Race oil available in Canada - TLZone Forums
Go Back   TLZone Forums > Region Specific Forums > Canadian Region
Old 02-24-2009, 06:14 AM   #1 (permalink)
GlennCauley's Avatar
Member #7709
Sportsbike: 2002 RC51 SP2 + 1998 TL1000R
Riding Experience: 34 years & counting
Trader Rating: (28)
Life Wasted on TLZone: 1 Week, 3 Days and 7:57:26 Hours
GlennCauley
Send a private message to <!-- google_ad_section_start(weight=ignore) -->GlennCauley<!-- google_ad_section_end --> Steve is the prettiest admin
I'm looking for somewhere I can get good race oil in Canada. Seems all the cool oils you read about are available elsewhere... USA, Europe, etc. but not here.
Wanted:
100% fully-synthetic
motorcycle-specific oil (for wet clutches)
for V-twin racebikes (if possible)
20w50 preferred (or 15w50, 10w40)
Oil that sounds interesting, but not avail in Canada:
Castrol Power RS V-Twin 4T
I don't care if I get it from Canadian Tire or a bike shop... but I'll be looking for a case.
Anyone, anyone?
GDRacing Canada Motosports Team
www.gdracing-canada.com
TLotM July 2009
Yoshimura Open SuperSport engine | WitchHunter-tuned fuel injectors | TiForce full exhaust | Pipercross airfilter | NGK race plugs | Braunberger Autosports ECU | 1/5 throttle insert | Machined alu sprocket cover | Accelerated Technologies suspension | Hyperpro RSC steering damper | Renthal grips | TLS cable clutch w/ Pazzo lever | Brembo 19RCS radial brake MC w/ remote reservoir | HEL SS brake lines | BrakeTech AXIS ductile iron rotors | Pro-Bolt Ti disc bolts | Brembo/Ducati 4-pad calipers | Ferodo CP2.11 ceramic pads | Sharkskinz race bodywork + fender | Chelapa ram airtubes | Graves fairing stay | ETI Fuel Cel (Kevlar) | Stomp Grip tank traction pad | QB Carbon self-supporting tail section | RK 520GXW chain | TechG adj. rearsets | +1mm swingarm eccentrics | Penske/LE rear shock + linkage | Yoshimura/Marchesini cast magnesium 16.5" sprint wheels
Old 02-24-2009, 08:45 AM   #2 (permalink)
Member #3007
Sportsbike: 2000 TL1000R
Riding Experience: 18 years
Life Wasted on TLZone: 3 Weeks, 2 Days and 17:08:00 Hours
dmilty
Send a private message to <!-- google_ad_section_start(weight=ignore) -->dmilty<!-- google_ad_section_end --> Steve is the prettiest admin
I used to be a parts manager for Inglis cycle in London, ontario. Let me make a few calls for you glen and see what I can come up with....
Old 02-24-2009, 09:07 AM   #3 (permalink)
SnailsPace's Avatar
Member #7640
Sportsbike: 02 TL1000R +more
Riding Experience: 20+
Trader Rating: (105)
Life Wasted on TLZone: 5 Months, 1 Week, 4 Days and 5:09:31 Hours
SnailsPace has a motorcycle addiction....
Send a private message to <!-- google_ad_section_start(weight=ignore) --><b>SnailsPace</b><!-- google_ad_section_end --> Steve is the prettiest admin
Can you get Shell Rotella Glenn?
Old 02-24-2009, 09:33 AM   #4 (permalink)
Member #7709
Trader Rating: (28)
GlennCauley
Not sure... I'll have to look.
I'm looking at the information for Rotella on Wikipedia:
Though marketed as an engine oil for diesel trucks, Rotella oil has found popularity with motorcyclists as well. The properties of heavy duty engine oils tend to map to the same requirements of motorcycle oils, particularly those whose engine and transmission share the same oil. (This is called a "shared sump" design, which is unlike automobiles which maintain separate oil reservoirs - one for the engine and one for the transmission). The chemical additives found in heavy duty engine oils work well with motorcycles. In addition, the lack of "friction modifiers" in truck oils such as Rotella means they do not interfere with proper wet clutch operations.
Motorcycle specific oils tend to cost between $8 and $10 per quart. Shell Rotella T 15W-40 costs about $10 per gallon (or about $2.50/quart). The price economy of Shell Rotella T allows a motorcycle owner to change oil more frequently, thus matching the "extended change interval" value of motorcycle specific synthetics.
Not sure if it would be well suited to racing, though... or even if it is 100% synthetic (which I want).
TLotM July 2009
Old 02-24-2009, 09:52 AM   #5 (permalink)
SnailsPace's Avatar
Member #7640
There are 2 types of Rotella. Dino and full synthetic. The synthetic retails here for about $20 a gallon at Wal-Mart.
It is 5w 40 though.
Pic courtesy of google images!
Old 02-24-2009, 10:08 AM   #6 (permalink)
Member #7709
Trader Rating: (28)
GlennCauley
It is 5w 40 though.
Have you used this for racing in your TL?
If yes, and if it was 20w50 I'd jump at it.
"Dino" oil
TLotM July 2009
Old 02-24-2009, 10:15 AM   #7 (permalink)
SnailsPace's Avatar
Member #7640
My race bike is yet to see the track.
I run it in everthing else that I own though.
Diesel truck, wifes car and all of our bikes.
This is what convinced me......and N2 doesn't even use the synthetic!
pistons and cylinder heads after 65K miles pictures
Followed up by this...
rotellaT testimonial part II - now with power shifting is OK sprinkles
Old 02-24-2009, 11:01 AM   #8 (permalink)
Life Wasted on TLZone: 3 Months, 1 Week, 6 Days and 14:58:27 Hours
"Dino" oil
I do believe N2wheelies used the Rotella synthetic in his bike, which saw lots of drag race time. There was virtually no wear apparent when he tore the motor down for a bit of a warming over.
Old 02-24-2009, 11:04 AM   #9 (permalink)
SnailsPace's Avatar
Member #7640
Post No. 3 in the first thread.
Originally Posted by N2wheelies View Post
6.99 a gallon dino 15w-40
Old 02-24-2009, 11:51 AM   #10 (permalink)
Member #1010
Sportsbike: '98-TLR, '80 Z-50
Riding Experience: 25+ years
Trader Rating: (6)
Life Wasted on TLZone: 1 Week, 1 Day and 9:52:51 Hours
TLR-NUT
Send a private message to <!-- google_ad_section_start(weight=ignore) -->TLR-NUT<!-- google_ad_section_end --> Steve is the prettiest admin
Rotella-T is only available in 15-40 for the mineral and 5-40 for synthetic, I believe. I prefer Motul 300v. 100% ester oil.
Modded everything. Not much left stock. Highlights: Marchesini mag wheels, Yosh aluminun fuel tank, JE 2mm pistons, VeeTwo cams. Kit Titanium rods, ect...
canada, race
