Well... it's time to share the new look! - Page 3 - TLZone Forums
Go Back   TLZone Forums > Image Galleries > Bike Pictures
Bike Pictures Got pics of your baby? Put 'em here
Old 07-14-2009, 03:21 AM   #21 (permalink)
JCM JCM is offline
JCM's Avatar
Member #11718
Sportsbike: 1997 Suzuki TL1000S Dark Green
Riding Experience: Novice
Pictures: 2
Life Wasted on TLZone: 2 Weeks, 5 Days and 10:10:00 Hours
JCM
Send a private message to <!-- google_ad_section_start(weight=ignore) -->JCM<!-- google_ad_section_end --> Steve is the prettiest admin
Bike looks awesum man!!
One small Q, whats the reason for the axle switch mod?
Great looking bike!
97 TLS with TRE, 1/5 rifleman insert, Airtech filter, 17/40 sprocks, gutted pipes, bitubo rear shock, Reverse Shift setup
Old 07-14-2009, 08:36 AM   #22 (permalink)
GhostMAFIA's Avatar
Member #13066
Sportsbike: 97 TLS
Riding Experience: Not long enough!
Trader Rating: (24)
Life Wasted on TLZone: 3 Weeks, 4 Days and 18:37:12 Hours
GhostMAFIA think's he's on a Kawasaki... we won't tell if you don't!
Send a private message to <!-- google_ad_section_start(weight=ignore) -->GhostMAFIA<!-- google_ad_section_end --> Steve is the prettiest admin
Great looking bike!
Keeps your chain from losing tension... even with the tensioners (sp?) it seems to get loose more often with the nut on the other side. Simple mod, do it the next time you have your rear wheel off.
M4 Carbon Pipes|Ohlins shock|gap mod|front signals|6 pot calipers|Zero Gravity|custom paint & vinyl|frame labels stripped|bar ends|SilverStar bulbs|solo hump|Van's sprocket cover|Geelong CF tank protector|CF heel guards|Dunlop Qualifiers|tire lettering|Tsubaki Gold Series chain|10wt fork oil|powdercoated rims|axle flip|stems/caps|LED taillight|Galfer SS brake lines|Ohlins damper|lower fairings|hugger|Van's front & rear resi|frame sliders|chrome pegs|Driven D-3 grips|K&N air filter|Barnett springs|swingarm spools|Vortex sprockets 17/38|rim stripes|gas cap|tag relocator & bolts|Roaring Toyz mirrors|Matt's TRE|gauge lights/needles|clear/white headlight|Van's rear brake spring/seat|Rifleman's 1/5th insert|FP Levers|Van's CCC, plate & retainers|Hump saver cable|Van's top triple|polished headers|CSS seat cover|Van's oil plug|CF Ducati fender
Old 07-14-2009, 09:03 AM   #23 (permalink)
WSB Pit boss
Gigas's Avatar
Member #2708
Sportsbike: TLS 1000, Husqy 610 SM, Enfield Bullet 500
Riding Experience: Always learning...
Life Wasted on TLZone: 1 Year, 9 Months, 1 Week, 4 Days and 5:04:23 Hours
Gigas misses his lost innocence...
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Gigas<!-- google_ad_section_end --> Steve is the prettiest admin
Actually it's for the exact opposite reason
While trying to adjust your chain and you think that it's spot on, you have to thighten that axle nut on the left. Just after torquing it, you recheck the chain and you find it to be really tight, something that is bad for the output bearing of the motor, jsut behind the front sprocket.
By switching the axle nut to the right, this problem dissapears and the adjustment of the chain is much easier.
BTW, I am not really fond of the green colour and the full fairing on the S but I have to admit there's tons of work on your bike.
That front light cover looks interesting. Can you post some details of what it is made of?
Old 07-14-2009, 05:01 PM   #24 (permalink)
GhostMAFIA's Avatar
Member #13066
Sportsbike: 97 TLS
Trader Rating: (24)
What he said... and why didn't I remember it that way around. All my days adjusting my bicycle chain I guess!
The head light covering is perforated vinyl, the kind they use at sign shops to wrap entire vehicles (buses us this alot) in a graphics, etc... and still be able to see out the windows.
It's rated at 50% transferrance for visibility, but with the white color and my hyper white bulbs, you can still see fine at night, even with the low beams on. I use a tinted visor at night, and usually ride with brights when there is no traffic. (I hate switching the visor... I know, I know) and it's fine even at night with my tinted visor. I would assume dark colors would reduce the light that would project out, but with the size of the holes, I'd bet high beams would work in place of low beams, even with black.
I just bought some white (I think they make other colors, but they can PRINT any color, or pattern on it you need) and traced the pattern for the way I wanted it. Initially I was going to wrap the whole headlight, but the S headlight curves a lot and it was difficult to wrap without wrinkling. I then decided to do just the pattern around each headlight that's naturally on the lens, and it looked even better. You still have some wrinkles to deal with and some working it, or cutting them out work out just fine.
I appreciate the compliment, especially from someone who gets a lot of nominations for TLOTM. I'm hoping to at least get a nomination some day... I still have some other projects planned, but the overall look is close enough I figure I'd toss some pics out there and see if anyone though it was worthy yet.
Old 07-15-2009, 06:43 AM   #25 (permalink)
1ncredible's Avatar
Member #15746
Sportsbike: TL1000S 1999
Riding Experience: 8 years
Life Wasted on TLZone: 2 Weeks, 2 Days and 12:16:34 Hours
1ncredible
Send a private message to <!-- google_ad_section_start(weight=ignore) -->1ncredible<!-- google_ad_section_end --> Steve is the prettiest admin
I'm absolutely loving this!!
Old 07-15-2009, 10:07 AM   #26 (permalink)
daveC's Avatar
Member #3235
Sportsbike: 06 ZX10R
Riding Experience: Should know better.
Trader Rating: (38)
Life Wasted on TLZone: 2 Weeks, 0 Days and 9:09:34 Hours
daveC
Send a private message to <!-- google_ad_section_start(weight=ignore) -->daveC<!-- google_ad_section_end --> Steve is the prettiest admin
Thats a fine looking ride.
Man, I want another tillis.
Old 07-15-2009, 02:41 PM   #27 (permalink)
TLSFREAK's Avatar
Member #14217
Sportsbike: What forum is this....
Riding Experience: Broken 3 bones ;-(
Trader Rating: (4)
Life Wasted on TLZone: 1 Month, 2 Weeks, 2 Days and 4:05:41 Hours
TLSFREAK
Send a private message to <!-- google_ad_section_start(weight=ignore) -->TLSFREAK<!-- google_ad_section_end --> Steve is the prettiest admin
Mate, love the color, fairing and wheels
Cool close up photos too
T L O T Y
Old 07-15-2009, 04:07 PM   #28 (permalink)
GhostMAFIA's Avatar
Member #13066
Sportsbike: 97 TLS
Trader Rating: (24)
Coming not only from a TLOTM winner, but TLOTY winner this time! Awesome
Thanks everyone... all the comments are making the MANY late nights worth it!
I usually here TONS of bad comments on lowers for the S, but most of the comments have been good on mine. Not sure why that is, but I really appreciate it.
When I initially posted pics of the color a couple months ago, I figured I'd get flamed for the Kawasaki color, but everyone was super cool about it, and it was all good comments.
I still have some things to do, and my next "big" item (in terms of cost) will probably be a clutch cover, etc... from Vandriver. (if/when they are available after I've secured the cash)
Old 07-15-2009, 04:44 PM   #29 (permalink)
TLR-Billbo's Avatar
Member #1415
Trader Rating: (48)
Life Wasted on TLZone: 3 Months, 3 Weeks, 0 Days and 17:22:23 Hours
TLR-Billbo is dreading winter coming
nice work, super clean
*2005 SXR 800*Skat 9/17 140-75 SS Impeller*Blowsion mat kit*Blowsion billet bilge switch*Rule 500GPH bilge*R&D bilge bracket*R&D billet angled reed spacers*V-Force Delta 2 Carbon reeds*R&D exhaust sleeve*Wamiltons scupper*Wamiltons stubby pump cone*fuel fill and pickup mod*-4" hull*-1.5" pole*R&D stealth intake grate*-4" ride plate*ODI grips*R&D Pro-lock filters*Jetworks mixture screws*Blowsion billet engine mount keepers*R&D 6º ignition adv kit*Billet driveshaft coupler*dual-cooling*Wiseco 80.96mm factory Kawi race pistons (true 800cc)*UMI Billet throttle lever*
MySpace and Facebook
Old 07-17-2009, 09:00 AM   #30 (permalink)
WSB Pit boss
PutteLiten's Avatar
Member #793
Sportsbike: Honda XR650R SuperMotard -03 + Black TL1000R - Yellow at heart
Riding Experience: Lots of years...
Trader Rating: (9)
Life Wasted on TLZone: 6 Days and 21:46:10 Hours
PutteLiten
Send a private message to <!-- google_ad_section_start(weight=ignore) -->PutteLiten<!-- google_ad_section_end --> Steve is the prettiest admin
Originally Posted by wreckah View Post
the color is soo wrong for a suzuki, but it damn looks fantastic, and i love the close up shots! good job!!
Looks great!
TL1000R -99. Black. (Yellow at heart)
Engine: PCIII, M4 Full system(Alu), K&N Filter, TRE mod, Joe V moded, removed Pair valve. Removed Scissor gears, Iridium plugs, Vandriver clear clutch cover, Vandriver billet clutch plate.
Chassis: Öhlins rear, Brembo front brakes, Black TLR/R fairings, dark windscreen, Gilles Toolings rearset, Carbon fibre hugger, carbon fibre rearhugger, ET79 undertail, Pazzo levers, +1mm Billet swingarm pivot eccentics, Gilles Clip-On.
Misc:
Gap mod, Diod indicators, Vandriver Billet rear reservoir, clip-on mirror.
And a couple of other minor mods I cant remember...
it's, look!, share, time, well...
