easily if the bike hasn't started or mix is way off.
I one time fouled 3 day old plugs because of a vacuum leak and the bike wouldn't fire after a couple tries. Troubleshot that thing for about a week before i put in new plugs
Old 06-19-2009, 05:47 PM   #8 (permalink)
Life Wasted on TLZone: 3 Months, 1 Week, 6 Days and 15:30:37 Hours
No fuel to the cylinder, fouled plugs, weak battery...
Old 06-20-2009, 10:23 PM   #9 (permalink)
drfunk's Avatar
Member #9825
Trader Rating: (9)
i think i've fried my PC3 usb....
might be my starting problem right there...
any way to repair these things?
Old 06-21-2009, 02:44 AM   #10 (permalink)
drfunk's Avatar
Member #9825
Trader Rating: (9)
yay....
she runs....
PC3 is buggered though....
removed it from the bike connected all the original wiring back and away she went...
thanks to all the guys who offered help and suggestions...
fire....help...!!!
