Wheel Bearings? Have you ever had this? - TLZone Forums
Old 05-14-2009, 04:43 PM   #1 (permalink)
tls-moose's Avatar
Member #785
Sportsbike: Tillis, What else?
Riding Experience: A bit more than it was
Trader Rating: (23)
Life Wasted on TLZone: 1 Month, 3 Weeks, 3 Days and 13:08:02 Hours
tls-moose
Send a private message to <!-- google_ad_section_start(weight=ignore) -->tls-moose<!-- google_ad_section_end --> Steve is the prettiest admin
Question Wheel Bearings? Have you ever had this?
I changed the chain and sprockets (DID 530ZVM & decent steel 17/42 sprockets) on my bike at a friends yesterday (he has a proper workshop). Before we started everything was fine and all working OK (to the best of my knowledge .... ) Once all was done and the bike back together it made a slight occasional "graunch" sound as the wheel rotated.
As I had an appointment, I rode the bike home about 6 or 7 miles with no problems.
this evening I have been trying to locate the sound, and it appears to be coming from the wheel hub rather than the chain and sprockets, and it gets worse the tighter you do up the wheel nut (hence asking the correct torque earlier)
I have taken the wheel out and checked all the bearings and they feel fine to the finger, rotating smoothly and no feel of sloppiness or tightnes - they've only done about 5k miles since replacement. I've cleaned and re-greased the spacers and spindle, double checked the wheel/chain alignment, and all is OK thee, but as I rotate the rear wheel gently with the nut done up tight I can still just hear a noise and it always seems to be when the wheel is at a certain point in it's rotation ... though if I slacken the nut so it's just too loose to feel comfortable riding with it (6-7Kg/M ish) it go's away
Now, under normal circumstances I'd probably just live with it and see what happens, but I am supposed to be on the ferry to France after work tomorrow for a 5-600 mile round trip to Le Mans for the MotoGP
I am tempted to call in to work tomorrow and go get a new set of wheel bearings just for peace of mind, but it's such a ball-ache to do .... decisions, decisions ......
has anyone else ever had this "noise" issue
Done: Fat-bar conversion; DNA Handlebar fairing; TLR Clock conversion; Yosh TLR Headers, one-off link pipes & Carbon cans; Relocated oil cooler; Relocated Coolant bottle; Transistor TRE; PCII; +1/-1 sprockets; Hyperpro steering damper & 916 style mount; Maxton Re-Valved forks; Tokico 6 pot callipers; HEL braided hoses; TLR Swing-arm; Bitubo shock; Yellow Box; 98+ Thermo-mod; JarkkoT +/- mod; Airbox mod; K&N air filter; Riflemans 1/5th; Harris carbon mudguard; Carbon Solo Seat Unit; Pyramid undertray; Powder coated wheels; Mini indicators; LSL rearsets; Scotoiler
Old 05-14-2009, 07:02 PM   #2 (permalink)
Life Wasted on TLZone: 3 Months, 1 Week, 0 Days and 23:55:29 Hours
Is the rotor bent a bit and making contact with the pads as you spin the wheel?
Old 05-14-2009, 07:22 PM   #3 (permalink)
133bhp's Avatar
Member #4408
Life Wasted on TLZone: 3 Weeks, 2 Days and 8:32:58 Hours
133bhp
Send a private message to <!-- google_ad_section_start(weight=ignore) -->133bhp<!-- google_ad_section_end --> Steve is the prettiest admin
spacers back in right side?? Althouigh from memory I think they're self explanatory?? Have you tried removing the caliper/chain to try and eliminate them? does sound like a abearing though?
Main sponsor.-
ebaY
Old 05-14-2009, 09:14 PM   #4 (permalink)
TLR-Brendan's Avatar
Member #9502
Sportsbike: 02 TL1000R, 00 TL1000R, 97 TL1000S
Riding Experience: 14
Trader Rating: (12)
Life Wasted on TLZone: 3 Weeks, 5 Days and 15:10:10 Hours
TLR-Brendan
Send a private message to <!-- google_ad_section_start(weight=ignore) -->TLR-Brendan<!-- google_ad_section_end --> Steve is the prettiest admin
The hub bearing goes bad on the rear wheels first. If you can get your rear wheel back off without much work check out the hub bearing....
2002 TL1000R, Air box mod, Pipercross air filter, Full yoshimura RS-3 stainless, Yoshimura box remap. R-1 throttle tube, Bitubo rear shock, Vandriver billet rear resovoir, tail risers, +1mm swingarm eccentrics, sprocket cover.
Future plans. 12.6:1 pistons, Web cams and gears, PCIII, Matchported and cleaned up heads, Vandriver triple clamps and clutch cover...
SOLD2004 GSX-R 1000, K&N air filter, Full yoshimura carbon TRS exhaust, -1 front sprocket. 148.3 horsepower and 73.14 ft-lbs torque.
2000 TL1000R track bike. K&N air cleaner, yoshimura RS-3 carbon full system with dual oxygen sensor bungs. Stock engine for now......
1997 TL1000S, soon to be TLR powered....
Old 05-15-2009, 12:12 AM   #5 (permalink)
officer140's Avatar
Member #13045
Sportsbike: 1999 TLR
Riding Experience: Fall down & get back up
Trader Rating: (8)
Life Wasted on TLZone: 1 Week, 3 Days and 7:02:52 Hours
officer140
Send a private message to <!-- google_ad_section_start(weight=ignore) -->officer140<!-- google_ad_section_end --> Steve is the prettiest admin
Could be a bearing - PM sent for similar help.
Old 05-15-2009, 09:28 AM   #6 (permalink)
tls-moose's Avatar
Member #785
Trader Rating: (23)
tls-moose
£40 for all three wheel/sprocket carrier bearings (didn't have time to shop around ) wheel out at 15.10, wheel back in at 15.50 and no more noise
I think it was the sprocket carrier bearing, but I didn't have time to p*ss around checking really. All three bearings felt absolutely fine before and after they came out but either way, it's done & I have peace of mind
Expensive month ..... tyres (Diablo's) £140, chain & sprockets (DID) £120, Bearings £40, MOT £30, and I indulged myself in new textile trousers £50 (reduced from £100) and a new helmet £180 (Arai Condor)
.... and I leave for the ferry to go to the Le Mans MotoGP in 3hrs
Old 05-15-2009, 10:17 AM   #7 (permalink)
TLR-Billbo's Avatar
Member #1415
Trader Rating: (48)
Life Wasted on TLZone: 3 Months, 3 Weeks, 0 Days and 14:36:53 Hours
TLR-Billbo is dreading winter coming
nice
*2005 SXR 800*Skat 9/17 140-75 SS Impeller*Blowsion mat kit*Blowsion billet bilge switch*Rule 500GPH bilge*R&D bilge bracket*R&D billet angled reed spacers*V-Force Delta 2 Carbon reeds*R&D exhaust sleeve*Wamiltons scupper*Wamiltons stubby pump cone*fuel fill and pickup mod*-4" hull*-1.5" pole*R&D stealth intake grate*-4" ride plate*ODI grips*R&D Pro-lock filters*Jetworks mixture screws*Blowsion billet engine mount keepers*R&D 6º ignition adv kit*Billet driveshaft couplers*dual-cooling*
Still To Come:*Factory Wet Pipe*AC Racing pole*Footwells*new mats*Wiseco 80.96mm factory Kawi race pistons (true 800cc)*fresh bore and hone*
MySpace and Facebook
Old 05-15-2009, 10:46 PM   #8 (permalink)
pmmonster's Avatar
Member #2388
Sportsbike: Green '97 TL1000S; '73 Goose; 1999 TTR250 (street legal)
Riding Experience: 21 years - street
Trader Rating: (18)
Life Wasted on TLZone: 2 Weeks, 6 Days and 1:32:03 Hours
pmmonster
Send a private message to <!-- google_ad_section_start(weight=ignore) -->pmmonster<!-- google_ad_section_end --> Steve is the prettiest admin
I was going to suggest borrowing a wheel from someone else but it sounds like you're sorted. Be sure to report from LeMans... we need PICS!!!
Pete - Ann Arbor
Penske, 6 piston brakes, fighter, airbox, breather mod...
Old 05-16-2009, 01:26 AM   #9 (permalink)
wreckah's Avatar
Member #144
Sportsbike: '09 KTM 990 SM-T
Riding Experience: 10 years
Trader Rating: (40)
Life Wasted on TLZone: 1 Week, 6 Days and 20:53:45 Hours
wreckah is quite fit, but he'll die
Send a private message to <!-- google_ad_section_start(weight=ignore) -->wreckah<!-- google_ad_section_end --> Steve is the prettiest admin
good going moose, and good luck on the trip
'AVE FUN!!!
<a href=http://www.mojomoto.be/logo.gif target=_blank>http://www.mojomoto.be/logo.gif</a>
bearings?, this?, wheel
