Iso 99 tl1000r ecu (North Carolina)
Results 1 to 7 of 7
Thread: Iso 99 tl1000r ecu (North Carolina)
    Apr 2017
    New to the site, but looking for an ecu for my tlr if anyone has one or can recommend let me know thanks!
    12,752
    never seen one fail.
    why do you need one?
    Naked TLS 97 , D port heads, TRE, Carrozzaria gold wheels, GSXR750 triples and forks, R1 calipers, Ti Force titanium exhaust system, welded clutch centre, ring-in CCC, polished pressure plate, 999 ducati radiator, custom handlebar fairing, polished ali screen, TLR clocks, Van reservoirs, TLR swingarm, TLR Ohlins rear shock, billet tank cap, Norton Commando handlebars on 65mm risers, extra heavy polished billet brass bar-ends, custom shaped seat pad, billet levers and pegs, stainless brake lines, modified airbox, PC11 ,undertail, hugger, clear taillight lens, hidden LED number plate lights, Personal number plate (97TLS),SV coils, ring-in pushrod seal saver.
    Apr 2017
    That's what I was told is needed,been chasing a no start issue for a while now so I caved and took it in. No spark c41 all connections look fine , not really mechanically savvy but done lots of reading and experimenting lol
    12,752
    c41 fuel pump relay
    how do u know no spark?
    GP Champ rxf610's Avatar
    Georgia, US
    1,293
    Quote Originally Posted by The Ring-In View Post
    Stu,
    Believe it or not the R ecu (never seen any S) blow the transistor that controls the fuel pump. C41 is a pretty much a sure fire indication.
    I would know as I had it happen...
    But to your point, it will not prevent spark, just won't prime the fuel pump.
    The fix is either short to ground the orange wire to force the pump on. Instead of a three second prime then off, it'll simply run indefinitely. (And the bike will run just fine. )
    The true fix is a new ecu, since the ecu can no longer control the fuel pump...
    In a tip over, the pump normally is disengaged. In the first scenario, it'll keep blasting fuel out.
    ... listen to Six5 ...
    Georgia, US
    1,293
    Dvanz,
    On a side note, can I have your ECU if you decide to get a new one.
    Apr 2017
    Got ahold of one yesterday, fired right up. Thanks for the info guys
