Front Tyre Alignment Question - TLZone Forums
Go Back   TLZone Forums > Region Specific Forums > Aussie Forum
Aussie Forum Rides, Rallies and info specific to the land down under.
This box pays the bills.
Old 10-07-2008, 03:16 AM   #1 (permalink)
Moyston's Avatar
Member #11365
Sportsbike: TL 1000 R
Riding Experience: 20 year
Trader Rating: (4)
Life Wasted on TLZone: 1 Week, 0 Days and 11:41:51 Hours
Moyston
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Moyston<!-- google_ad_section_end --> Steve is the prettiest admin
Question Front Tyre Alignment Question
Could someone tell me the best way to align the front tyre. Came home from the island and the driveway was a bit wet and i rode it up and parked it under the garage and when i went to the front of the bike, you could see that the wet mark on the tyre was to the left of the centre. Had a closer look and the tyre is wearing on the left hand side, just not in the middle.
Do you tackle the front or is that the back is out of alignment and whats the best way to get it back wearing in the centre of the tyre? thanks
Stop staring at my Tits!!
Old 10-07-2008, 04:20 AM   #2 (permalink)
2much's Avatar
Member #15418
Life Wasted on TLZone: 4 Days and 4:33:00 Hours
2much
Send a private message to <!-- google_ad_section_start(weight=ignore) -->2much<!-- google_ad_section_end --> Steve is the prettiest admin
Move your arse further to the left of the seat. It's probably your balance and positioning on the bike rather that the bike's alignment... Unless one one fork is raised drastically more in the triple clamp than the other but I expect you would've noticed that already.
Old 10-07-2008, 04:23 AM   #3 (permalink)
Sam Sam is offline
Sportsbike: 3 TLS's, GSXR1000K7, SuperDuke R
Riding Experience: 32 Years & Still Counting
Trader Rating: (71)
Life Wasted on TLZone: 3 Weeks, 2 Days and 3:37:21 Hours
Generally two parallels either side of the rear tyre up to the front wheel, but aiming the rear tyre at the front can hide a bent headstock etc
Difficult to check the front end for straightness without a bit of careful measuring.
I've levelled the TL before by placing a spirit level on top the subframe/swingarm splindle/top frame rails etc to get it dead level then placed the spirit level vertical on the side of the front tyre. This will only check twist in the headstock and not if it's been pushed back. I check the wheelbase from the manual for that but obviously it varies with chain adjustment so only a rough indication.
Old 10-07-2008, 08:02 AM   #4 (permalink)
Resident Presidential Candidate
Kamikuza's Avatar
Member #4632
Trader Rating: (19)
Life Wasted on TLZone: 3 Weeks, 1 Day and 21:31:12 Hours
Kamikuza doesn't want to go back to work next week
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Kamikuza<!-- google_ad_section_end --> Steve is the prettiest admin
The dyno at the LBS uses the wheel clamps to check for alignment ... cost me like ¥2,000 and is all within 0.5mm peace of mind
It's time to change America! Peace and Prosperity! Kuz for Kommandant!
FYI OEM prices - check here before your dealership rips you off!
Old 10-07-2008, 03:55 PM   #5 (permalink)
Moyston's Avatar
Member #11365
Trader Rating: (4)
Moyston
was looking up last night and a cpl of threads on using string to tie round rear tyre and pulling up straight and shows if out of alignment. but nothing in manual at all, and will look at bearings and forks to see if loose and axle out a bit....
Old 10-07-2008, 04:06 PM   #6 (permalink)
Blade Runner
TomM's Avatar
Member #6594
Life Wasted on TLZone: 6 Days and 15:04:32 Hours
TomM
Send a private message to <!-- google_ad_section_start(weight=ignore) -->TomM<!-- google_ad_section_end --> Steve is the prettiest admin
most people turn left better than right, might be that. im fairly sure theres someone down mexico way that checks for straightness. but its a pain and you have to strip everything except the engine. + side is its cheap to do (well in syd it is).
Old 10-07-2008, 04:44 PM   #7 (permalink)
Beaza's Avatar
Member #4865
Sportsbike: TL1000S, YZ490, CR85R, 125cc PITBIKE, PW80, Z-fiddy
Riding Experience: bout 29 years
Trader Rating: (16)
Life Wasted on TLZone: 2 Weeks, 3 Days and 9:37:33 Hours
Beaza
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Beaza<!-- google_ad_section_end --> Steve is the prettiest admin
Sounds odd Moyston, cause our roads generally have a slight off-camber to the left side, meaning we usually get a bit more wear on the right side of the front tyre . Not sure what your solution might be .
Beaza.
98 Black TLS - Full Yosh Titanium race system with Carbon RS3 Cans - N.W.S. Hugger - Ohlins rear stick - Race Tech .95 & Gold Valve Front End - TRE - BMC air filter - Airbox mod. - Power Commander II - Dark Tint DB Screen - Gold Busa 6 Pot Front Calipers - Busa Nissin 5/8 m/c - Custom Stainless Steel Brake Lines - Rizoma Bar End Mirrors - Gap Mod. - Custom Alloy Checkerplate Undertail - Cats Eye Indicators - 16/41 sprockets with gold RK chain - 'Ziggy999 Frame Sliders - Riflemans 1/5th Throttle Insert - Riflemans Clear Clutch Cover - Scotts Billet Oil Filter - Vandriver Billet Rear Brake Res. - Adjustable Black Rearsets - Carbon Fibre Quick Fill Fuel Cap - External Fuel Filter mod - Fan Switch mod.
Old 10-07-2008, 06:54 PM   #8 (permalink)
Loki-TLR's Avatar
Member #7563
Sportsbike: TL-r, Bandit 6
Riding Experience: 3 years
Life Wasted on TLZone: 1 Week, 2 Days and 17:43:10 Hours
Loki-TLR
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Loki-TLR<!-- google_ad_section_end --> Steve is the prettiest admin
Wouldn't the swingeraxle make a nice referencepoint? Maybe with the addition of some extensions to make it easier to work with and have more accuracy. Not to forget the possibility to use it for checking rearaxle alignment. Only 'problem' I can think of right now is the unknown offsets from center of the bike to both ends of the swingeraxle.
..Seducing TL rumble playing my mind once again..
alignment, front, question, tyre
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
The TLZone Blog:
